Question about Aprilaire 700 Humidifier
Aprilaire 700 Humidifier not working. Can it be repaired?
House is very dry. Aprilaire 700 Humdifier is not actively working. It's silent. What repairs are involved?
    Problem Solver:
  • 4 Answers
Turn the humidistat back up, aand make sure if is still wired up.
Posted on Jan 19, 2009
We have an Aprilaire whole house humidifier that is functioning, but it does not have the ability to humidify our home. We have 3000 sq ft. When the heat comes on, the temperature must be high enough then...
You can turn the blower on so that the humidifier will run more... there should be a manual on detting on your t-stat that will run the blower constantly. The humdifier should be wired to go on withthe blower.
The other option would be to install a stem humidifier which will produce more humidity faster...
heatman101
Apr 19, 2010 | Honeywell HE365 Humidifier
Solenoid on Aprilaire whole house humidifier
the solenoid allows water to flow to jet that then runs down the pad the solenoid is control by the stat
Feb 23, 2010 | Aprilaire 700 Humidifier
House is dry though it's quite cold outside and furnace is running. Aprilaire is turned up to 35 (I have a dial, not a digital panel). the water panel is completely dry (should it be?)
unless the humidty in your home is higher then 35%. if it is then the humidifier would not run. try turning it up higher and see if it comes on. Do you hear a click in the humidistat? as you turn up the dail when you hear the click is when the humidifier should come on. Also remember your furnace must be running for the humidifier to come on. if you hear the click and the humidifier fan comes on but no water, you may have a clogged inline filter located in the solinoid valve or a bad soliniod. all parts for your humifier can be purchased from www.aprilaire.com
Feb 05, 2010 | Aprilaire 700 Humidifier
Dry house with furnace mounted humdifier
Is the furnace fan set on auto or on. You will get better humidity if you keep the fan on. It won't add much to your electric bill because many of the newer furnaces operate the fan on DC voltage. Try it!
Jan 16, 2010 | Aprilaire 700 Humidifier
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
Aprilaire Humidifier Model 560 - Humidity Not Rising in House
water trough on top filling up. do not clean it too much as crud distributes water across top better.
Dec 25, 2008 | Aprilaire 700 Humidifier
What should my humidifier be set at for the winter?
Hi, Jennifer:
I'm no expert, but those who are seem to agree that the first thing to check is your evaporator panel. Aprilaire recommends replacing it annually--so if you haven't replaced it recently, that would be the first step to take. Next, check the power supply to your Aprilaire unit. Turn the humidistat to 0%, and then turn it slowly back toward 35% until you hear a click at the unit. If you don't hear a click, you'll want to check that the unit is in fact getting electric power (you may want to get an electrician or furnace tech to do this). If you do hear the click, the next thing to check is whether you have sufficient water flow to your Aprilaire unit. On mine, I had to adjust my water supply saddle valve, as well as the inline valve on the discharge side of the solenoid (see prior post from this morning)--and this seemed to clear the lines and restore water flow. Once you achieve proper water flow, you will probably want to set your humidistat at 35% for winter temps of around 20 degrees F--but be sure to adjust it downward for colder weather. Comments, anyone?
Dec 13, 2008 | Aprilaire 700 Humidifier
After one season the model 700 doesn't turn on
clogged solonoid? clean filter and orifice
Aprilaire 700 Humidifier Doesn't work
check this website for a wiring diaghram Aprilaire 700 Repair Parts & Supplies
http://www.arnoldservice.com/Aprilaire_700_repair_parts_supplies.htm
Dec 07, 2008 | Aprilaire 700 Humidifier
Aprilaire 700 operating at wrong time
You want the humidifier to run in heat mode which is the r-w1 terminal on the stat.
Nov 17, 2008 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
413 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
