Question about Stiebel Eltron TEMPRA 24 Tankless Water Heater
Shower is hot- bathtub is not- tempra tankless hot water heater
Hot water is not a problem anywhere but my bathtub- the shower is hot. my other bathroom, the bathtub is hot and the shower is hot. Thoughts?
  • Stiebel Eltron Master
  • 5,245 Answers
1) Test for crossover:
http://waterheatertimer.org/Crossover.html
2) Add a comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Dec 30, 2012
  • 308 Answers
SOURCE: hot water tap only warm water in bathroom but hot in kitchen
Usually when you are having a problem at only one fixture, and not any others it is a sign that you have a faulty fixture. Hope this helps.
Posted on Jul 16, 2009
SOURCE: tempra 12 the when you
I am a free answerer, and I specialize in giving you resources for free.
The paid answerers may have a person who knows your product and the problems associated with your model.
I only see the questions where people have not paid.
Each day I see 20-25 unanswered questions about tankless water heaters.
And the day before, the same number of unanswered questions about tankless products.
The number of questions shows the complexity of the machines, and the inability of the manufactures to take care of their customers.
The manufacturer will refer you to the installer.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
There are not many ways a do-it-yourselfer can fix a tankless.
In contrast with tankless, tank-type water heaters have generic troubleshoot steps that lead to a quick diagnosis, and same-day repair of almost any brand. Most times a tank-type heater repair can be DIY.
Posted on Oct 31, 2010
packrat1948
  • 528 Answers
SOURCE: Specifications sheet for Stiebel Eltron Tempra 24
hope this is what you need.
http://www.stiebel-eltron-usa.com/techdata_tempranew.html
http://www.stiebel-eltron-usa.com/pdf/install_tempra_tempraplus.pdf
Posted on Feb 04, 2011
kel1guy2002
  • 3740 Answers
SOURCE: I installed a dhc tankless heater, but when I open
Hi and welcome to FixYa, I am Kelly.
What is happening is that your cold water flow is greater in volume (gals per min) than your hot water. So when you open the cold water it is mixing with the hot water inside the faucett or shower plumbing and actually reverse flowing back into the hot water heater plumbing. The reverse flow slows the water flow sensing turbine inside the heater and it is thinking that there is not any water flow. (There isn't actually due to the equalization of water pressure when you open the cold water faucett) Since this is a safety feature of the tankless heater to keep it from overheating, it shuts off.
Somewhere in the hot water plumbing there is a major restriction. It may very well be the internal plumbing of the tankless hot water heater or the flow detector design.
There are 2 ways to correct this. The easy way would be to restrict the available cold water flow. You can do this by installing another shut off valve inline with the cold water plumbing and just not open the valve all the way. You would have to adjust the setting so that the hot and cold water can be on at the same time and the hot water heater stays on. The hard way is to locate the hot water flow restriction and eliminate it.
It is possible.... if you have a flow restrictor in a shower head or a screen in a faucett areator that they are partially clogged. Clean any flow restrictors and screens then see how the hot water heater performs before you start modifying plumbing.
Thanks for choosing FixYa,
Kelly
Posted on Apr 10, 2011
heatman101
  • 43501 Answers
SOURCE: my tempra20 plus will only deliver 90egree water
Is this a new install? Or is it an existing heater that all of a sudden went cool?
If it is new, then the water flow is too much and you need to cutback on the amount of water that can flow through...
If it is an existing install then a heating element has gone bad...
heatman101
Posted on Aug 16, 2011
Tempra 24 installation. No hot water. No power led on fron cover. Is the led supposed to be on all the time or just when water is ran?
First, check the circuit breaker. Also, did you upgrade to heavier wiring and a double 60 circuit breaker when you had this installed?
Aug 15, 2014 | Stiebel Eltron TEMPRA 24 Tankless Water...
Should the red lights be flashing or be on steady
A solid light is what you actually want.
If you have a blinking light, the unit is unable to keep up with the flow of water.
Slowly turn on the hot water for your bathtub until the light starts to blink to find your limit. in other words your tankless heater is too small for your needs.
The 24 model is more for houses with showers or slower flow.
The 36 or higher model has 3 sets of heaters to be used with a bath, higher flow.
Jan 20, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
No warm water at the tap
What kind of water heater do you have?
Gas or electric, tank or tankless or solar or condensing or hybrid etc
If the water hot at the water heater?
If water is hot at water heater, then you might have plumbing problem like crossover.
Add a comment for possible troubleshoot.
Copy following link for tank-type electric troubleshoot.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Copy following link for tank-type gas water heater:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Aug 18, 2012 | Stiebel Eltron TEMPRA 24 Tankless Water...
I have a recently installed richmond water heater. When the shower is running and someone turns the faucet on in the kitchen the water gets drastically colder in the shower. We didnt have that problem with...
Which type Richmond water heater?
Is this a tankless water heater or tank-type?
Tankless are notorious for 'cold water sandwich' under exact conditions you describe. You might need tankless with larger BTU burner.
Don't install a tankless.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If you have tank-type water heater, then I suspect a clog in the hot water line, or single-handle faucet cartridge in show is going bad.
Same problems can contribute to tankless problems.
http://waterheatertimer.org/Low-hot-water-pressure.html
Aug 06, 2012 | Rheem Richmond
My shower is not hot enough unless I turn the cold water on in the tub at the same time
You might have a plumbing problem.
1) Faulty check valve
2) Crossover at single handle faucet
Read: http://waterheatertimer.org/pdf/No-Error-Code.pdf
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 31, 2011 | Stiebel Eltron TEMPRA 24 Tankless Water...
Tempra 12 the when you turn off the water the heating unit does not turn off then it gets hot and pop the reset
Oct 31, 2010 | Stiebel Eltron TEMPRA 24 Tankless Water...
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Stiebel Eltron TEMPRA 24 Tankless Water Heater Logo
208 people viewed this question
Top Stiebel Eltron Water Heaters Experts
chargerhp
chargerhp
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
