How to replace the idler pulley step by step - Computers & Internet
  • 7,627 Answers
I think you have the wrong category, you will get a faster response if posted correctly and with detailed info.
Posted on Dec 30, 2012
HDo I remove and install an idler pulley on a 2005 Toyota Camry?
How to replace drive belt tensioner Toyota Camry - YouTube
? 4:26
https://www.youtube.com/watch?v=gfSJvN-CE2E
Feb 22, 2013 - Uploaded by Fix It Angel
2002 2003 2004 2005 2006 2007 2008 2009 Toyota Camry. Engine, 4 cylinder, 2.4L, 2AZ-FE. 2004 Toyota ...
Idler Pulley, How to replace (EASY and CHEAP) - YouTube
? 4:56
https://www.youtube.com/watch?v=axAltpW8wR4
Nov 2, 2013 - Uploaded by ChrisFix
Idler pulley squeak? Learn how to fix a squeaky pulley in your car. The serpentine belt in your car powers the ...
2007 Camry Serpentine Belt Replace - 4 Cyl, 2.4 liter ...
? 4:21
https://www.youtube.com/watch?v=ejhyCrh96a8
Jan 13, 2013 - Uploaded by Flyin Brian
I show you step-by step how to get the old belt off and install a new ... ... Water pump replacement 2007 Toyota ...
Jan 27, 2016 | Toyota Cars & Trucks
How to remove front idler
Dryer Idler Pulley (part #691366)-How To Replace - YouTube
? 6:06
https://www.youtube.com/watch?v=YoJ7k30kXhE
Nov 14, 2011 - Uploaded by AppliancePartsPros
Buy the new Dryer Idler Pulley 691366 ... We did not have toremove the rear panel with this design, it was ...
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ...
? 2:53
https://www.youtube.com/watch?v=RZ09dH4-7Ho
Jul 6, 2010 - Uploaded by RepairClinic.com
Dryer Idler Pulley Replacement - Whirlpool/Kenmore ElectricDryer Repair .... If the belt is around the drum ...
Dryer Idler Pulley Replacement - GE Dryer Repair (part ...
? 3:37
https://www.youtube.com/watch?v=bm8s2vVuxvk
Sep 17, 2012 - Uploaded by RepairClinic.com
The most common reasons for replacing the idler pulley... ... GEdryer tune up, belt, drum bearing and front ...
Dec 25, 2015 | Dryers
Bolt backed out of idler pulley in my 2008 ford fusion what do I need to do to put my new pulley in
You need a serpentine belt tool, you can rent one at the parts place and while you are there get the new idler. You will also need a wrench to fit the bolt. Remove the belt then take the bolt out of the idler and install the new one, you can use some low strength loctite purple to keep this from happening again. Reinstall the belt, return the tool and get your money back for the rental.
Feb 17, 2014 | 2008 Ford Fusion
Makes a squak noise
You need to replace the dryer belt.
Instructions Things You'll Need:
  • Screwdriver
  • Amana dryer belt
  1. Step 1 Disconnect the power source from the dryer. You can unplug from the wall outlet, remove the fuse from the fuse box or flip the breaker in the panel box.
  2. Step 2 Pull off the front panel of the dryer. Remove the screw in each corner at the bottom of the dryer's front panel. Lift up the front panel until the two clips at the top disengage. Remove the two screws that are found beneath it at the corners to remove the cabinet top.
  3. Step 3 Remove the belt by releasing the tension applied by the movable idler pulley wheel. The belt loops over the drum, under the idler pulley wheel and then around the motor's drive pulley.
  4. Step 4 Discard the used belt. It is fine to just throw it in the trash.
  5. Step 5 Install the new belt by pushing in on the idler pulley arm. Make sure the new belt is placed flat along the exterior of the drum.
  6. Step 6 Replace the screws back into the dryer's front panel. Screw them in tightly so that the panel will not fall off or jiggle loose.
  7. Step 7 Reconnect the power source back to your dryer. Either plug it back in or flip the switch in the breaker box.
May 13, 2010 | Amana NDE2330AY Electric Dryer
How do i get to the serpantine belt on 96 lincoln continental
Step 1 Inspect the belt already in your Lincoln for cracks or wear. It is best to replace serpentine belts early, before any major damage occurs, as a break in the belt will cause a critical failure in a motor vehicle while under power.
  • Step 2 Find the belt routing diagram under the hood, this can usually be found on the top of the radiator mount. Lincolns, even those of the same year model, may have different accessories run by the serpentine belt. So the exact routing of the belt will vary from vehicle to vehicle.
  • Step 3 Loosen the tensioner pulley until you can push it relatively easily. The belt should still be too tight remove, if it is not the idler pulley is malfunctioning.
  • Step 4 Unscrew the idler pulley belt until the idler pulley loosens enough to allow the belt to be removed.
  • Step 5 Make note of the direction of rotation of the serpentine belt as it is important to install the new belt in a way that it is intended to rotate.
  • Step 6 Insert the new belt in accordance with your Lincoln's belt installation chart.
  • Step 7 Tighten the idler and tensioner pulleys an assistant with a pry bar may be needed to properly tighten your Lincoln's serpentine belt.
  • Sep 24, 2009 | 1997 Lincoln Continental
    If tention pully was loose would it make a steel on steele sound i nothing is rattling 97 cavalier
    it could and also look at the idler pulley too. If it is your tensioner or idler pulley, try not to drive it to much till you can replace it. If the pulley bearing fails, you'll end up on the side of the road. With out the pulley's you'll lose your power steering, water pump, and alternator. Good luck and hope this helps. Keep me posted, be glad to help. If there is a Auto Zone around your area, your can buy the replacement parts there and they will have the step by step instruction to do the job and it's fee of charge.
    Jun 11, 2009 | 1997 Chevrolet Cavalier
    Replace idler arm pulley
    An idler arm is a steering component found on vehicles without rack and pinion steering. Your referring to an idler pulley. To replace: remove the belt, remove the bolt from the center of the pulley, replace the pulley and reinstall the belt.
    Apr 11, 2009 | 1999 Dodge Intrepid
    Dryer belt install
    This site has a good illustrated procedure for replacing the belt. The picture in step 11 shows how to route the belt under the idler pulley.
    http://repair2000.com/wpoolbelt.htm#INSTALLING
    Feb 07, 2009 | Whirlpool Dryers
    1996 Grand AM 3.1L serpentine belt replacement
    Try this procedure.
    To replace a worn belt, locate the idler or generator pulley.
    Loosen the hold-down fastener for the idler or generator pulley.
    Pry the idler or generator pulley inward to release the belt tension and remove the belt.
    Match the old belt up for size with the new replacement belt.
    Observe the belt routing diagram in the engine compartment.
    Install the new belt over each of the drive pulleys. Often the manufacturer recommends a sequence for feeding the belt around the pulleys.
    Art courtesy of Delmar - Thomson Learning.
    Pry out the idler or generator pulley to put tension on the belt.
    Install the belt squarely in the grooves of each pulley.
    Before adjusting belt tension, check for proper pulley alignment. This is especially critical with serpentine belts. Measure the belt deflection in its longest span. If a belt tension gauge is available, use it and compare the tension to specifications.
    If a belt is too tight, wear to bearings for the water pump, alternator, and engine crankshaft can result.
    Some late-model Chrysler engines require a torque reading to be taken when tension is applied to the generator drive belt. This is especially important on the longer, multiribbed V-belts.
    Pry the idler or generator pulley to adjust the belt to specifications.
    Tighten the idler or generator pulley fastener.
    Start the engine and check the belt for proper operation.
    Any more questions please ask. Good luck.
    Jan 24, 2009 | 1996 Pontiac Grand Am
    Daewoo Leganza 2000 timing belt broke
    Hi.
    If the idler pulley, broke, with the car running, (I think is the most probable), There is no way to fix the car just replacing the timing belt and the idler pulley. This is an interference engine, that means if the timing belt or the idler pulley breaks, you need to replace the whole cylinder head, that's because the valves are bent. I just fix my daewoo, I tried first to just change the idler pulley and set up the time, but it did not work. I had to replace the whole head cylinder, timing belt and pulleys.
    I got the information to set up the timing belt from a Library, The program is Mitchell on demand.
    Thanks
    Aug 29, 2008 | 2000 Daewoo Leganza
    Computers & Internet Logo
    12 people viewed this question
    David Payne
    David Payne
