Question about Octane Fitness Q47ci Elliptical Trainer
Replace octane q45 stride motor - Octane Fitness Q47ci Elliptical Trainer
Where is fuse for cigarette lighter in 1997 infiniti q45
Hope this helps
https://www.google.com/search?q=1997+ford+explorer+wiper+motor+wiring+diagram&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjfjN2gmqPVAhUC54MKHf-8DXsQsAQIIQ&biw=1364&bih=642#tbm=isch&q=1997+infiniti+q45+fuse+box+diagram
Jul 25, 2017 | Infiniti Cars & Trucks
How to relearn a sunroof on q45 1991 infiniti
Keith, Could not find a lot on your problem. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
All Infiniti Sunroof Motor Adjustment Repair
http://www.q45.org/techhelp.html
http://forums.nicoclub.com/q45-j30-qx4-sunroof-repair-t288595.html
infiniti q45 sunroof relay
Jun 17, 2016 | Infiniti Q45 Cars & Trucks
Why does my Infinity Q45 idle at 1500 rpm when every thing is connected and there are no vacuum leaks?
If the motor is cold it will have a higher idle. If the battery has a low charge, the computer will tell the motor to rev higher to get the alternator pushing out higher voltage to charge it.
Mar 01, 2015 | 2002 Infiniti Q45
Error 20 on Q47 Octane Eliptical
Sounds like it needs to be fixed. It will need a new left motor and cord most likely, less likely a lower board.
Apr 14, 2013 | Octane Fitness Octane Q47 Elliptical...
Cant remove my starter from 1997 fordareostar
CAR STARTER REMOVAL? TESTING
One Wire From Starter Motor Goes To Solenoid And Other Goes To BATTERY. Starter GETS 12 VOLT SUPPLY FROM BATTERY AND WITH THESE VOLTAGE IT TURNS THE MOTOR AND THIS TRIGGERS THE STARTER SOLENOID AND YOUR VEHICLE RUNS.============
For your help there are few relatively help links showing how to remove and install starter with proper instructions:-----
These help links will help.
Click the link below:-----
How to test starter solenoid? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html -------------------- How to test cars starter? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html ----------- How to replace starter in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
How to replace Starter on Infiniti Q45? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
2006 GM Montana: How to replace Starter Solenoid?
http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
Saturn SL2: How to replace Starter Motor?
http://howtobyme.blogspot.in/2012/06/saturn-sl2-how-to-replace-starter-motor.html
Saturn SL2 Starter Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/saturn-sl2-starter-wiring-diagram.html
Oldsmobile starter solenoid replacement procedure?...
How to replace Oldsmobile starter moor?
Oldsmobile starter motor testing?
Oldsmobile STARTER MOTOR NOISE DIAGNOSIS?
These details will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
How 2 wire a stater on a 2000 chevy cavalier
How to test starter solenoid? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-starter-solenoid.html -------------------- How to test cars starter? http://schematicsdiagram.blogspot.com/2011/06/how-to-test-cars-starter.html----------- How to replace starter in car? http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-starter-in-car.html
-----------How to replace Starter on Infiniti Q45? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-starter-on-infiniti-q45.html
---------- 2006 GM Montana: How to replace Starter Solenoid? http://repairhelpcenter.blogspot.in/2012/06/2006-gm-montana-how-to-replace-starter.html
-----Saturn SL2: How to replace Starter Motor?
------------These details will help.Thanks.
Nov 23, 2012 | Cars & Trucks
Does a starter come out the top of a 2000 infinity q45??? or the bottom????
bottom, but the manual mentions a couple different procedures. See below.
4.1L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Steering gear and linkage assembly Harness connector Starter retainers Starter
To install:
Install or connect the following:
Starter Starter retainers. Tighten the starter retainers to 30-37 ft. lbs. (40-50 Nm). Harness connector Steering gear and linkage assembly Negative battery cable
Alternate procedure:
  1. Remove or disconnect the following:
    Negative battery cable Engine undercover Harness connectors Starter motor mounting bolt and nut
  2. Remove engine mounting insulator bottom nuts, and lift engine approximately 2 inches with a transmission jack
  3. Remove starter motor
To install:
  1. Installation is in reverse order of removal; observe torque values shown in diagram
Fig. Starter motor mounting and torque specifications-Q45 & 2004 M45
Oct 31, 2011 | 1997 Infiniti.5 Q45
I lost my directions and don't know how to change my stride to a lower number.
Manual is here: http://www.sportline.com/manuals/340.pdf
INPUT YOUR STRIDE LENGTH (Range: 12 inches to 60 inches or 30cm to 150cm) 1. Walk 10 steps. 2. Measure the distance that you've walked either from heel-to-heel or toe-to-toe. 3. Divide by the distance covered to arrive at your Stride Length. 4. Example: measured distance 360 inches, number of steps taken was 10 = 36 inches stride length. Important: Please remember that the length of your stride while walking is different than the length of your stride while running. If you plan to use this pedometer for both types of exercise, you will have to reprogram your stride length when you go from one to the other. 5. Press MODE button to reach the DISTANCE MODE showing MILE or KM. 6. In DISTANCE MODE, press the SET button. The display will show previous stride input in Inches or CM and start to flash. You will now have five seconds to start changing your stride length. If you do not adjust your stride length during these 5 seconds, you will have to start step 3 over again. 7. To change your stride length while the display is flashing, press the RESET button. Each press of the RESET button will increase the input by either 1 inch or 2 cm depending on which mode you are in. If you hold the RESET button, the numbers will increase continuously. Release when the display shows the Stride Length for you. 8. Once you have entered your stride length properly, wait 5 seconds - the display will flash and reset the memory - and the display will return to DISTANCE MODE
Dec 31, 2010 | Sportline 340 Step and Distance Pedometer...
How do i install fuel injectors on a 1993
Your problem doesn't make sense to me , but I can almost guarantee you that replacing your injectors won't cure it. I am sitting here trying to figure out how fuel could be getting into your oil and not coming up with an answer. A blown intake manifold gasket , or head gasket would do it , but would cause other very noticeable problems
Apr 08, 2010 | 1997 Infiniti.5 Q45
1992 infiniti q45
motor run ruff and will not ideal
Jun 24, 2008 | 1997 Infiniti.5 Q45
Octane Fitness Q47ci Elliptical Trainer Logo
488 people viewed this question
Top Octane Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Octane Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
