Question about Kohler Plumbing
Cannot separate new Kohler stainer from other parts
The parts are screwed on too tightly and I don't want to scratch anything trying to get them apart with a wrench. I don't even have a wrench is big enough to grip it.
  • 2,427 Answers
Unfortunately you will need a wrench to take it apart.. you can use some contact cleaner or rust remover to loosen it up a it. Just be sure to wash all the residue off.
Posted on Dec 30, 2012
I ordered a new blade because the original one's
No one can help you without the make and model number of your shaver
Apr 25, 2013 | Health & Beauty
Kohler cimarron broken seat, replacement parts don't work 2x's
No do not use metal bolt and nut as this can crack the toilet. Just go to Lowes or Home Depot and buy 2 plastic bolts , 2 plastic wing nuts, and 2 plastic washers. Install with seat through toilet holes and tighten by hand until tight. I then use pliers to tight just a turn tighter and the seat should be center as you tightened one side, then the other, and back again until tight.
Mar 17, 2013 | Kohler Cimarron Comfort Height 2-Piece 1.6...
Black Kohler sink has scratches from washing my pots and pans. It is only 2 weeks old...how do I remove them?
Try getting a light rubbing compound and buff it out . Hopefully, you have scratched it too deep. I know this hurts when you scratched. No one likes to see there "new" sink messed up.
Nov 04, 2012 | Kohler Nice Cast Iron Kitchen Sink
How I just got a invicta stainless steel scuba pro diver quartz gmt watch and I can't size the bracelet band. It's way to big. It has screws on one side and a pin on the other side. I have arrows...
just try it with force placing an adhesive tape on top of it to prevent scratches. many adhesive tape the better to prevent scratches. i know you can do it now. good luck. i hope this will help you.
Aug 04, 2011 | Watches
Can I get a copy of the procedure to change the 02 sensor on a 2004 Lincoln Aviator?
You don't need a copy of anything
All O2 Sensors are in both ends of the
exhaust converters on lincolns
All you need is a 22mm or 7/8" wrench
You will be changing only the front (2) sensors,
the ones closest to the engine at 100,000 miles
or when they fail
Ideally the check light or wrench etc & codes
don't always mean to change something
Assuming you won't know or have what is necessary
to test them, just change the front 2
Get the OEM NGK or Bosch at NAPA
Once you pull the sensor ,you will see the brand on it
The new wires may be 5" longer,just coil & wire tie
I used an old scan tool with a scope on mine, as a VOM
Meter didn't give you switching time & the scope really
was a nice test. You will notice an instant pedal response
with new sensors,I did with the Lincoln LS
Check that the rear monitor O2 sensors are tight
They loosen from the heat or were never tight from
the assy line
Jun 25, 2011 | 2004 Lincoln Aviator
#3&4 cyl. Have spark and fuel but air idle screws don't do anything. When warming up backfired out exhaust and carbs
Check the valve lash-sounds like valves are tight in those cylinders. Idle air screws won't do anything if the valves are tight, the motor doesn't develop vacuum when the cylinder doesn't seal. And without vacuum, carbs don't work. If the valve lash is within specs, run a compression test, most "rockets" run a minimum PSI of 150 to be within spec. Good luck!
Jun 11, 2011 | Suzuki GV 1400 Cavalcade LXE Motorcycles
For the past 2 weeks, when I try to start my 2003 Nissan Xterra, it seems sluggish, but the engine will turn over. On 2 separate occasions, when attempting to start the engine, it wouldn't turn over ...
Checked Cables how?
Looking & Touching isn't doing anything
You have to do a voltage drop test or remove
& clean the ends. I would do both
Remove the starter & have it tested at parts store,
assuming you don't know how to do a voltage or
current test while cranking.
May 24, 2011 | 2003 Nissan Xterra
The toilet tank doesn't fill up properly. I have replaced the flap several times during the past 24 months. I have come to the conclusion that the whole flushing system has to be replaced with...
Kohler toliets can be a pain to repair. I have found with them that the only thing to do with them is go to a plumbing company, take the model number with you and replace all in the inner parts to it. You will replace the fill valve and flush valve. After I do this on Kohler I don't have anymore problems with them. It should work for you, just make sure they are Kohler parts. Good Luck
Tool Belt Diva
www.toolbelt-diva.com
May 16, 2011 | Kohler Toilet - One Piece with Ingenium...
CANNOT UNTIGHTEN EITHER TOILET SEAT SCREWS - SO TIGHT WILL STRIP WITH ANY MORE PRESSURE. STRAIGHT SLOT - . ON A LOW PROFILE KOHLER . THERE IS NOT ACCESS TO THE OTHER END OF SCREWS EVERYTHING IS...
screws can be accessed thru tank..take a hacksaw blade only n cut from above (careful not to scratch where can be seen)..nuts will fall in tank..will have to reach for them thru tank.
Nov 19, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Plumbing Logo
399 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
