Question about Foxconn K7S741GXMG-6L S.462 Motherboard
Motherboard wont do anything
I installed this board into my pc and it turns on but it wont kick the monitor on at all it gives no beeps for errors but im baffled i dont see a mainboard speaker either so i hooked up a speaker and still nothing help please
  • 5,660 Answers
A) FOLLOWING Anti-Static Precautions?
If you, or someone who had the board before you didn't, you can use it for a Frisbee now.
(WOW! Look at that thing GO!)
B) Processor installed with Heatsink, and fan hooked up; and Ram Memory installed -> ONLY; you should get BIOS Beep Codes, and maybe Error Codes; plus the BIOS Setup screen.
(Hooked to VGA monitor. No AGP graphics card used)
No?
Frisbee
C) Look at the Electrolytic Capacitors on the motherboard.
(Radial Aluminum Electrolytic Capacitors to be exact)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1284612
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://en.wikipedia.org/wiki/Capacitor_plague
Can they be replaced?
Yes, the Capacitor Plague has been around for a LONG time, and is still affecting us today.
Need guidance in replacing? Post back in a Comment.
http://www.youtube.com/watch?v=YCSNWi3UHf4
http://www.hardwaresecrets.com/article/595
http://www.hardwaresecrets.com/article/616
http://www.mouser.com/Passive-Components/Aluminum-Electrolytic-Capacitors/_/N-75hqt?Keyword=Electrolytic+Capacitors&FS=True
You click IN the fields needed.
Leave alone;
1) Manufacturer: The one's presented are of Excellent quality.
2) Tolerance:
3) Product: The capacitor examples that will be shown, ARE of computer grade quality.
4) Operating Temperature Range:
Fields you NEED are the values of the capacitor, and style;
1) Capacitance: Look for -> uf ratings. uf = Microfarad
Capacitors on a personal computer's motherboard; are rated in Microfarads, ( uF), NOT Picofarads. (pF)
2) Voltage
3) Termination Style: -> Radial.
BOTH leads come out of the bottom,
http://en.wikipedia.org/wiki/Electrolytic_capacitor
(Click on the second photo down on the right)
When you have clicked in each field, and clicked on the values, and style; then go to the left, or right side; underneath, and click on -
Apply Filters.
Let's use a 4.7uF / 16 Volt / Radial electrolytic capacitor for an example,
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/_/N-75hqt?P=1z0wrjcZ1z0x565Z1z0z7l5&Keyword=Electrolytic+Capacitors&FS=True
Scroll down.
Look under -> Dimensions - to get the physical size you need.
D) Power Supply:
Whip out your multimeter, and with the Function knob set to DC Voltage, check the 3 main voltage power rails.
(If just a symbol, the symbol is a dotted line over a solid line)
Check at the 20-pin ATX main power cable connector.
I use a straightened out paperclip, and insert down into the back of the 20-pin ATX main power cable's connector.
The BACK is where the wires go in.
The straightened out paperclip is inserted down into the socket hole, in the Back of the connector; and slides past the insulation of that wire. It MUST touch a metal terminal at the end of the wire.
Every wire going down into that ATX main power cable's connector; ends in a female Molex metal terminal.
Orange wires are 3.3 Volts.
Red wires are 5 Volts.
Yellow wires are 12 Volts.
Black wires are Ground wires.
ALL Orange wires end in ONE central pint in the Power Supply.
This is the 3.3 Volt power rail.
You can test ANY Orange wire, and test the entire 3.3 Volt power rail.
Same with the Red 5 Volt wires, and Yellow 12 Volt wires.
Pick one to test.
Paperclip in Positive socket hole, in 20-pin ATX main power cable's connector.
Plus paperclip in ANY Black wire socket hole.
3.3 Volt, 5 Volt, and 12 Volt wires are POSITIVE wires.
Positive (Red) probe lead of multimeter touches Orange, OR Red, Or Yellow wire - paperclip.
Negative (Black) probe lead of multimeter touches Black wire paperclip.
Worried about shock?
Naa.
The dangerous voltage is contained in the case of the Power Supply.
100 to 240 Volts AC.
The Power Supply converts this AC voltage into the low DC Voltages stated above.
In comparison two D cell flashlight batteries produce 3 Volts DC.
NOT saying there may not be a spark!
Connect a wire to a flashlight battery, and touch it to the bulb, and there is gonna be a spark. Just the way electricity works.
This is why I suggest for those who are new at this; to have the Power Supply unplugged from power; and insert two straightened out paperclips, in the socket holes of the ATX main power cable's connector.
Then (Making sure they don't touch each other), plug the Power Supply into power, and touch the paperclips with the probe leads of the multimeter.
Tested 3.3 Volt power rail? (Orange wire)
Then unplug the Power Supply from power, and move the paperclip over to a Red wire socket hole.
Test for 5 Volts.
Same again for the 12 Volt power rail. (Yellow wire)
Or use a KNOWN to be good, Compatible power supply; for a test unit. Perhaps there is a working computer you can borrow one from.
For additional questions please post in a Comment.
Regards,
joecoolvette
[Are you sure the Ram Memory is plugged in tightly? CANNOT just visually inspect. Remove, and reinstall to be SURE.
Are you sure the Ram Memory is the correct Frequency Rate?
('Speed')
Ram Memory typically operates at HALF of the Processor's Front Side Bus. (FSB) ]
Posted on Jan 01, 2013
4 Suggested Answers
naveen_gvvsn
  • 9 Answers
SOURCE: New "Foxconn G9657MA-8KS2H Motherboard" but nothing on monitor
You said that the old motherboard has burned so that you bought this mother board. i have a doubt that the old motherboard was running on smps which is insufficient for this one.
one of the main reasons that the motherboard doesn't start when the rated powersupply is not used.
please post your total configuration including the power supply to check the problem
Posted on Apr 19, 2009
  • 117 Answers
SOURCE: I have p4m890-8207 motherboard. my pc not install
Hello cbozkurt54,
I think I understand. Please follow this link to obtain the correct drivers.
http://www.viaarena.com/Drivers.aspx
Posted on Jul 12, 2009
dkammeyer79
  • 92 Answers
SOURCE: I have foxconn 865G7MF with
It's possible that the video processor has been damaged from ESD (electro Static Discharge) from the connecting and reconnecting while it was turned on. The first thing I would try is installing an expansion video card (like a PCI or AGP one) to see if that works. If it does, that was the issue
Posted on Feb 28, 2011
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the...
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
Jun 18, 2011 | Compaq AlphaStation XP1000 PC Desktop
I have an AOpen vKM400Am-S Motherboard, when i turn it on a red light and cpu fan turns on but no video to my monitor,i checked if my video card works on a difrent pc and it did, my pc wont turn on
this caused by RAM error, open your computer, disconnect ram, turn on your computer?is computer beeping, 1 long and 2 short beep??if yes the problem is come from your ram, clean your ram connection then connect ram to mother board, turn on your computer, is the video come to screen??if no, try to connect another ram to your computer, for sure use new ram
i hope this helpful
thank you for using fixya
Feb 05, 2011 | AOpen MX4LR (91.89Y10.002) Motherboard
When I turn on my pc monitor goes blank and computer starts beeping. As long as it's turn on it continue to beep. These are short often beeps
the beeps indicate a cpu or memory error. it would help to know what mb you have and if you replaced anything recently
Jan 29, 2011 | Computers & Internet
THE BIOSTAR G31-M7 TE MOTHERBOARD WONT START UP.IT COMES ON BUT WONT POST OR SHOW ANYTHING ON MONITOR
Good day sir, hi. you need these 7 things to make your pc start, make sure they are good.
first unplug your pc. open the side panel to access the motherboard. Remove all connections to the motherboard.
  1. Remove and check the memory module, make sure that the memory terminals are clean, you can use an eraser to clean the contacts. much better if you have new ones. or test the memory modules on another PC to confirm that they are good, then snap it in place, you should hear clicks as you place it on the slot.
  2. Clean the memory slot with a clean paint brush, there should be no foreign objects inside the slots, visual inspection is necessary.
  3. make sure you PS is good. Plug in the 20/24 pin connector and the 4 pin 12v connector firmly.
  4. Make sure that the processor is installed properly. the fan is connected on the fan power port.
  5. connect the monitor to the vga slot, (or if you have graphics card)
  6. connect a keyboard,
  7. and a pc speaker (or the thumb speaker)
Power on your PC.
monitor your PC speaker.
You should hear a beep, (good) one long and 2 or 3 short beeps, problem with the display card, continuous beeps, system board cannot detect memory.
monitor your keyboard.
You should see 3 sets of led light, numlock+caps lock+scroll lock, and a few seconds, 1 led light, the num lock only.
Dec 14, 2009 | Biostar G31-M7 TE Motherboard
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
ASUS M2N68-LA Motherboard beeps
The short then long beep error is indicative of a RAM memory issue. I had the same problem and had to use a process of elimination to determine the bad RAM. Place a RAM stick in slot 1 one at a time. The RAM stick(s) that give the short-long beep error are bad. If all RAM gives you the error it is more likely you have a bad board
Sep 03, 2008 | Computers & Internet
Boot
Do any lights turn on when you power it on? Can you here the fans spinning and hard disk working?
Sep 14, 2007 | Computers & Internet
No beeping, no video displayed.
hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Jun 30, 2007 | Abit LG-95Z Motherboard
SOLTEK SL-65K2-CT Motherboard
The beep pattern is a beep code and is how the motherboard communicates errors during the early booting process otherwise known as the POST (Power On Self-Test). List restart the computer and listen for the pattern of short and long beeps. Soltek does not list the beep codes in their manual, instead they refer to Phoenix who manufacturers the AwardBIOS on your motherboard. There are only two POST beep codes; a single long beep followed by two short beeps (Video error) and anything else. Apparently anything else you hear *probably* refers to RAM problems. Since you?ve already tested both one of the remaining options is to install a *POST* card (about $30 to $50), boot the PC and read the hexadecimal error code for a more detailed clue to what failed. If you ask around you might find someone who has one and may be willing to loan it to you. Another option is to write off the motherboard since the cost of the test equipment it about 1/3 the cost of a new board. Let us know if you have any other questions and please don?t forget to rate the posing.
Jan 06, 2007 | Soltek SL-65KV2-T Motherboard
Foxconn K7S741GXMG-6L S.462 Motherboard Logo
65 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
