Question about Hitachi Computers & Internet
No audio how do you hook up speakers - Hitachi Computers & Internet
How do i get the external audio output to work?
First make sure that your TV has an audio OUT. Most do not. If you do then you can plug into that but you will have to go into the menu on the TV under audio and turn on the external speaker feature. If you do not have an audio OUT then you will have to hook you speaker to the audio OUT of your home stereo system and hook the source output to the input of your stereo. Source being (dvd, cable box). In that case you need to turn off the internal speakers on the TV and just run it through your home stereo system.
Mar 07, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
Need to know how to hook tv up to prewired home surround system. connections on wall, seakers inceiling
Run the audio output from the tv rca audio output, to any input of receiver and hook your speakers to receiver. You cannot hook up speakers to tv cause its a low level audio output. Needs to be amplified.
Nov 15, 2011 | Televison & Video
I have a 42" plasma
The Logitech speakers z506 manual would explain what it needs for a source. RCA Audio outputs can be adapted to 3.5mm.
http://www.logitech.com/en-us/439/7191
Jul 17, 2011 | Panasonic Audio Players & Recorders
How do I hook up my logitech speekers
If you're running a tower, you jack it into the speaker or audio output on the back of the unit. If you're using a laptop, you run the speakers by plugging the 1/4" stereo plug into the headphone/audio output jack on the front or side of the computer.
You have to make sure you're hooking up the input to the Logitech speakers- refer to your manual for details, or read the fine markings on the speaker power supply and audio input jacks.
Good luck, and hope this helps.
Oct 21, 2010 | Office Equipment & Supplies
When plugged into my tv they are not very loud, why please
Probably because your TV does not have a built in speaker amplifier. You'll need to hook up a small amplifier to your speakers. Hook up audio cables to the TV AUDIO OUTPUT and then to the INPUT of the amplifier. Hook the speakers up to the AUDIO OUT or SPEAKERS OUT on the amplifier. Probaly have to take a trip to a place like Radio Shack to get the correct cables.... Good Luck.
Nov 22, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Everything works the speakers are hooked up i just
connect one speaker at a time .If one speaker or speaker wire is bad it will cause all audio to mute.connect one speaker at a time
Jul 30, 2009 | Pioneer DEH-P3500 CD Player
How do i hook up speakers to my lcd?
go to Radio Shack or whoever is closest for audio cables, ask for a mini-stereo jack to RCA male jack, it should look like a Y with the stereo mini female jack on one end and two (one red one black or white) old style speaker jacks. These should take care of the audio situation. It might be better to consider adding a tuner or media center to help direct the sound.
Jun 22, 2009 | Bose Companion 2 Computer Speakers
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
Want to add an external speaker to TV
If you have audio out RCA jacks then you can hook up some computer speakers that have RCA jack inputs. If you don't have audio outputs and your TV has a HOT chassis then you won't be able to do it. If your tv has a switching power supply then you can install a jack to TV speakers, so they disconect when you hook up your other speakers, if you try and hook up speaker to the TV speakers then the impedence will change, and your audio output IC will get hot and short out.
Oct 26, 2008 | Televison & Video
Computers & Internet Logo
18 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
