Question about Acer Computers & Internet
Can't install windows
Windows could not complete the instalation . To install windows on this computer restart the installation This comes on the screen
  • Acer Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Dec 29, 2012
bpcs
  • 112 Answers
SOURCE: brand new v5535 notebook won't set up keeps coming up with error
Try pressing the F8 key while booting, at the boot option page select the last known good configuration and boot from there. If this does not work, press the F8 key while booting and choose boot in safe mode, then go to start/programs/accessorys/system tools/system restore. choose a date that the computer was acting normal and restore to this date. If this does not work do a reinstall with the system restore disk and drive/application restore disk. BPCS
Posted on Dec 30, 2007
gnkanang
  • 63 Answers
SOURCE: Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Posted on Mar 25, 2009
Rossiman46
  • 50 Answers
SOURCE: Problem with Installation of Windows 7 on Acer Laptop
Have you checked with Acer that your pc can accept Win 7.0?
if its not compatible then you may be floggin a dead horse with it, I doubt there will be many Win 7.0 drivers available yet for older systems but you may be lucky.
Posted on Nov 09, 2009
mirzausman
  • 129 Answers
SOURCE: computer restarted unexpectedly or encountered an
Please explain the error. Mostly its because Windows couldn't access some particular area in RAM.
Posted on May 12, 2010
SOURCE: I have an an acer aspire 5336-2524 i tried to do a
You can try using a different Operating system disc.. completely format the hard derive before reinstalling the Operating System..
Thank you
Posted on Apr 29, 2011
Set up failed after down loading files to restart
This is usually a RAM issue. The files did not read correctly. try different RAM, boot off the DVD again and try again. Usually works.
Jan 04, 2015 | Computers & Internet
Err msg "windows unable to complete installation. to install windows on this computer, restart the installation."
Order the CD from the manufacturer or you are going to have to download a program to wipe the active partition (c)
Jul 21, 2013 | Gateway Computers & Internet
Windows 7 installation never-ending loop
andrew it can be a microsoft update.which was pulled back some days
ago.KB/2823324 i dont say it is,only it can be.
Apr 16, 2013 | Acer eMachines Black EL1352G-41w Desktop...
During restore windows i found error "Windows could not complete the installation. To install windows this computer, restart the installation.
Reboot windows without any CD in drive and tap F8 key before windows screen appears. Select safe mode from the menu that appears and elect to do a system restore.
If this doesn't work you could try changing the boot order in the bios ensuring that your hard drive is first boot device. should get into bios when starting PC usually F2 or del key. remember to save changes in bios normally F10
Oct 13, 2012 | eMachines E730, Core i3-330M 2.13GHz,...
My computer keeps saying windows cannot complete installation. To install windows on this computer restart the installion have tried this nothing's working help
The way you state the problem makes me think you are trying to reinstall Windows. If this is the case, I'd suggest reformatting the hard drive before installation. There seems to be something left over from the old system that is preventing the install from completing.
If you have a "clean" hard drive and the install fails, there is a good possibility that there is a memory problem. A bad memory stick will cause the install to fail.
So--do the clean install first and if that fails, try replacing the memory or at least swapping out one or the other of the memory sticks.
Apr 20, 2012 | HEWLETT-PACKARD TouchSmart 9100 PC Desktop
I up graded my pc to windows 7 ultimate. i have a Hp laserjet 3015 and cannot seem to make the scanner work
Chances are the printer didn't come with drivers for Windows 7.
If you have Windows 7 Ultimate x32/86, click here.
If you have Windows 7 Ultimate x64, click here.
Install the appropriate driver on your computer and it should work. Best of luck!
Jul 19, 2011 | Computers & Internet
When I power the computer on, I'm getting an error message that says, windows could not complete the installation. To install windows, please complete installation and restart computer. How can I fix...
    • If the computer has a single operating system installed, press and hold the F8 key as the computer restarts. You must press the F8 key before the Windows logo appears. If the Windows logo appears, you must restart and try again.
    1. In Advanced Boot Options, use the arrow keys to select Repair the computer, and then press ENTER. Click a keyboard layout in the list, and then click Next. Click a user name in the list, enter the password, and then click OK. In the System Recovery Options menu, click Startup Repair. When the repair process is complete, click Finish.
    2. Hope this works!
    Jul 04, 2011 | Computers & Internet
    I did recovery manager. When it restart den it says ((The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install Windows, click ''OK'' to...
    The previous windows installation is either damaged, or did not complete, it is asking you to put your windows disc in so that in can proceed with the installation.
    The recovery manager must have damaged your windows installation
    Sep 05, 2010 | HP Pavilion dv6000z Notebook
    Computers & Internet Logo
    16 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
