Question about Husqvarna 28cc Gas Line Trimmer
Where do the fuels connect from fuel tank on husqvarna 326l
  • Husqvarna Master
  • 2,239 Answers
You should have 3 tubes, a fuel delivery tube, a fuel return tube and a fuel suction tube, the fuel delivery tube ( the one with the fuel filer on in the tank ) goes to the connection on the carb nearest to the pump cover held with a single screw, the other connection on the carb goes to the suction side of the primer bulb ( the shorter of the two connections ) the return to tank tube fits to the longer connection on the primer, this tube is just pushed into the top of the fuel tank,
Posted on Dec 30, 2012
2 Suggested Answers
  • 144 Answers
SOURCE: I have a 326L. The trimmer starts and sounds like
Sounds like your fuel cap may not be venting properly. If no air can get into the fuel tank, then after a short while of running, no fuel will be able to be sucked out, thus starving the engine. You can find replacement fuel caps at PartsBuggy.com.
Posted on Oct 24, 2011
Routing of fuel lines on a husqvarna weedeater carburator 323L
The fuel line from the tank ( the one with the fuel filter on the end ) goes to the car inlet ( the one nearest to the pump cover held with a single cross head screw) the other connection on the car goes to the purge bulb ( the connection with the shorter tube) the other connection on the purge bulb ( longer connection) goes back to the fuel tank. The thing to remember is the bulb pulls fuel from the carb, into the bulb and delivers back to the tank.
Aug 20, 2017 | Husqvarna Garden
Stalls slowing down
Air filter plugged - Clean air filter
Tank vent faulty - Clean or replace tank vent if necessary
Leak in fuel line between tank and fuel pump - Seal or renew connections and fuel line
Pump diaphragm damaged or fatigued - Fit new pump diaphragm
Main jet bores or ports blocked - Clean bores and ports
Fuel pickup body dirty - Fit new pickup body
Fuel strainers dirty - Clean fuel strainers
May 01, 2013 | Husqvarna Garden
I have a 326L. The trimmer starts and sounds like normal. After about 5 minutes it starts spuddering and then dies as it losses power. Then I cannot start it again. I have a new fuel filter and I have...
Aug 29, 2011 | Husqvarna 28cc Gas Line Trimmer
I filled my 340 husqvarna chainsaw for the first time this year and it leaked gas from someshere opposite the fuel fill tank( maybe near the fuel line). It then quit leaking and just will not start. Maybe...
Opposite the fuel fill is the tank breather, and the return to tank hose if the machine has a primer, the back to tank hose fits on to an orange connection in the tank, it may have slipped off, next to it is the breather the early breather was two white pellets pressed into the tank, these will need to be removed and replaced if this is where the leak is from, the later breather is a white round assembly with a connection on the top, nothing fits to this conection, the breather can be pulled and and replaced if required.
May 01, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I HAVE A HUSQVARNA MONDO LINE TRIMMER.WHERE DO THE FUEL LINES CONNECT.THE MACHINE HAS A WALBRO CARB.
For a machine with a remote primer bulb: The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. For a machine with the purge/primer bulb on top of the carb: The small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Oct 25, 2010 | Husqvarna 28cc Gas Line Trimmer
Fuel line
I think a direct line from the tank to the carburetor just like the video.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
An IPL with part numbers and some detail can be found here: (Probably a page and a half of 61s. If you do know what year your saw was produced please contact Husqvarna, at the link provided, for help.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Gas line broke at top of gas tank fuel filter loose in gas tank
You may find these helpful. Typical fuel system:
5114cbb.gif No model provided; may not have primer.
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
HTH
Lou
Dec 20, 2009 | Husqvarna Garden
How to replace fuel line/filter 1994 husqvarna 36 chainsaw?
You can find an IPL with fuel system components, part numbers and some detail here: They are probably spread overr multiple images.
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
typical fuel system:
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Nov 13, 2009 | Garden
Husqvarna 65 fuel line
This is Husqvarna.com manuals. You wlll need to find the IPL that applies to you. The exploded diagrams should help you trace the fue lines.
Lou
Aug 06, 2009 | Garden
Husqvarna 28cc Gas Line Trimmer Logo
480 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
