Question about Jabra BT620s Consumer Headphones
Jabra bT260s Pairing problem...
I just purchased the Jabra bT260s. They are fully charged. I also purchased a bluetooth dongle from amazon.. http://www.amazon.com/gp/product/B0019SI266. With the software that came with the dongo I can recognize my headphones and it has them paired, but I don't hear anything from my Pc. I have played music using windows media player and tried everything. I can hear the hardware noises inside the Jabras when I press one of the hardware buttons, but I don't hear any music. Please help!
You may need to change your output sound device. The method may vary depending on your software and hardware, but go to Start -> Control Panel -> Sound (I think. Doing this from memory, so might be slightly off). There should be a Devices or Output tab. Change that to your bluetooth headset. You will probably need to restart WMP before you hear music, too.
Posted on Oct 23, 2009
The freeway does not respond to any phone commands
Be certain that your bluetooth is fully charged, then be certain you follow BOTH your phone's and your bluetooth devices instruction for pairing.
Exactly what phone commands are you trying to get your bluetooth device to respond to?
Apr 02, 2015 | Jabra Freeway Hfs100 Bluetooth Wireless...
Cant pair my iPhone with jabra sp5050
forget the headset
turn bluetooth off
turn the headset device off
reboot phone.
try again
Mar 04, 2014 | Jabra A320s Bluetooth Wireless Adapter
I have it pair to my I phone ----but I lost my manual what are the buttons for?
Follow the instructions mentioned below to resolve the issue:
  • Charge the headset
  • Charge your Jabra VBT185Z until the solid LED turns off
  • (approximately 2 hours)
  • Turning the headset On and Off
  • Press the answer/end button until you see a burst of flashes on the
  • indicator light (LED) to turn your headset on or off.
Headset Pairing Readiness Instructions:
1. Fully charge headset for two hours.
2. The headset will automatically go into pairing mode if no device has
been previously paired.
3. Set your mobile phone to 'discover Jabra VBT185Z'.
4. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK.
For online pairing assistance visit www.verizonwireless.com/bluetooth.
Hope the above steps allows you to resolve the issue. Please revert back for any further clarification.
Regards
Anand
May 10, 2011 | Jabra VBT185Z Bluetooth Headset
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
Dec 26, 2010 | Jabra BT150 Wireless Headset
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Charged earpiece doesn't communicate with cell phone
My advice would be to re-pair the two devices. In the Bluetooth menu on you phone find 'paired devices' and delete the headset from the list. Next you will need to put the Bluetooth headset into pairing mode. Make sure it is switched off and then press and hold the power button on the headset and keep pressing it ( some headsets need to also have the up volume button pressed at the same time). What should happen is either a solid blue light of alternate flashing of two colours. (pairing mode varies on different headsets and you made need instructions or call Jabra) At this point on the phone in the Bluetooth menu search new devices. It should find your headset and request pairing code. Code should be '0000' or some headsets use '1234'. This should now set up a fresh pairing and work again. Hope that helps.
Apr 23, 2009 | Cell Phones
I have a Jabra set, but my Motorola Krazer can not find it
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for around 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Jabra device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 16, 2009 | Jabra BT350 Bluetooth Headset Headset
Cant par my jabra bt125
First make sure your bluetooth and your phone are fully charged. Next press the on - off button in the middle of your bluetooth until it is a solid blue color. If it is flashing it is not in the pair mode. Just hold it down until it is a solid blue light.
Then set your phone to the pairing mode following your phones set up bluetooth instructions. Select the discover, search, or add function on your phone. Your phone should find the bluetooth device and ask "do you want to pair with it?" Accept by pressing yes or ok on the phone and entering the passkey or pin # of 0000 or 4 zeros.
Your phone should confirm when pairing is complete.
I discovered that I was not holding the on-off button down long enough for my bluetooth to reach the pairing mode and give me a solid blue light.
I hope this helps as I know how frustrating this can be.
Jan 15, 2009 | Jabra BT125 Headset
Jabra bluetooth headset
how do I set up the phone to discover jabra vbt185z?
Dec 29, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT620s Consumer Headphones Logo
713 people viewed this question
Top Jabra Audio Players & Recorders Experts
Tom Chichester
Mister Danger
Jeff Tilburn
Jeff Tilburn
Are you a Jabra Audio Player and Recorder Expert? Answer questions, earn points and help others
