Question about GE Profile WPRE6150KWT Colossal Capacity Washer
Ge wpre6150kwt wont start
Cycle lights come on if you move the estimated time dials but nothing happens when you push the start button, I have unplugged the unit and plugged it back up in an effort to reset, but nothing happens when I press start, no humm, no nothing,
  • 1294 Answers
SOURCE: CONTROL LOCK and Can't start the GE front load washer - WSSH300GWW
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on May 30, 2008
SOURCE: GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
Most likley it's the drain pump! check the wiing and pump
Posted on Jul 09, 2008
  • 130 Answers
SOURCE: Broken knob on GE washer
There are four separate parts that make up the knob dial. You can pull off the knob if you use a screwdriver/pliers to remove the clip holding it on. Check if the mounting areas appear stripped or broken. There should also be a compression ring in the mounting hole on the back of the knob. That's what may be broken or stripped. These are all parts that you can get from a local parts store (check the phone book) and you can do it yourself. Any of those parts should cost less than $10. The bad news is if you stripped the pole coming out of the timer assembly. You would need to replace the entire assembly which costs about $130. If you call a GE repairman, you are looking at $89.95 or more just to have them show up. If it is still under warranty, there is no charge. You can call them to verify this:
1-866-383-3933
Posted on May 03, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
SOURCE: ge front load wcvh6600.
take the bottom panel off three screws and put your hand up where the door is located feeling blindly for a plastic latch....pull the latch to manually unlock door..... then with the door open unplug washer and wait 10 minutes...even if you have done this before this is different b/c the door will be open....still open plug back up and turn on..if the display comes on its the door lock...about $94.00 if no display its the panel board and that'a about $ 200.00...hope this helps too
Posted on May 29, 2010
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
Maytag dryer waont start when you push start button
Try opening and closing the door a few times it might be the door interlock switch, Are your plugs fused like in the UK. If so check fuse, or there will be a safety fuse inside the dryer which has blown in which case it will have to be examined by a qualified repairer.
Nov 13, 2011 | Maytag Performa PAV3200
All the lights light up, but washer won't fill when I push the start button. It is barely 3 years old. This happened before and then after I left it a while, when I pushed start it filled. I tried...
Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. You may need to do it several times before it resets. After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.
GE Hydrowave notes
Feb 10, 2011 | GE WWSE5240G
I just bought a GE 24 hour mechanical time # 15152. How do set it? The dial is very confusing. I understand that I must first pull all the buttons up and push down the ones I need. If I set it to go...
GE 15152
http://waterheatertimer.org/GE-timers-and-manuals.html#15152
Light side of dial is am hours
Dark side is pm hours
Set timer ON from 5pm to 11 pm:
When segments are down, timer is ON.
Lift all segments, except segments between 5 and 11.
Rotate dial until current time lines up with arrowhead located on inner dial.
Move switch to TIMER ON
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Washer stopped after wash cycle
The lid switch is the culprit. Push down on the lid it should start. It needs to be adjusted . the tab on the lid is not activating the switch. Try triming the door bumpers.
Apr 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Profile WPRE6150KWT Colossal Capacity Washer Logo
32 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
