I have a Intel DG41RQ motherboard with Intel core 2 Quad processor. I have a 2 GB RAM 800Mhz. When i tried to upgrade my ram by putting another 2GB of 800Mhz, i get beeps and my system shuts down. I dont have problem with both the rams individually.
  • 32,281 Answers
The RAM modules maybe incompatible.
Try using the same make and speed RAM modules.
Posted on Dec 30, 2012
  • sujaiillusio
    sujaiillusio Dec 30, 2012
    I will try buying a RAM of the same make.. I tried using same speed still i get the beeps.
5 Suggested Answers
  • 50 Answers
SOURCE: I am trying to remove a and replace the motherboard in my desktop pc. I have quad core processors. How do I fit and get the pc to recognise the new board and processors?
If the motherboard you bought did not come with a processor and heatsink, you will have to take the one from your current system and put them in the new one. You will also need thermal paste for this transfer, so please purchase some if you do not have it already.
Keep in mind that no versions of Windows XP can use more than 4 GB of RAM, and only the 64-bit version of Windows Vista can correctly use it. If you are still intent on replacing the board after knowing this, follow these directions.
You're going to want to be very careful with this kind of procedure. Ensure that everything is unplugged and that you are working in a static free environment. (Not on the carpet!)
First, you'll want to take out the power supply. Follow the cables down, and disconnect them from each of the components it powers. The connections for the motherboard will have retention clips, so be careful. Once you have the connections undone, take a screwdriver and remove the power supply from the case.
Next, look to see if the hard drives hover over the board in any way. If they are not in the way, try not to remove them. We want as little re-assembly as possible.
You're going to want to disconnect the cables for the hard drive(s) next. Remove them from the motherboard, keeping an eye on which cables went where. The same goes for the cables from your DVD/CD drive(s).
Next, take a look at what's connected to your board. Are there any expansion cards? If so, unscrew them from the back of the machine, and carefully lift them out. If there is a videocard in the machine, watch for a retention clip - make sure not to force the card out.
After everything is out, look around. Make sure that there are no fans connected from the case to the board, and if there are, unplug them. Lastly, take the wires running from the front of the case to the bottom area of the board, and disconnect them. Please notice if there are labels on them.. you will need to hook them up according to your new board's arrangement.
Once you're sure that nothing else is connected to the board, start unscrewing it from the side of the case. On most boards, there will be six screws for this. Please make sure you get them all. Once this is done, you can lift the old one out. Most people do this by pulling up on the heatsink fan over their processor. I also suggest lifting by the sides of the board itself. It may tug where the back panel with the keyboard/mouse/USB ports are.. Just lift the board on the upper right side and angle it out if it does.
Once you have the old board out, set it somewhere safe. Remove the heatsink. This will be a forceful procedure.. You'll need to lift the rentention clip and lift it off.. Wipe the old thermal paste from the bottom of the heatsink. Go back to the board, and lift the small lever that is next to the processor. You should be able to lift it out, be very careful with the bottom!
Clean the processor, and get the excess thermal paste off. Lift the retention bracket next to the socket of the new board, carefully lining the processor up and setting it down gently. Lower the bracket.
Apply a small bit of thermal paste to the processor. Spread it evenly, making sure there are no gaps or globs. Take the heatsink, align it with the socket, and gently lower it on top of the processor. Lock the heatsink back down, and let it set for a bit to get the air bubbles worked out from the paste. Make sure you connect the fan in the heatsink to the board!
If the metal shield around your keyboard/mouse/USB ports matches your new board, you can leave it in. Otherwise, replace it with the one that came with your new board. Look at how the screws line up with the newer board.. If it matches the gold posts (standoffs) in your case, then you can lower the board back in the same way you lifted the old one out, and gently set it down. It will take some work to get it properly aligned with that metal shield.
Once you have it set down, begin to screw the board down. Make sure ALL of the holes are filled - you don't want anything to short out. Begin with the wires from the front of the case. They are called "front panel" connections, and a guide to hooking them up should be in your motherboard's manual.
Connect the fans back up to the board, and reinstall the power supply, reversing the directions I gave earlier. Leave out the extra expansion cards for now, and if the board has a video port near the keyboard/mouse, leave out the videocard, too. If it doesn't have its own video port, go ahead and put your card back in. Install the RAM.
Connect the power connections from the power supply back up to the board, hard drives, and DVD/CD drives. Take the cables from those drives and reconnect them to your new board. From here, you should be able to turn the system on.
Your system WILL freak out. There is new hardware attached, and it won't have the drivers. Just cancel when it tries to look for them, and then run the CD that came with the motherboard to get everything installed and working. Once you're sure everything's going to be working alright, turn off the machine and reinstall the extra cards.
This is a very bland guide. If you have more specific questions, don't hesitate to ask.
Posted on Apr 09, 2008
  • 96 Answers
SOURCE: 2 GB DDR2 on Gigabyte GA-MA78GM-US2H Motherboard
Hello
That's normal condition. Probably your RAM shares it's capacity with internal video card (which uses the whole 256MB)
More info can be found on Wikipedia:
http://en.wikipedia.org/wiki/Shared_Memory_Architecture
Posted on Jan 25, 2010
  • 11800 Answers
SOURCE: i have intel core 2
Yes, perfectly fine. read this:
http://downloadmirror.intel.com/17250/eng/DG41RQ_TechProdSpec.pdf
Posted on Nov 08, 2010
  • 2385 Answers
SOURCE: i want to upgrade my
The below is the contents of Intel published for your board
Intel Desktop Board D102GGC2 Technical Product Specification
System Memory The board has two 240-pin DIMM sockets and supports the following memory features: • 1.8 V (only) DDR2 SDRAM DIMMs with gold-plated contacts • Unbuffered, single-sided or double-sided DIMMs with the following restriction: Double-sided DIMMS with x16 organization are not supported. • 2 GB maximum total system memory. • Minimum total system memory: 128 MB • Non-ECC DIMMs • Serial Presence Detect • DDR2 533 or DDR2 400 MHz SDRAM DIMM
hope it helps, if so rate the solution
Posted on Nov 16, 2010
E5200 drivers
Hello the drivers can be downloaded here:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+4+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG41RQ
But first select your windows system.
And heres the ram support:
http://www.intel.com/support/motherboards/desktop/dg41rq/sb/CS-029920.htm
Your mainboard supports DDR 2 ram, up to 8 gb.
Please select a quality brand, the cheap ones does not last long.
Good luck
Jun 24, 2013 | Intel DG41RQ Motherboard CPU Bundle - ...
Which is the best graphic card for intel DG41RQ mother board
I have a motherboard intel dg41rq and intel core 2 duo E7200 and nvidia geforce 9500 GT and 4gb ram (DDR3).It will work with call of duty black ops 2 and FIFA 13.So your done.
Oct 02, 2012 | Intel DG41RQ Motherboard CPU Bundle - ...
Intel dg41rqi not working
The RAM module is either incompatible or faulty or not seated properly.
Mar 25, 2012 | Intel DG41RQ Motherboard & Core 2 Duo...
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
Fiteed new quad core CPU and 4gb of Ram, when started up getting no signal detected on the monitor. Can anyone help?
Let's back up a second.
A) What HP model is it? (P/N. Product Number. Back of desktop computer tower)
B) What model number of Intel quad core is it?
C) What are the manufacturer ID number/letters on the ram memory module/s?
I need to know what Northbridge chip is used on the motherboard, to know if it will support the particular Intel quad core you're trying to use.
This I can hopefully obtain from HP Support, by looking at the specifications for the motherboard.
(This technology does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge chip is part of the motherboard chipset.
So aptly named, because on a desktop computer motherboard it sits to the 'North', for one.
(Under the Processor)
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
AGP and PCI-Express are high-speed graphics technology.
A graphics card plugged into a PCI slot, and Integrated Graphics, is Not high-speed graphics.
The Southbridge chip handles the slower capabilities of the computer.
Motherboard Diagram;
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
List of Intel Chipsets, and more specifically the one's that can handle Intel quad core processors,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
Secondly;
Make sure the Ram Memory you installed is Compatible.
If the motherboard supports 4GB of ram, make sure it is in the correct ram slots if using two sticks of ram, or four sticks.
There HAS to be a ram memory module ('Stick') in Slot 1. (DIMM 1)
EACH ram memory slot has a Maximum Amount.
For example if there are 4 ram slots, and the Maximum Total Amount of ram memory is 4GB, each ram slot may have a maximum of 1GB.
It may, or may not be that you can use Slot 1 and Slot 2, and use two 2GB sticks.
Third:
Always go slow when upgrading.
Install the Processor first, boot the computer up, see how it works.
THEN shut the computer down, unplug from power, observe Anti-Static Precautions, and install 2GB of ram memory.
Works?
Install the other 2GB.
BIOS has to recognize the changes.
Fourth:
Are you sure your Power Supply is adequate to support the quad core, and the added ram memory?
Post back in a Comment.
Regards,
joecoolvette
Jul 24, 2011 | HP Computers & Internet
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Computers & Internet
I have a laptop of compaq brand whose modle no is presario C700 in which intel celeron microprocessor is installed. 512 MB ram is installed i want to update it 4 improving its speed. i want to setup a...
I found the manual on the net that gives you instructions on replacing components if you're not sure how, it can be found here.
RAM upgrade
The Compaq Presario C700 uses DDR2 Laptop RAM as shown below.
slasher_x_11.jpg The motherboard of the Presario C700 has two RAM slots, one of them will be occupied by the 512MB RAM (running at 667MHz) module you have at present. This leaves one more that can accomodate a DDR2 667Mhz card of up to 1GB or you could get two 1GB DDR2 800MHz (the faster DDR2) cards and remove the 512 leaving you with a wopping 4GB of memory, that'll definately speed it up. Just remember the Presario C700 can only have up to 2GB of RAM so don't go higher than that or Windows will not boot for some reason.
Processor upgrade
The Presario C700 supports any Socket P, Core 2 Duo or Pentiun Dual Core chips. The fastest processor you can get is the Intel T8300 2.4GHz Core 2 Duo Processor with 3MB L2 cache and an 800MHz FSB
For a full list of compatible processors go to page 9 of the user manual found here.
Jan 11, 2011 | HP Computers & Internet
I want to upgrade my system ram size to 2gb...my system memory configuration as follows mother board: intel102ggc2 system bus speed :800mhz processor (p4):3.0ghz ram slots available:2 and presently i'm...
Nov 16, 2010 | Intel D102GGC2 Motherboard
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
