Question about Canon PIXMA MP470 All-in-One Printer
Adds header too every page printed
Put a caption on pic now adds it too every plain paper job.
    President:
  • 2,692 Answers
Sharp mx 3110n, all settings are at "Plain Paper", when print a worksheet from excel, does not print because settings say "Heavy Paper"
Excel treats each worksheet as a different print job. Make sure each page is set to the type of paper that you want to print on.
Under the Page Setup make sure the type is set for the correct type, as well as in the print driver.
How To Configure Sharp Print Drivers with Installed Options to print...
Oct 21, 2013 | Sharp "MX-3110N Color Copier, Printer,...
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
How can i chanche de fax number dat is printed. That number is not good, i wil chanche this
you need to go into the menu and look for settings fax the n look for the fax ID here you can change the number and the header the header is the name you want printed on top of the page ie your company name.. you can find the sections by looking on the right hand side of the display and you should see a button called reports here you can print off the section rep[ort which tells you where to find the settings in teh menu
Sep 29, 2009 | Canon FAX-L350 Plain Paper Laser
HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Apr 13, 2009 | HP LaserJet 5000dn Printer
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
Canceling a print job?
Remove paper....unplug power....hold down 3 and 6 and plug in.
Mar 20, 2008 | HP 920 Plain Paper Fax
Panafax UF560 - how to set so confirmation page is automatic ?
Function 7 4 set.
07 (Header Print)
Setting number 1 (Inside copy area) 2 (outside) 3 (none)
Set.
You can also set the header format with Parameter 08(Header Format) 1 is for your Logo and fax number. 2 is for From: to:
Feb 01, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Sharp ar-m351/451
I think that funcation is called inter-weaving or insert-page. Look in the index for Special Features
Jan 28, 2008 | Office Equipment & Supplies
Duplex printing on HP Laserjet 2840
This is the natural process for the you the user to make sure that you have the correct media in the manual feed. You can change this in the paper handling menu within the menu options set the tray 1 media type to plain and auto continue also correct paper size. You can also put the paper back into the main cassette and this will not cause the problem.
Thanks J
Jan 24, 2008 | HP LaserJet 2840 Printer
Canon PIXMA MP470 All-in-One Printer Logo
27 people viewed this question
old marine
old marine
