Question about Archos 4GB Arnova 10BG3 10.1" WiFi Tablet with Android 4.0
Tablet is not charging
Brand new, I plug in the charger and it does not appear to be charging. Is there a specific way to charge this
The charger that arrived with the unit should fit and work as you'd expect. I would first try charging with another lead as this is likely to be the first item to go wrong. A lot of these devices come with a separate USB insert style plug. Again I would check this is not the cause of your issue. The more links in the cnnection chain the more opportunity there is for something not to function as it should. If you are able to check these things prior to going back to place of purchase you will save yourself time when they go through the fault finding exercise. There is an outside chance the pin configuration is slightly off so I would try to hold the connection in place to see if it begins to charge. There are occasions where the fitting is just slightly out and the lead is not being held in place maintaining the connection. I would suggest though not spending any money on trying these different options as your unlikely to get any money back from the manufacturer by way of compensation for the items you bought to test. I hope that all helps you.
Posted on Dec 30, 2012
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
Trouble charging a Digland 10.1" tablet
Did the charger that you are using come with the Tablets? Many 5 volt chargers can only output a 0.5 to 1amp current, while a Tablet typically needs 2 to 2.5 amps charging current. So, if you're using a charger from some other device, then it's almost certain that it cannot provide a sufficient current for the Tablet, and the charger overloads, shuts down cools off, turns on again, overloads again, shuts down etc repeatedly - giving the exact symptom you are reporting.
Even if the charger did come with the Tablet, some of the Chinese ones are of very poor quality and cannot provide reliable service. A replacement charger rated to suit your Tablet (there should be something in the specifications that came with the Tablet listing the requirements for the charger) should solve your problem {:o)
Jan 01, 2015 | Tablets & eReaders
Why won't my table charge?
Will the charger fit any other device that you have? If so try to charge some other device. It appears that there are only two possible problems. 1 The charger is bad.- 2 The tablet is bad.
Read your manual regarding charging and how long the first charge should take.
Aug 15, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
P5113 not charging properly
There are a couple of common problems that can cause bad charging:
  1. Bad charging cable - try a new cable
  2. Bad charger - try a new charger, or try plugging it into a PC USB port overnight with the PC turned on
  3. Charger is not the right charger for your tablet - Samsung devices are known for being picky about what charger you use. If you don't use the original charger that came with the device, or a Samsung charger made for your specific tablet, you will have trouble.
  4. A bad/broken charging port on the tablet - this is not something you can fix yourself. You would likely have to return it to Samsung for repair, or find a local repair shop.
Jan 07, 2014 | Samsung Galaxy Tab 2
Visual Land Prestige won't charge
take the tablet to a store that sells charger , ask if you can test it before you buy it
Nov 22, 2013 | Visual Land Connect 7" Tablet
Nabi will not charge .have new charger
Whenever you plug in your Nabi 2 tablet to charge, The tablet will boot up. Whenever tablet boots up, turn it off and leave it charging for a good 4 to 6 hours. That should charge it.
Aug 12, 2013 | Nabi 2
My pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Aug 05, 2013 | Tablets & eReaders
My satelite r15-s829 tablet laptop battery went aprox 10 days without a charge while shut off. Saturday I received a new ac adaptor, upon plugging it into the laptop an amber light in plug in icon on the...
This appears to be a problem with the ac charger its saying that ur charger is underpowered and cannot charge ur laptop take a look at ur older charger and buy the same brand and that should help out its a common problem that pops up for some that replace failed chargers
Dec 15, 2008 | Toshiba Computers & Internet
Archos 4GB Arnova 10BG3 10.1" WiFi Tablet with Android 4.0 Logo
532 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
