Question about Dryers
Gas Dryer will heat once only during the cycle
Kitchen Aid KGYS750JQ2 will ignite during the beginning of the cycle if it is cool. If it is still warm, will not ignite at all. I tried jumpering all the sensors one at a time, can't isolate it. Is there a sensor down by ignition module (under drum) that might cause this?
Mark
  • mokopny Jan 18, 2009
    That's probably it. Pretty mechanical, but I'm worried about investing $75 and the odds of getting the front back together without messing up drum and alignment.
  • 640 Answers
Defective gas coils,,replace gas coils..
Posted on Jan 18, 2009
  • onthethejob1
    onthethejob1 Jan 18, 2009
    gas vavle coils,,srry,,,
Quietpak 4 gas dryer. Why does it heat for about 4 minutes, then shut off?
Could be a faulty igniter, thermocouple, and/or gas valve
May 26, 2015 | Dryers
Self cleaning Kitchen aid oven
Hi there
Could it that one if the small fuses have gone?
Take a lookkolbrun
Apr 18, 2012 | Kitchen Ranges
Gas Dryer has heat at beginning of cycle then no heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 05, 2010 | Whirlpool LGR3624JQ Gas Dryer
Kitchen aid kgys750gq0 works but there is no heat
The KitchenAid KGYS750GQ0 is a gas dryer, so the solution of looking for a heating element is not helpful. There are several heat switches and a gas burner assembly (which includes a gas valve and an electric ignition), any of which could be the problem.
May 15, 2010 | Dryers
Kitchen aid dryer / heat flame not staying on after 20 secs
Sounds like your gas valve is fine, if it comes on at all, its good. A air flow restriction would cause a overheat condition and shut down the burner. Once it cools back down the burner would re-ignite and repeat the cycle. The sensor on the left of the burner is the flame sensor and the flame wouldn't come on at all if it was bad. You've already changed the coil kit so the valve is fine, disconnect the vent from the back of the dryer and see if the problem goes away. If the problem stays, I would suspect the thermostat. Good luck.
Mar 16, 2010 | KitchenAid Dryers
My kitchen aid gas dryer is not heating up.
If it is tumbling. This troubleshooting video will help. Could be the thermal fuse,ignitor,or gas coils. The free video will walk you thru testing.
www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | KitchenAid Dryers
Ignitor won't ignite after working for 2-5 min
Your fuel supply is OK?
If the igniter comes on and you have fuel, there is no problem ... for some reason you dont have fuel, seems to me.
Did you check the gas valve(s). There nay be several.
If you have gas and the valves are on ... you have an electric (gas relay valve) problem.
Sep 27, 2009 | Dryers
Kenmore model #78702895 78702 front load natgas dryer : ignites and heats at beginning of cycle, then cools cycle continues without heat
replaced both the black coils on gas burner they will sometimes go bad after first heat cycle
Dec 05, 2008 | Dryers
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
131 people viewed this question
Top Dryers Experts
