Question about Epson Stylus C84 InkJet Printer
Stylus is not printing
How come that it's not printing not even a single dot? i have stylus c84 for years now.
  • 1 more comment
  • jatos49580 Jan 21, 2009
    Go to this forum. Maybe some of the comments will help. More than one poster solved this by cleaning out the purge tube but I for one can't figure out how to get to it.
    http://www.fixyourownprinter.com/forums/...
  • Anonymous Jan 22, 2009
    my epson c84 won't print on the paper
  • Gerry Millward
    Gerry Millward May 11, 2010
    We need a bit more information. Is it both black and colour that doesn't print? Was it printing OK, then you changed the cartridges and after that no printout? Did you do a proper cartridge change that finished with an ink charging cycle. Have you run any head cleaning cycles.
  • 353 Answers
It appears that gbmalabanan and guest have lost interest in this problem, so I think we may post it as "Solved by Posters".
Posted on Apr 08, 2009
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Jan 01, 2011 | Epson Stylus C84 InkJet Printer
Will not print plank pages,even after cleaning.
check print head and head cable............
If ink flow change mainboard, print head, and head cable. if ink not flow change only main board
Jan 06, 2010 | Epson Stylus C84 InkJet Printer
Printing blank pages but just changed ink
check the print head and cable head. if it is ok you need to replace Main board. if they not ok replace all
Dec 19, 2009 | Epson Stylus C84 InkJet Printer
Printer wont print out in colour The inks are full. The black ink works but not the colour inks, Epson stylus C84
Epson Requires Original Epson Ink.
Colors will not come out as they should, and then the words will print out only either top or bottom.
Good Luck....
Oct 06, 2009 | Epson Stylus C84 InkJet Printer
Not printing
If you've just bought a C84 today then you've been sold a second (or even third) hand unit which is clogged solid.
To resolve this you're going to need to clean the printheads which is something I've described here
It's a different printer but the same process applies.
Hope that helps.
Feb 21, 2009 | Epson Stylus C84 InkJet Printer
Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Dec 08, 2008 | Epson Stylus C84 InkJet Printer
Won't print unless all ink cartridges have ink.
Try changing it in the properties section under device settings
or go to color management if you have it and change the setting to black only,.
Aug 07, 2008 | Epson Stylus C84 InkJet Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
CAN NOT PRINT LWORKS FILE TO THE EPSON STYLUS C84 PRINTER
Can you print something with a different program such a Microsoft Word? If you can then the problem is with LWORKS if not then the problem is with the printer driver. Please respond so I can help more.
Thanks for reading!
Nov 29, 2007 | Epson Stylus C84 InkJet Printer
Printer not printing
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Epson Stylus C84 InkJet Printer Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
