Question about Dryers
The stacking kit for your model is availabe at the Frigidaire online asseccory store I got the kit for ours but I have not arrived at that point in our remodel, so I do not know how easy it is to install in this manner, but the kit looks simple enough. Good luck!
Posted on Jan 18, 2009
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
I have an Electrolux front load dryer Mo. # GLER331AS2 and the drum is no longer turning but the belt is in good condition. What could be the problem. The motor sounds like it is working when I use the...
Your belt may have slipped off of the idler pulley, or maybe the belt idler spring has come unhooked from the belt.
I will include a website that shows the belt configuation...
Please rate me
Dec 31, 2010 | Electrolux FEQ332ES Dryer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEQ332ES tumbles but does not heat up. Replaced the thermostat, did not solve the problem.
check ur breaker see if something is tripped dryer willl run on 120 but needs 240 to heat..
check ur element and also a thermal fuse, there might also be another thermosat that could be bad.
if gas check the ignitor, fuse, and thermostats
Feb 05, 2010 | Frigidaire FEQ332E Electric Dryer
Frigidaire FEQ332ES-It starts out ok, then trips the breaker, then no heat, continues to run but only blows cold air
sounds like your heat coil element is shorted, this coil is in the inside behind the drum..
replace coil and this will solve your problem, the coils break , you get no heat but voltage goes to heat elem that is shorted, trips breaker
Sep 16, 2009 | Frigidaire FEQ332E Electric Dryer
My Fridgidaire feq332es dryer has stopped heating in certain cycles. I read the thread about the control thermostat, I think I can change this myself do you have someone who can give me some direction on...
Have you checked your duct and vent for lint clogs? If you vent is obstructed, it will cause the unit to shut down the heat. Try removing the duct hose and examine for lint clogs. Be sure to look into where duct connects to your dryer. Then take a look at the wall vent, both inside and outside the house as well. You might try that before replacing the thermostat.
Jun 08, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Trying to trouble shoot problem with Frigidare stack top load was
There are 2 screws on the bottom/front of the cover to the washer. Remove the screws. Near the top/front of the cover is a seam; insert something flat in the seam (such as a screw driver blade, covered as to not scratch the finish)and pry the cover downward. This worked for me.
Jan 28, 2009 | Frigidaire GLET1031 Top Load Stacked...
Electric dryer FEQ332ES WOW, the control start switch doesn't work
Evidentally, this is a common problem for these dryers. I have found parts available for you to order and replace yourself if you would like and save from a hefty repair bill. The cost of a new switch is 24.74 before shipping. Depending on your location, 9 nationwide warehouses have them in stock in multiple quantities. If you would like further information, conatct me via e-mail at I'll be more than glad to help.
Apr 08, 2008 | Dryers
Washer thumper
The thumping could also be a belt issue if it has a flat spot in it, especially if its a Frigidare Hybrid GE. To get to the element, sorry to say it, but will have to remove the drum and front of machine to get to it. Ohm out all the thermostats and thermofuses first. If it has the round element behind the drum (which it should) check the heater wire for breaks. If its a true GE it will have two wires, Frigidare Hybrid will only have one. Good Luck!!! Jim
Sep 03, 2007 | GE WSM2420T Top Load Stacked Washer /...
Dryers Logo
273 people viewed this question
Top Dryers Experts
