Question about Acer Aspire SA80 (ASA80UC4603) PC Desktop
No display - ON-chip VGA diabled in BIOS
I have an ACER Acerpower SV. In an effort to get my new PCI video card to boot up at start-up I set the ON-CHIP VGA to "disabled" in BIOS. The result was, I now have no display signal to the monitor at all. Nothing from the on-board monitor port or the new video card port. So obviously I cannot go back in to BIOS to re-enable the setting. I have no display at all. How do I fix this???
Hi ... i think you might solve the problem by removing the battery from *********** board for about 30 seconds or even a few minutes to be sure...... this should reset your bios to factory settings... good luck !
Posted on Mar 24, 2009
You go change it blind; in other words you do it without seeing what you are doin; yoiu likely can find the instructions or the video on utube to show you where you are goin . you should be able to do this with just seeing what your screen shots look likeand since you don't use the mouse; you just need to visualise your one click at a time comands with your directional arrows and then all the other ones you need are enter and delete ; depending on the key you need to use to go to yoiur bios set-up. And next time you are in contact with your working monitor; take pictures of each frame (screenshot) in your bios and store them in your phone or other pc so that you will always have control of this situation; no matter what happens . Or you could buy these guys' products.LOL
Posted on Jun 01, 2013
  • 114 Answers
Pull out the new video card and the old one will be enabled once again..
Posted on Jan 18, 2009
    Champion:
  • 203 Answers
You can go back to bios that is and reste the video card, try in SAVE MODE you should be able to go in SAVE MODE and enable it back. It is not big problem.
    Sergeant:
    Champion:
  • 334 Answers
You should of went into the control panel and went to system then hardware and then device manager and disable it there. you probably need to back into setup and enable it. Then go into device manager and disable it there then check while your there if your new one is enabled if it isn't enable it
How do you enable onboard video card in bios
Here's what others have tried.
I like the jumper and cmos and enable/disable portions
avatar-default.png Posted bylesleymillar on 11 Oct 2009 8:00 AM Just fitted a new PCI graphics card (Radeon 9200) in my 4 year old Dimension 2400. The only way I can get it to work is to have both it and the on-board graphics chip running together - done this by selecting the Radeon as the default display and by not having the Windows desktop run over onto the Intel display. Problem: If I disable the on-board graphics chip as per the fitting instructions and then set my Bios to auto select, the computer boots and is active but all I get is a blank screen regardless of which output the monitor is connected to. Also, as I have the Radeon as the default display in Windows I don't see anything (no Dell boot screen, etc) when I switch my machine on until Windows log on screen as I have to have the Bios set to 'On-board' in the graphics option otherwise the aforementioned problem persists. Has anyone else encountered this problem, and if yes, has anyone managed to overcome it i.e. successfully disabled the on-board chip? Unfortunately there is no Bios upgrade from Dell that allows a user to select either auto, on-board AND PCI - the last one being ideal it would seem!
{count}" data-configuration="Format=%3Cspan%20class%3D%22count%22%3E%3Cspan%20class%3D%22icon%22%3E%3C%2Fspan%3E%7Bcount%7D%3C%2Fspan%3E">0
  • avatar-default.png Posted byrdunnill on 11 Oct 2009 4:58 PMI just configured a 2350 with a PCI card (Sparkle 8400GS), and I left the BIOS setting at auto-select. (I could find no way to disable the onboard graphics.)
    I found that if Windows installed a driver for the onboard graphics before the PCI video, the onboard graphics were used for the default monitor. Thus, I got no image from the PCI video. I connected a second cable to a spare DSUB port on the monitor to the onboard graphics and switched inputs until I got video. Then I downloaded the appropriate video driver for the onboard graphics, installed, and rebooted. Upon reboot, I switched the default monitor from the onboard graphics to the PCI video, after which I could remove the second video cable.
    Hope that helps!
  • 4tjv4usnef6m.jpg-32x32.jpg?m=634535492957260780 Posted byJackShack on 11 Oct 2009 6:32 PMSome additional information that may be helpful:
    1. The Dimension 2400 uses an on-board AGP graphics chip that cannot be disabled in hardware. It shares the interrupt for the first PCI slot which can give you trouble if you decide to place your add-on PCI graphics card in slot 1. My own add-on card wound up in slot 3, so it might be helpful to switch to another slot before giving up.
    2. If you do have your card in slot 1, try resetting the NVRAM (CMOS) by removing the battery for about five minutes. You can find instructions for that here: Dimension 2400 Service Manual. Look in the section on Removing and Installing Parts, Battery. While the battery is out and everything still unplugged, push the power button and hold it in for about fifteen seconds to ensure the discharge of any storage elements. When you put the battery back in its holder and fire everything up again, the computer will take a new inventory of its devices and will sometimes finally find the PCI video card.
    3. This next you've probably seen, but it bears repeating: Before attempting to install the new card, go to the Device Manager, Display Devices, and find the Intel Graphics Adapter. Double click it to bring up its properties, go to the bottom of the little window to Device Usage, and click the small arrow on the right to get the menu. Select "Do Not Use This Device - Disable". This will disable the onboard driver and cause the computer to load the standard VGA driver that works with all the video cards. Sometimes the reason you see nothing on the add-on card is that Windows is still trying to use the driver for its previous video adapter which is incompatible with the new card.
    Dell Forum member since 2005
  • avatar-default.png Posted byrdunnill on 11 Oct 2009 7:40 PMIt might help to disable the onboard video in Vista, as ATI drivers can clash with it and cause BSODs. Under XP it'll co-exist.
    There is a jumper on the mainboard for clearing the CMOS. It is marked as such, and the manual will point it out.
    The default Windows driver for the add-on card will work, but without acceleration and with a very low resolution. Also, if Windows installs the driver for the onboard graphics first, it will mark the onboard graphics as the primary display.
  • 4tjv4usnef6m.jpg-32x32.jpg?m=634535492957260780 Posted byJackShack on 11 Oct 2009 9:10 PMYes, I neglected to mention that if you get the card to work in the VGA mode you should be able to install the specific driver for the card. In the past I have recommended that no attempt be made to load the driver for the card until a VGA screen can be displayed.
    Granted there is usually no conflict if the onboard driver is left in place; the problem arises when the BIOS sort of recognizes the new card but for some reason Windows fails to find a driver for it. In this situation you get video from neither the onboard port or the PCI video card port. This seems to happen a lot if the card is installed into slot 1. In the past I've corresponded with folks who seem to be able to get the card to work only by using the Windows multi-monitor capability; extending the screen onto the video card. The only irritation with this is that you get no video until Windows loads, so if you want to see the system setup screen you need to switch ports.
    Naturally I realize that a jumper is there and is supposed to work, but removing the back-up cell makes certain that the NVRAM will be cleared.
  • avatar-default.png Posted byrdunnill on 11 Oct 2009 10:40 PMThe jumper definitely works, as I used it last week several times in dealing with a recalcitrant 2350.
    Windows should find a driver for any VGA-compatible card; it'll be a default VGA driver. However, if Windows can find the driver for the onboard video, it will use that as the primary video, regardless if they are connected or not, and the user will get no video from the PCI card. I had this problem with the 2350, and had to temporarily install a VGA cable to connect the onboard video; after installing the drivers for the PCI card, I'd switch the primary monitor to it and all would be fine.
    When I installed Vista on the 2350, I experienced BSODs on startup until I disabled the onboard video. I am not sure if this happens with nVidia cards as well as ATI ones.
    I tried two cards with the 2350: an expensive HIS 4350 ATI and a much cheaper Sparkle 8400GS. The 4350 worked, but did not accelerate video playback (ATI said they did not support it over the PCI bus), so I RMA'ed it. The 8400GS installed without incident and worked perfectly and accelerates both standard and high-def video. Both cards were installed in slot 3.
Jun 01, 2014 | Dell Dimension 2400 PC Desktop
HP d530 sff with XP won't boot with NVS400 PCI card installed
display first going to your Nvidia card which is i think is faulty, however if you still want to attach it , change the bios setting, display first to onboard instead of pci
Jan 30, 2013 | Nvidia Computers & Internet
I have a Gateway DX4822 with Acer G43T-AM v2.0 Motherboard. I want to remove the GT220 Video Card and install an ASUS ENGTX465. When I boot up the video does not start and the computer fails to complete...
First open the cpu cabinet and install the new graphic card in 1 of the pci slot or AGP slot. Then when you power up the computer press F1 or F2 or del or ALT +F2 key to enter in bios. Then disable on board vga .Then save settings and exit. Then when you power up the computer press F8 key 5 to 6 times then you can see safe mode and other menu. Enter in enable vga mode then uninstall old graphic driver and install driver of new graphics card. then go to display settings change screen resolution to 1024*768 then apply and check. Let me know if you need further assistance. Thanks for using FixYa.
Nov 28, 2010 | Gateway DX482203 (PTGA002009) PC Desktop
How do I install VGA PNY VCG62256PXB 6200 256M RT
heres a link to a video tutorial from PNY's site.
http://www3.pny.com/support/media//Files%5C270ec5f3-e4a8-4fd6-b9d1-aefe16606c78/fx5500D_v1.swf
after you have disabled your current adapter in device manager, you will need to verify that your system's primary display adapter is set to PCI in your BIOS.
1. Reboot computer. you can enter the BIOS settings by pressing F2 key right after post during the boot process.
After you have set the primary display, reboot and then shutdown. unhook power cord and monitor cable
2. find an open PCI slot and remove the slot cover from the back of the case. Insert the card, making sure it is seated properly (no gaps, not crooked)
3. attach monitor cable to the VGA port on your new card.
4. boot system. you will get the message that windows has found new hardware. cancel all the prompts that come up.
5. insert your drivers disk that came with the card. follow through the prompts.you will have to reboot after the installation.
your video card should be working now.
hope this helps
Feb 16, 2010 | Dell Dimension 2400 PC Desktop
I need to diable the onboard video card before installing a PCI-E 2.0 graphic card. From what I have read, it's possible this is done automatically, through BIOS, or by a jumper setting. I never received...
It is an option in the BIOS under "Advanced Bios Features". Set Initial Display to PCI Express VGA card. Your options may be slightly different due to different BIOS.
Jan 30, 2010 | Gateway GM5472 PC Desktop
Pc powers up but no video on screen gateway 420gr desktop
Yes generally speaking when you drop in a videocard it typically will disable the built on one. You may have to disable it though. I know you said you did not see the onboard video in BIOS but there is almost always a setting in there to turn it off.
Sep 17, 2009 | Dell Dimension 8200 PC Desktop
Acer 8000 desktop. Cleared password moving the jumper pin. Put the jumper pin back turned back on and it will not post to boot. Lights on the keyboard keep blinking and no post to boot.
It is possible that your video settings in the BIOS has been reset. When you move the jumper pin to reset, the BIOS automatically resets to defaults. Depending if you are using a PCI card for video or the integrated graphics card AGP on the motherboard. You need to set this correctly otherwise you will not see anything. Worst case scenario, remove the CMOS battery for ten minutes and when you turn on the computer try to activate setup. go to the advance options and see if you are using the correct settings. I hope this helps.
Mar 15, 2009 | AcerPower 8000 PC Desktop
How to disable onboard/integrated video in bios
I would suggest attempting to configure it through windows. Go start, control panel, display and set the secondary output which should be your pci card to display the primary screen. If that does not work I would suggest going onto the hp website and searching for further assistance.
Mar 07, 2008 | Computers & Internet
Frezees at bios
REPLACE RAM OR VGA CARD
Dec 12, 2007 | Acer Aspire T310 PC Desktop
Computer boots up but no video display.
If it has onboard video and you've added a video card, sometimes you need to disable the onboard video in the BIOS as it won't send output to both when they are there. I would try a different monitor and eliminate that as a possibility also.
Mar 24, 2007 | AcerPower F2 PC Desktop
Acer Aspire SA80 (ASA80UC4603) PC Desktop Logo
1,793 people viewed this question
Brian Sullivan
Brian Sullivan
