Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Wring for trolling motor
I bought a 24 volt trolling.My boat is wired only for a 12 volt.How should I run the wiring to two batteries
  • 10,865 Answers
Just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
Posted on Jan 18, 2009
My motor guide trolling motor died . It was on the new boat that I bought in 2011 . Checked the breaker fuse and it's good, tested the wiring with a volt meter couldn't find anything. Could it be the micro...
do you have it hard wired to pos and neg or does it have the 3 prong plug in switch ..if 3 prong its for a 24/36 volt motor wont work on 12 volt less you have the 12 volt plug
Oct 16, 2013 | Boating
Great white trolling motor,bow mount,24 volt, 82lb thrust / big problems! Burned up Marinco plug,replaced plug,recetacle,fuses on. batteries, tech says motor runs fine on bench,but not on boat. Getting 24...
The heat is developed from to much resistance from batteries to TM, check for loose/corroded connections at batteries, including the jumperwire, also check the size of wire from battery to plug, should be at least 8 gauge if not 6 gauge depending on the length of run. If corrosion has built up inside the wires this will also cause high resistance causing excessive heat build up. I would prolly just replace boat wiring to make sure none of the above problems are present. Use tinned copper marine grade wire that is multi stranded.
Mar 08, 2012 | Boating
24 volt trolling motor (motorguide) not working. Have 24 volts at receptacle in hull of boat but when I plug in the trolling motor and check the volts on the plug, I only read 6 volts. Any idea whats...
You have a high resistance short either inside the wiring or the lower unit. This will cause a voltage drop. I would be very careful not to keep it connected too long cuz the battery is trying to keep up with the current demand and may explode.
Oct 03, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
24 volt trolling motor wiring
Just like a flashlight. Positive to neg, In a loop going to the motor. That is the jump between the batteries, One red wire coming in from motor, it will go to pos, from one battery, the neg will go to the 2nd battery pos. From the 2nd battery neg will go to the motor. That is it, one jumper connecting the 2 batteries, will create the 24 volts. Hope this helps.
Mar 22, 2010 | Boating
Wanting to install motorguide 24v trolling motor in boat, will it work on just 12 v system
No. you can put in extra batteries and use it, but you must remove you charging system from them to use it that way. Not really practical.
Mar 21, 2010 | Electrical Supplies
I bought a used trolling motor (motorguide brute 750 50# thrust) it has a 12-24 volt selector switch and three wires to hook up to battery, a black, a white, and a red. i'm assuming on 12v setting of...
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
Mar 15, 2010 | MotorGuide Electrical Supplies
My 12/24 volt trolling motor only runs on 12 volts
Did you connect 2 batteries to try the 24 volt version? You have to link them together like a flashlight, positive to neg and then out the other side, for 24 volts, like a golf car.
Feb 23, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a minn kota 48 AT 12/24 volt bow mount that I run on a two battery 24 volt setup. The trolling motor is on a 3 prong plug into a panel at the front of my boat. That panel has an on/off/on toggle...
use a volt meter and check for voltage at the plug, if none..check in the back near your batterys and locate the circuit breaker and reset it ...basic system = battery-breaker-wires....hope this helps ....GL
Jul 05, 2009 | Boating
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
Oct 20, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
805 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
