Question about Balboa Instruments Duplex Digital Panel 2 Pump
Balboa control unti for my spa. (Model HPL200 that won't turn on
4 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
SOURCE: hi have problem with canadian spa
OHS, OH, or SPA TEMP LMT Message There is an "Over Heated Spa" (OHS or OH) Water Condition.
One of the Water Temp Sensors has detected 110°F (43.3°C) Incoming Water Temp and Spa Functions are Disabled. System will Auto Reset when Water Temp is below 108°F (42.2°C). Check for Extended Pump Operation or High Ambient Temp, or contact your Dealer or Service Organization.
Spa Water Cool Down
• In order for the Spa Water Overheat Error Message to Automatically Reset and Clear, the Spa Water Must Cool to below 108°F (42.2°C).
• Check the Topside Panel Display to see if the "OHS", "OH", or "SPA TEMP LMT" Spa Water Overheat Error Message has Cleared. If the Error Message has Not Cleared, the Spa Water is still too Hot to Continue Testing.
• Either Wait for the Spa Water to Cool Below 108°F (42.2°C), or Exit Now and Retest at a Later time.
You can find answers to COMMON SPA MESSAGES at the following website:
COMMON SPA PANEL MESSAGES
Hope this helps.
Posted on Sep 09, 2011
SOURCE: I have a 1999 Emerald
Understand that this information isbeing provided as-is and without warranty or guarantee. As with allelectrical components and devices, all work should be performed by a licensedspa or pool technician. Serious injury or death can occur if a component isimproperly repaired or installed. This soundslike it could be an issue with the board but there is some testing that needsto be done to determine the actual cause. A spa technician will be required tocome out and verify the wiring to the pump and then typically start testingvoltages off of the board as the unit switches between the relays that controlthe speeds on the pump. You can find answers to common spa orbath problems online at http://www.balboadirect.com/support.aspx Hope that helps!
Posted on Sep 12, 2011
Where may I obtain a schematic diagram for Balboa Spa control board H716R1A
Probably the only one who can provide you is the distribuitor of the board.
Nov 13, 2014 | Balboa Instruments BALBOA BOARD 100 MORGAN...
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
My Balboa vs500 won't change filter cycle time. I set it on F2 but it still runs for 4hrs.
Here is a link to the factory website and their trouble shooting guide. I hope it will help you get the settings changed.
Balboa Support Pages
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Mar 28, 2013 | Dream Maker Spas Pool & Spa
How to I increase the temperature to 101 on the drreammaker spa fantasy model?
This may be a little late as you may have already found the answer. But most "Fantasy" spas have "Balboa" control system. They are either a heat control knob, or Up/Down arrows on the spa side control system.
If you have the know & it is all the way turned to max position, and still not hot enough, then you may well have a faulty "Temperature Sensor". Get a replacement from your local DreamMaker dealership. Easy to replace.
Dec 20, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a problem when I turn on my spa the control plannel just shows (= = = )and nothing will work dose any one have any ideas what it could be
Balboa Control Packs -
(---) = Unknown water temperature.
Spa Builders Control Pack -
(---) = "Watchdog". Water temperature has reached 118?F. Entire system is disabled. Contact qualified service technician.
This error code is related to sensor malfunction or failure.
Disconnect and reconnect sensors (while system is disconnected from electrical supply), if that does not help start by replacing the Temperature or Hi Limit sensors.
Jun 03, 2012 | Garden
Topside control issues
Topside control is in "Locked" mode.
If you accidentally locked your control
Hold temperature UP & DOWN together for 6 seconds.
or
Balboa 7 button controls, both buttons to the left of the display screen & down temperature.
or
One of the buttons might be stuck in the down position
If these do not help let us know your control make and model & we'll see what we can do to find out more for you.
Dec 31, 2011 | Dream Maker Spas Pool & Spa
My balboa spa says sl and isn't heating up
SLP or SL Message
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
You can find answers to common spa panel messages on the following page:
May 19, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
I just bought a used balboa hot tub and have no expertise. Does the pump kick in automatically even when you turn it off it will turn back on instantly? Is that normal? If it is not normal what could be...
This does not sound normal, but in order to better diagnose this I need to know exactly what model of controls your spa has. This is easily found on a label on top of the control box in the spa cabinet. If the label is missing, then remove the control box cover and look at the inside of the cover for the schematic, should be a model number on it.
Aug 25, 2010 | Balboa Instruments Duplex Digital Panel 2...
Balboa Instruments Duplex Digital Panel 2 Pump Logo
131 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Craig Butler
Craig Butler
Delage guy
Delage guy
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
