Question about Iomega NAS P415m 180 GB Hard Drive Array
Hard drives freezing up
We had a power spike that took out the power supply on our unit. Had the power supply replaced but, ever since then the unit thinks the Raid-5 drive has failed and begins to regenerate. When it finishes regenerating the Raid, after about 1/2 an hour (or so), everything freezes up on the device. The only way to get it going again is a hard boot which starts the whole process over again (Raid failed - regenerate - finish regeneration - freeze, etc. etc...) Any ideas?
  • Irwin Matthies Jun 27, 2007
    I haven't tried your solution yet as we are currently undergoing a rollover to SAP.
  • Irwin Matthies Jul 28, 2007
    I tried testing the drive but was unsure as to whether a RAID-5 drive could be imported onto my XP machine. When I tried it the message came up that I could lose data so I felt it best not to import until I have more information.
    Is there a way to do this test without losing data?
  • 97 Answers
Damaged drive controller on HDD a possibility. Pull drive and test as a slave to rule out a bad RAID controller. Let me know if the drive is failing under SMART setting in system BIOS upon boot.
Posted on Jun 25, 2007
Polaroid FLM-3701 power
Unfortunately modern televisions and monitors are full of electronic semiconductors of which many are likely have got destroyed along with your original power supply during the storm. A nearby lightning strike will send high voltage spikes down aerial cables as well as through socket outlets.
If you have contents insurance you should be able to claim for a new monitor.
Nov 09, 2013 | Polaroid FLM-3701 Television
Burnt Out Case
are the machine operational or dead?
First find what is burned out on copier.
There are proposals from UPS and other device manufacturers that they arent predicted for copiers and laser printers.
If you want to be sure regarding power supply or network install power cord with auto fuse, wich will disconnect the power in case of el. discharge.
May 22, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Our power went out but it's back on and my hard drive wont come on
power supply could of been hit by a spike if you are usiang a power strip that are cheap or not using a spike arestor on your system then that will kill your computer faster then you might think
Dec 10, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
EMachines T2824. Does nothing but light on mainboard coming on...
This is a motherboard problem. You'll need to replace it. Although, it may be cheaper just to buy a new PC (eMachines are never very expensive, or well-made for that matter)
Sep 22, 2009 | Computers & Internet
Yamaha HTR-5890 not powering up
Power supply is burned out. surge or spike got it, replace power supply unit.
Sep 08, 2009 | Yamaha HTR-5890 Receiver
Dp-01fx tascam
Since the unit powers up and displays an error message it means that the power supply is working to some extent. The hard drive is probably malfunctioning and needs to be replaced. The DP-01 I have uses an 40 pin IDE 3.5" hard drive so finding a replacement should be easy unless it needs special formatting like TIVO drives.
As for the first solution - why do you think a PC hard drive needs -5v? The PC drive power connector has four pins - two grounds, 5v and 12v.
Mar 30, 2009 | Tascam DP01FX All-In-One Recording Package...
My Elements 500 ext hard drive no longer appears on desktop
I did this on my PC. Took it to the shop (Harvey Norman). The techie reckons I got a spike across the terminals because I did not properly disconnect. He reformatted the drive for me. Unfortunately i lost everything on it (unrecoverable anyway he said). Worked fine till I got a problem with the transformer. Still working on that one. Know where to get a new transformer/power supply?
Jan 24, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
My SIR-S4040R no longer turns on..
If the unit doesn't power on at all, no fan spinning and no power light, then it's either your power supply, and/or motherboard. Your hard drive could be damaged as well. You can find power supplies by googling tivo power supplies.
You may be better off sending out the unit for testing/repair. I recommend CCS in Indiana. Fast, and friendly service, used them many times. You will need to lose anything that was on the unit (settings, season passes and recordings) to ensure the drive is fully functional.
Dec 29, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Hard drive light stays on and system freezes
You may have a hardware problem of some sort. The first place I'd start is to check the power supply voltages. If one or more voltages is off tolerance, this will cause all sorts of symptoms. if you have a voltmeter check especially the +5, +3.3, +12, & +5 standby voltages. Use this site as a reference http://pinouts.ru/Power/atx_v2_pinout.shtml If the supply checks out faulty, buy a replacement, or, if tech savvy, you might repair it-- probable component defects= one or more electrolytic capacitors. Other possible problems are Memory errors (try subbing a RAM stick), hard drive developing errors, or a bad chip on the motherboard. If you have some spare parts, RAM, hard disk, you can try subbing parts and narrow down the problem.
Apr 27, 2007 | E-Machines T2792 PC Desktop
Iomega NAS P415m 180 GB Hard Drive Array Logo
359 people viewed this question
Top Iomega Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Alun Cox
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
