Question about Panasonic DVD-S35 DVD Player
Fault code HO5
The DVD player will no longer read the dics
Make panasonic
model DVD S 35
Remote # EUR 7621020
SOURCE: Fault code F498 on panasonic
as far as i understand, it is caused by dry joints - poor workmanship. Try taking the top off and pressing down on right-hand side the green circuit board with the dvd in standby. Then switch on. If that works then what i did was to take all the screws out and jiggle it then put all screws back except the one to the left of the board, next to the brown board. seems to work now. Tip found on another forum, no credit to me
Posted on Jun 12, 2008
Benimur
  • 6966 Answers
SOURCE: Panasonic Portable dvd/cd player model
Two possibilities:
  • the laser eye (lens) is dirty, weak or defective. The unit no longer can sense that a disc is present and therefore will not initiate servo motor engagement. Pls try cleaning;
  • the spindle motor is weak or defective. This might be of additional information.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 30, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
SOURCE: Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Posted on Mar 13, 2009
SOURCE: fox remote code for panasonic dmr-e55 dvd.have fox
Code nokia 9200
Posted on Jun 27, 2011
Can anyone tell me how to step by step take apart Panasonic DVD-S25 to get to the motor to get the ho7 to popping up the dvd will play thru then stop spinning which wont read dics anymore
hi there it could b a fault in the cpu ..if it is its not worth fixing...have a look on e/bay u can buy them for $10 to $20 dollars working good luck.........
Sep 18, 2015 | Panasonic Televison & Video
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
I have a Panasonic DVD-35 player. Lost the remote. Have programmed my Comcast remote to work and it does. Problem I have is I need to get to the SETUP screen to make an audio change. Cannot get to screen....
hi,
u didn't mentioned the model of comcast remote.if it is DVR 3 device then you can control panasonic dvd through it. the programming code is 20490
if its comcast DVR 3 divice univeral remote control then try these code 0490,0632,1490,1907
ok
Jan 05, 2011 | Panasonic DVD-S35 DVD Player
Dvd player wont read displays H2O panasonic 2001 model
try cleaning the scanner eye with the cleaner disk
Jun 16, 2009 | Panasonic DVD-RV31 DVD Player
Compatibility of remote with DVD recorder?
If it doesn´t say Panasonic on the remote, you have what´s called a universal remote. It has to be programmed for your Panasonic DVD. I hope you got the instructions with it. If not, use the record button on the machine and try getting Panasonic´s own remote or another programmable one with instructions.
Feb 10, 2009 | Panasonic DMR-ES10 DVD Recorder
Philips 622 Universal Remote Code
I have an original remote control available @ EUR. 10.= + postage.
Comes from a working set, but the player will only read CD's, not DVDs.
Other parts upon request.
Mail interest to evert @ ismijnnaam dot nl
Dec 30, 2008 | Philips DVD622 DVD Player
Model D8B-M1000ZB
I read the specs and::DVD Region: 2 (UK/EUR) means that the machine was made for UK\EUR and to the best of my knowledge cannot be hacked to Region: 1 (US)
Aug 01, 2008 | Funai PY90VG DVD Player/VCR
Panasonic DVD recorder DMRES46V
Hi, sometimes if the disc is not completely flat in the tray, I get the same problem. Pretty low tech, but sometimes works!
JMM
Mar 26, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Can no longer read DVD
I PUT IN A NEW MEMOREX OPTI DIC CLEANER AND ALL I GET IS CANT READ DVD UNABLE TO READ DISK,CAN YOU PLEASE HELP.
Dec 10, 2007 | Samsung DVD-V3500 DVD Player/VCR
Panasonic DVD-S35 DVD Player Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
