Question about GE Profile JS968 Electric Kitchen Range
Ge profile electric range f0
Buttons on touchpad initial work except 0 9 4 and 5. These buttons never work. Can set bake and it goes to 115 and shuts itself off. Then none of the buttons work. After 5-10 minutes it starts beeping and there is a F0 code. We ave already replaced the touchpad ( a few days ago) but no luck. Orange sticker on ERC mentions resetting something when you remove the touchpad. Could this be the problem? Any help will be appreciated.
    Top Expert:
  • GE Master
  • 79,865 Answers
You need to replace the control panel.
Posted on Jul 09, 2017
3 Suggested Answers
leedavidian
  • 1420 Answers
SOURCE: The range recently began to
Test
Posted on Nov 19, 2010
reyjoshua07
  • 1157 Answers
SOURCE: GE Profile electric range: I'm getting an F0
Hi greengib,
The Failure code "F0" description is a stuck touchpad. Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 20, 2011
GE Range JSP68 shuts off while preheating
I have an aging JSP68. First, take out the range control (held in by just a couple of screws, disect it, clean it the best you can, dry it. Be careful not to break it because there is no replacement. Pay special attention to the membrane buttons. They tend to stick. Realize the broiler element turns on sporadically to reach the set temp quickly, the bake element should be solid on. Check the "header" (the long double strip of pins) connecting the range control. I had to resolder mine. Another insult was that I baked a bread recipe that required you put water in the oven to generate steam. The steam made this oven literally go bonkers. The relays started to chatter and just a half minute of this will destroy them. Also when you press bake keep it pressed for a few seconds while adjusting the temp to 170 then release. If you don't hear the bake relay click on, try again. Another thing you could try is to press all of the buttons once, this should help to unstick them if any are stuck.
Aug 07, 2013 | GE Profile JTP18 Electric Single Oven
GE Spectra control panel buttons not working
Most likely control is bad and will have to be replaced
Aug 30, 2017 | GE Profile Spectra JBP95 Electric Kitchen...
I keep getting FO code and beeping won't clear
Hello George,
The F0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
Oct 05, 2011 | GE Profile JKP56 Electric Double Oven
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
Displays F0 code, none of the buttons work and beeps continually until power is turned off.
The F0 error code can be different depending on the brand and model range you have. The most common cause for this error is a shorted or stuck touchpad. This web site http://www.repairclinic.com/0078.asp has a listing of the error codes for many different manufacturers. Go to this website and find the manufacturer of your range and see what the F0 code is. If it is a stuck or shorted keypad error you could try disconnected the touchpad connector to the ERC for about a minute and see if that clears it up. This would require you to dis-assemble the back panel of the range and unplug the power before doing any service to the range. You could also check the touchpad buttons and see if any are stuck.
Mar 10, 2010 | Kenmore Kitchen Ranges
My ge profile range will not operate loc appears when you try to put it on bake
Hold the 9 & 0 down together till the loc on goes to loc off. About 5 secs.
Jan 27, 2010 | GE Profile 30" Self-Cleaning Slide-In...
Buttons/timer don't make sound
Unplug the range.
Remove the control panel to access the touchpad and electronic control.
Remove the touchpad ribbon from the control inspect for and clean any corrosion and reinsert it.
If this fails, replace the touchpad.
Feb 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Dec 02, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Buttons on Control Panel not working for my GE Profile Gas Range
Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
Thanks
Mar 14, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile JS968 Electric Kitchen Range Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
