I have an American Standard heat pump. My heat strips are automatically turning on immediately when the heat pump starts. It heats the house up very quickly, but with the strips turning on immediately it is defeating the purpose of the heat pump. My electrical meter runs very very fast as soon as the heat pump turns on. I know this is not how the heat pump is supposed to operate. I am using a lot more electricity than I should be using. Can you tell me how to solve this? Can I adjust something on the thermostat myself? Thanks.
3 Suggested Answers
mastatech
  • 478 Answers
SOURCE: Heat pump cycling on and off.
It sounds as if you you have a low charge of refrigerant, r22. When the unit comes on outside, the outdoor coils become the lowside, there is a low pressure switch that is tripping out contactor protecting the compressor.
Posted on Mar 11, 2009
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Posted on Mar 26, 2009
Heat works until thermostat calls for aux heat, then blower shuts off with outside unit still running.
Some blowers shut off depending on the system. Do you have electric hest strips inside? If not the blower will shut off. The outdoor fan should not be running if in defrost mode. If you have heat strips then you likely have low voltage wiring crossed
Dec 16, 2016 | American Standard Heating & Cooling
American standard heat pump will only work on emergency heat with fan turned on not auto but only works a little while then quits i can turn it off for about 20 min. and back on emergency heat with fan on...
How old is the unit? Heat pumps don't work when it's real cold, you know it's limits. If it's not real cold outside, then it may be low on gas or such and need a service call.
Nov 26, 2013 | American Standard Heating & Cooling
Heat Pump
That is normal. Secondary heat is not needed unless it is very cold outside. If the heat pump can't keep the house warm enough and the temps start to drop, the secondary heat kicks in. 2 degrees is normal.
Aug 18, 2012 | American Standard 5000 Heat Pump Unit
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
I have a small house with a outside package unit American standard (Trane) Model# WCM030F100BB, italso says BAYHTRN110A. When I select cold from the off position on the thermostat it immediately pops the...
I would check the outdoor unit, Trane uses "Sump Heaters" on their compressors
and when one fails it will blow fuses at the disconnect or trip breakers.
The sump heater is a small metal pencil sized item at the bottom of the compressor
with something that looks like lamp cord going to it. Also when the start capacitor
fails it will exhibit this symptom. Look at the can shaped items inside the cover
If they are leaking, or bulged this may also be the problem.
(with the breakers off to everything including the inside unit to prevent shorting
the transformer)
These are the most common problems and the parts are less than 20 dollars each.
I service 155 trane units at my properties.
hope this helps.
Mar 19, 2011 | American Standard Heating & Cooling
The heat pump stays on to 20 deg (outdoors) and the burners will not work till the temp is under that leaving the house at a max 65 deg, I beleave the heat pump should true off around 30 -35 deg ? then the...
Remove the cover of the circuit board and controls on the outside unit. Some units have a thermostat that allows you to set the temperature at which it switches to the second stage of heat. Set that for about 34 degrees.
Jan 02, 2011 | Heating & Cooling
Every time my heat pump turns on, the blue auxilliary light comes on, and it only blows icy air. I do not want to use that much power, so I turn it back down a few degrees. Now, it is 50 degrees in the...
A heat pump starts losing efficiency below 30F or so. The aux. heat helps the heat pump keep up with heat demand. The Aux heat can be electric heat strips or another type of heat. Check to make sure you have power to whatever type of aux heat you have (breaker not tripped, no overloads tripped). If it is electric heat check the heat strips to make sure they haven't burnt in to. Hope this helps.
Jan 10, 2010 | Amana PTH123B25AJ Heat Pump Air...
After RTH6400 installation heat strip is no longer actuated
http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/Do-It-Yourself/Programmable/5-1-1/Default.htm look at the very last part of thius page and you will see that the particular thermostat does not work for heat pumps tha have auxillary heat. Sorry for being the bearer of bad news but you need to upgrade the selection to make it work right.
Jan 24, 2009 | Honeywell Electronic Programmable...
Heat pump trips circuit breaker
I seem to have the same problem. But when I reset the breakers, they won't stay in the on position. They go back to the off position. What gives? It is 95F inside the house.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
