Question about Brother XL-5130 Mechanical Sewing Machine
Two Stitch Hang-up
Basically, I sew about one or two stitches and the whole machine grinds to a halt. It looks like the thread is getting hung up on something in the bobbin area. I really dont know what it wrong - and I have tried the thread tension, new needle, re-threading...etc, It just keeps happening!
  • Fairy.Stitch Jan 18, 2009
    Yes, it is getting caught around the bobbin casing...i think. *sigh* I already took the whole thing apart, cleaned it, put it back together, put the machine on normal settings...and it is still happening. Also, when you "gun it" it snaps the thread on the inside, not at the needle (that happened on accident - touchy pedal). I really dont know what to make of it.
  • 22 Answers
Youch!  how frustrating.  It sounds like there is a piece of thread caught in or around the bobbin casing.  take the whole casing out and clean with your brush.
I feel your pain, hope this helps.  If not, please come back and we'll try some other things.
Posted on Jan 18, 2009
  • jill Jan 18, 2009
    have you had a needle hit the bobbin area?  is there a burr on the raceway anywhere?
Top stitch is fine bottom is loose. Have tried adjusting tension but not working. If I get tension too tight breaks thread so I gradually change tension to no avail. Please help
Check your stitch sample. The loose stitches under the fabric--are they actually top thread???? Usually,stitch problems under the fabric is a result of a top thread problem. In this case, it could be bird nesting.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot.
Rethread from the beginning.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 21, 2017 | Sewing Machines
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Is a satin stich programed in the machine.
Perhaps newer machines have it, but usually the sewists programs it. All it requires is a wide stitch and short stitch length. The length is adjusted so the thread actually covers the fabric between stitches, but does not overlap itself. Even if the sewist has a programmed satin stitch but there may still be some required adjustments needed since the thickness of the thread will alter the way the stitch looks.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Mar 20, 2016 | Sewing Machines
How do I get my sewing machine to sew with correct tension and straight stitches?
Over time, internal adjustments and servicing is required, at a sewing centers, service dept.
Take it in, have them look and repair, pay the nominal charge!
you will be glad you did!
Apr 16, 2015 | Sewing Machines
Thread tension
Needle/fabric/thread combination is wrong. hope this helps
Aug 17, 2017 | Sewing Machines
I have a 1970's? singer and the top stitch is ok but the bottom stitch is very loose then binds up I have tried putting another bobbin in but nothing seems to work. Thank you
Check the threading and tension on the top thread. It is the one that affects the stitch on the bottom. It may be hung up somewhere if it's not threaded correctly or the tension might be too tight. Also double check the size of your needle and make sure it is correct for the type of fabric. Most likely it is the tension. Double check the tension by sewing a wide zig zag stitch and examining the top and under side to see if they look identical and not puckered or too loose.
Mar 28, 2011 | Singer Sewing Machines
Hi. My name is Sue. Could you please let me know if our Necchi sewing machine has a blanket stitch or not? The model number is 4825. Thank you
Hi Sue,
I found that the blanket stitch is also called a "whip stitch" or a "crochet stitch" and looks like this:
I tried to look for instructions or a manual on the web for your machine, but there's little to find. I did find a picture of the stitch selector - and it looked to me that the RED "D" or "F" :
was as close as that machine was going to get to it. I'm not a sewing machine person - so that may not be correct.
Mar 03, 2011 | Necchi 4575 Mechanical Sewing Machine
Huskystar 224 top tension will not adjust. Last time I used this machine was a week ago, everything was perfect. Yesterday I started a project, and from the get-go there were big loops on the bottom of...
Have you tried to re-thread the machine? Check to see if the thread is in the take-up lever. There also might be a piece of thread or lint caught between the top tension disks.
Feb 23, 2010 | Sewing Machines
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
95 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
