Question about LG VOYAGER VX10000 Cellular Phone
Voyager buttons do not work
I have a brand new voyager, that I got second hand. My brother warranty replaced his a couple of days before he got a new storm and the gave me the voyager, because I lost mine. The phone has never been dropped or had anything spilled on it and it doesn't have a single scratch; however, the majority of the buttons do not work. The send button on the front of the phone doesn't work and the clear and end buttons are the only ones that work on the inside. Even if your using the browser, you have to hit the touchscreen about 20 times, before it will go to a link. If you turn the phone off for a few minutes and turn it back on, the buttons will sometimes work for a couple of minutes. I've had the verizon store update the software and the problem has persisted. Any ideas what is wrong and how to fix this?
What a loser natymiami04...have you tried calibrating it??? mine did that same thing till I calibrated it to my fingertips...try that
Posted on Jan 28, 2009
Press them really. ut really hard... jsut as how i pressed your **** last night..
Posted on Jan 20, 2009
I now have 2 Voyager Pro+ wireless ear pieces that have quit working within 2 months of activation. No LED light at all when hitting the on/off switch, when power is plugged in no LED on one, I get an LED...
If the units were just purchased I would suggest having them replaced by Plantronics. The Voyager Pro+ has a one year warranty through Plantronics. The link below is for Plantronics online replacement form.
Plantronics Replacement Form
Good luck from Headsets Direct!
Aug 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
My headset will not hold the charge very long - is there a fix for this - is there a battery somewhere on this unit that can be replaced?
Unfortunately, the Plantronics Voyager 510 Bluetooth headset does not have a replaceable battery, it is "hard wired". However the 510 headset does have a one year warranty, so Plantronics will replace it within the warranty period. If it's out of warranty, you can buy a replacement if you'd like or buy the newer version which is the Plantronics Voyager Pro+, which is just a newer, slimmer model and it also has newer technology (for the same cost). Here are the links below.
Here is the link to the Plantronics 510 replacement headset.
Here is the link to the Plantronics Voyager Pro+.
Aug 25, 2011 | Plantronics 510 Voyager Headset - PLN-510...
When using the lg Voyager I can hear the person on the other line but they cant hear me .
Try this:
Remove the battery.
Hold power button for 10 seconds while battery is out to fully discharge the power.
Replace battery and reboot phone.
If the microphone still does not work then it would appear that your microphone has broken. You will either need to take your phone to a qualified LG repair place or purchase a new phone.
Jul 20, 2011 | LG VOYAGER VX10000 Cellular Phone
I have a Plantronics Voyager Pro and it will not take a charge. I plugged the charger into my phone to check it and it does work on my phone except not with my blurtooth. Thanks for your help.
If you have the Plantronics Voyager Pro headset, you should be using the ac adapter that came with the headset ( model 79414-01 ). If the headset will not charge, it could be broken or the internal battery may be worn out. Keep in mind that the Voyager Pro has a one year warranty, and Plantronics will replace it within the warranty period.
Plantronics Voyager Pro Headset
AC Adapter for Voyager Pro Headset
Feb 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
The headset will not charge. If I hold down the black button on the headset for app 15 seconds, the red light comes on the headset but it will sgo off in just a few seconds. Is there a battery in the...
Yes, the headset has a battery, but it's non-replaceable. If you've had it for some time and your battery is going out, you will need to replace the headset. Below is a link for the replacement headset that you can check out:
Plantronics Voyager 510 Replacement Headset
Oct 19, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Everytime i hit the blue button on the desk set i don't hear a dial tone in my head piece
Two things to remember. If you're connected through the handset jack, the handset (receiver) needs to be lifted off the phone to get a dial tone. Secondly, if you're connected through the headset jack, you may need to adjust the configuration dial (round dial on left-hand side of base) to make it work when the headset button on phone is pushed.
Aug 24, 2010 | Plantronics Voyager 500A Deskphone Adapter...
With full tank of gas the gauge go's full for a couple days then around half a tank the gauge reads empty 1993 voyager
It sounds like the sending unit has a dead spot on it causing it to read inaccurately. The tank would have to be dropped and the sending unit replaced. Check out this page and illustration to better understand what's going on. "How a fuel gauge works"
Aug 06, 2010 | 1993 Plymouth Voyager
Touch screen on lg voyager stopped working
Does it have an after market plastic cover? If so they sometimes touch one part of the screen making it non responsive. On a day it does work try recalibrating the screen.
Sep 08, 2009 | LG VOYAGER VX10000 Cellular Phone
Just replaced the fuel pump and fuel filter in my 1997 P- Voyager
Fuel Pump relay, Fuel Pressure Regulator may be faulty. A relay can be tested with multi-tester, and a pressure tester for regulator.
Jul 27, 2009 | 1997 Plymouth Voyager
LG VOYAGER VX10000 Cellular Phone Logo
88 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
