Question about Belling XOU270 / XOU271 Electric Single Oven
Cant get anoying alarm buzzing sound to stop
It is not timer alarm
Oven keeps beaping and has a alarm symbol showing
Sounds like the timer was set and time is up, the issue is whichever model oven it is has a specific way to stop the alarm. Some just require a simple pressing "cancel" while others use a combination of buttons. I would try pressing either the arrow up or down, if not present just press the "timer" button, see if the alarm symbol changes or disappears
Nov 10, 2016 | Ovens
A SMALL BUZZING IS GOING ON AND CANT SHUT IT OFF ALSO OVEN HASENT BEEN USED IN YEARS TURNED ELECTRIC OFF BUZZING WENT OFF
Check to see if there is a switch for an open or not properly closed oven door. Could be stuck in the wrong position.
Nov 09, 2015 | Ovens
My electrolux EOU43002X oven bottom fan recently stopped. it also coincided with a buzzing from the timer panel. I replaced fan motor but timer wont work and the buzz still there when the timers tried
According to the convection fan which does not work, I suggest checking the main oven selector, wiring and convection fan.
According to the timer you should first set the time and then verify the correctness the timer relay. If relay is open than completely oven will not work.
Dado
Sep 08, 2015 | Electrolux Ovens
My daughter turned the timer but when it got to zero and it buzzed....it never stopped buzzing. It is still buzzing 10 hrs now! What can I do?
unplug your oven. sounds like you need a new timer. the relay is not releasing . cause the timer wont let it
Jun 19, 2011 | Kenmore Ovens
Timer alarm volume is down
iam sorry to tel you there is no way of turning it up you would have to get a new timer
Paul http://www.apart4u.co.uk
Mar 04, 2010 | Ovens
Zanussi oven timer buzzes at 20.00 then resets to 12.00
Gave up and bought a new timer module for £66 from espares. Timer board has microscopic components so even if you knew what was wrong it wouldn't be fixable.
Sep 22, 2009 | Zanussi ZBF360 Electric Single Oven
Timer is making ticking noise cant turn it off.
My same oven makes a ticking sound when you tell it to start pre-heating the oven. The oven continues to make this ticking sound until you stop the oven and it completely cools down. This ticking sounds to be coming from the oven control panel. I have no solution, but I'm glad I wasn't the only one who had a problem with this ticking sound!
Jul 15, 2009 | Ovens
No Sound on frigidaire black smooth top stove/oven
Check in the manual, sometimes the alarms can be disabled.
Please reply the complete model number to see if that ability exists, or what the P/N is of the timer.
Feb 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Belling XOU270 / XOU271 Electric Single Oven Logo
20 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
