Question about GE WBSR3140DW Top Load Washer
GE Washer Drum fell off
I have a GE top loading Washer that drum fell off during the spin cycle. I had a unbalance load..Is this problem easy to fix?
  • shantam4114 Jan 23, 2009
    I think this is the same problem that I have.
    diferant moddel #
SOURCE: GE frontload washer will not wash cycle or spin out
Thanks to Guest #2 our laundry is back in action and we're not waiting for a serviceperson. We took the front panel off, unscrewed the white plug and was sure our plastic drawer was open to catch the water, a load's worth. We found a small screw driver, 8 or so pony holders, some change, drill bits, bark, games pieces, can tops, etc... unbelievable. Thanks SO MUCH for the hint!
Posted on Nov 22, 2007
SOURCE: GE WCVH6260 Front Load Washer
thank you ...thank you...thank you. i never knew that there was a filter..as ge manuel says nothing about that. got 2.75 in change, a few rusted screws and assorted other **** out of it. runs like new
Posted on Nov 27, 2008
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
I removed the three screws, and lower cover cleaned the few pennies, screws and nasty gunk build up from the filter. The wash machine seems to function as it did prior to the clogged issue. Thank you everyone !!!
Posted on May 31, 2009
My GE washer GTW460NMKwww, the drum will not balance itself when going into final spine cycle.
Are the clothes evenly distributed inside the drum and the washer not overloaded? The drum is not self balancing, you must take care when loading it to even the weight distribution
Mar 01, 2017 | GE Washing Machines
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
GE GTWN5050M0WS top loader Washer, during the spin cycle the tub itself will not spin, but the bottom center piece will? Any ideas? Thanks
Call in an engineer. We had the same trouble and it was the clutch in the bottom of the drum. Takes about 20 minutes to fix.
Sep 18, 2015 | GE GTWN5050MWS 27" top-load washer with...
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
I have a LG WM1814CW front load washer. I get UE when it trys to go on spin cycle. I re-arranged the load and still comes up UE. I also tried a cycle without anything in the washer and still the same...
The UE error code is nothing to worry about. It indicates an "unbalanced error"¬-your washer's way of saying that the drum is not spinning is a smooth rotation. It could be as simple as rearranging the load in the drum (click image for zoom). Here's why:
1) Small loads. Your washer operates better when the weight of the load is evenly distributed across the drum, but that is not always possible with small loads.
2) Mixed fabric loads. For example, if you're washing jeans and t-shirts, the jeans could be on one side and the t-shirts on the other, causing the unbalance. Try rearranging the items and spin again.
3) Large single items. Items like sheets, blankets and comforters tend not to spread out evenly, causing unbalance when the drum spins. Rearrange the item and start the spin cycle over.
4) Spin Sense Option. If your washer has the Spin Sense Option, it may try to adjust the load on its own. If that happens, the washer would slow down and tumble a few times slowly during the spin cycle and then speed up until the problem is resolved.
Hope this helps.
Jun 24, 2011 | LG WM-2077C Front Load Washer
Washer bangs loudly on spin cycle
if you look inside at the top of the inner drum there are two big springs and a bamper at the bottom if any of the springs have snaped or just fell off there not holding the drum up and this is why it makes all that noise
its best to get it fixed as fast as you can as when its spinning the drum is wacking about inside your washer and its going to smash its self to bits as well as rip all the water pipes and wireing off as well?????
its an easy fix if you can do it?????
May 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothes washer vibration during spin cycles
the vibration and noise is most likely from the drum bearings wearing out to test the bearings try this out,,,
open the door, hold the top of the drum and lift it up, if it has any free lift in it the bearings are going, now spin the drum by hand and you should here the rumble off the bearings
Dec 29, 2009 | GE WPXH214A Front Load Washer
GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
Nov 22, 2008 | GE WBSR3140DW Top Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
GE WBSR3140DW Top Load Washer Logo
101 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
