Question about Quasar SP-3233 TV
Picture too dark
Our television's brightness was somehow set to one of the lowest levels, and then the remote was lost during our recent move. How can we adjust the brightness without the remote? There don't seem to be the correct buttons on the front of the set. The picture is so dark that most darker scenes look completely black
    Scholar:
    New Friend:
  • 70 Answers
Mkbowen,
whats the brand name of your TV?
also try this, facing the front of your screen. locate a button indicating " menu" and click it.
once the menu button been activated there would be a display box indicating "AUDIO" "VIDEO" "TUNNING" or in some cases the screen will indicate one by one setting every time you press the "menu" button. If you'll able to find a display indicating "video" higlight the said icon and navigate throught it until you see the control for brightness. you can navigate the icon by pressing +/- channel button and to change the value of selected item you need to press +/- volume button of the screen.
cheers ,
mark
Posted on Jan 18, 2009
My television screen went dark. I can get sound but no picture. I suspect that I rolled over on the remote and did something. However with no picture I don't know how to fix it.
The only thing I can think of is you somehow selected brightness when you rolled onto the remote and turned it right down, however if the TV is ok selecting such options would usually put a scale onto the screen regardless of how the brightness/contrast is set.
You might have damaged the remote. There have been incidences of remotes overheating when a button is kept pressed for an extended period and have even been blamed for causing a housefire.
Your tv might have some basic function controls on the set, perhaps behind a little door or somewhere at the back.
Aug 22, 2015 | Televison & Video
CONTRAST ADJUSTMENT
it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels.
I am further looking into ur problem..
Goodluck..
Feb 07, 2008 | Hitachi 57F500 57" Rear Projection...
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
I have a Visio TV that automatically dims during dark scene of movies. How can I fix this?
Hello:
There are several settings on your Vizio TV that could be causing this effect. Follow these directions to turn them off:
  1. Press "MENU" on your remote control
  2. Use the Left and Right Arrow buttons to select "Picture Adjust" (Far left)
  3. Use the Up and Down Arrow buttons to select "Advanced Video" (Bottom)
  4. Press the ">" button to enter the Advanced Video menu
  5. These menu options could affect the brightness and contrast of the picture:
    A. Black Level Extender
    B. White Level Extender
    C. Adaptive Luma
  6. Use the Up and Down Arrow buttons to select each menu option
  7. Use the Left and Right Arrow buttons to toggle these settings On and Off
  8. Once you have changed the desired settings, press the "MENU" button to exit the menu
Mar 07, 2011 | Televison & Video
The overall picture is much darker. Night scenes are almost impossible to see.
The brightness settings must have been changed somehow. Just go into your tv menu (there should be a menu button on your remote). Navigate to Picture Settings (this maybe different but there should be something similar) and move the brightness slider up but not too much or the picture will begin to look "washed out". Hope that helps.
Mar 02, 2011 | Hitachi 46F510 46" Projection HDTV
I have a Samsung 42" DLP. During the daytime I can hardly see the people and definition on the screen. It is all very dark. Nightime is better.
check your video settings there are 3 or 4 usually that all have various levels of brightness, it may be set to one of thelower ones. or you can go into tv menu and try kicking up the brightness. if no luck the lamp may be failing if not recently replaced they begin to make screen darker before they fail.
Jan 23, 2010 | Samsung DLP HL-P5663W 56" TV
Adjusting darkness
Hi Angel,
Are you really sure , your set has video? How dark is it ? As if really nothing visible? Am, sure you can hear sounds. You can adjust the brightness + button to increase the brightness. But if nothing happens , you have problem with your TV set. The problem might be in the Video section. Please let an expert technician to check it. Please don't do it by yourself, it's risky.
Please send feedback whatever comes up. So we can help you further in the future.
Thanks,
Eriez
May 26, 2008 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Aadjusting screen colors
They should be adjusted to set voltages. however it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels. Hope this helps.
Feb 01, 2008 | Hitachi 57F500 57" Rear Projection...
Quasar SP-3233 TV Logo
171 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
