Question about Dell UltraSharp 1905FP LCD Monitor
My DELL external monitor just turned PINK... I can adjust the colors from the legend within the monitor but cannot change it back to the original white display.
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 61 Answers
The nature of your problem not software. This is hardware problem.
Either you have a broken, loose, bent pin in your VGA connector or VGA convertor board in the monitor is damaged. First try changing the VGA cable. If that doesn't work, send it to a repair shop. But compare the price of repair and buying a new one. These days buying is more reasonable than repairing.
But wish you it was only the VGA cable. Good luck.
Posted on Dec 07, 2014
  • 1153 Answers
SOURCE: dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Posted on Sep 14, 2007
SOURCE: Pink tint on Dell 1704FPT Flatpanel LCD
The monitor is broken. The circuits that generate green in the RGB setup are not working. If its under warranty, replace it.
Posted on Aug 22, 2008
  • 3940 Answers
SOURCE: Dell monitor attached to Inspiron 1520 runs landscape (sideways)
try CNTL+ALT+Up arrow/Down Arrow
Posted on Apr 14, 2009
  • 10406 Answers
SOURCE: dell monitor 152fpc orange coloring replacing red
If you connect the monitor to a laptop's "video-out", do you get correct colours, or do you still get the "orange" ??
If so, then the monitor is the problem.
Posted on Apr 23, 2009
budmrtn
  • 11361 Answers
SOURCE: Monitor display on Dell E176FP
You may loose connections at the end of the VGA cable, or video card not seated tightly. I would check that first.
Posted on Apr 23, 2010
Testimonial: "Thanks! You put me on the right track!"
PINK Laptop screen
1. Plug in an external monitor to your laptop. If the picture on the external monitor is good, then the problem is your laptop screen. If the external monitor also displays a pink screen, the problem is in your laptop hardware or software.
  • 2 Contact Dell if your computer is still under warranty when the problem is with your screen. If your laptop is not covered by warranty, contact a computer repair shop to have the screen repaired or replaced.
  • 3 Update your drivers and bios. Outdated drivers or bios have been known to cause screen issues. Visit Dell's Drivers and Downloadsicon1.png website where you can enter your service tag and find the appropriate updates for your computer.
  • 4 Contact Dell's technical support team if the above steps do not fix the pink screen. Dell has had known issues with the pink screen being caused by the graphics card on some of their laptopsicon1.png. In many cases, replacing the motherboard is necessary to remedy the problem.
  • Read more: http://www.ehow.com/how_6318059_fix-pink-screen-dell-laptops.html#ixzz2n6yCxzw5
    Dec 10, 2013 | Dell Latitude E5500 Laptop
    I made adjustments to my monitor to change the brightness but now all my monitor has a pink tinge to it and all my photos in photoshop are pink. How can I set the monitor back to the factory settings
    sound like a loose connection, check all your cables and make sure they are securely attached to your computer and also the back of your monitor, if problem persist try going to the degauss menu and degauss the monitor, check to see if your color settings are properly configured, also check the color temperature. If none of these suggestions worked your monitor may have a more server problem, hope this helps, best of luck
    Feb 06, 2011 | LG 22" FLATRON LCD Monitor
    My dell inspiron 1525 screen is turning pink in color when ever i restart it this process is from booting itself not in operating system what might be the problem with it?
    Hi Friend, In this case I would recommend you to please try and connect any external monitor to the system and check if you have the same issue with the external monitor also, so, that we can check if the issue is with the hardware or with the software.
    Dec 09, 2010 | Computers & Internet
    My laptop monitor goes dark
    Hi there! Try this trick...
    You can adjust the screen brightness within BIOS set up...
    It works with Dell!!!
    ^_^
    May 13, 2010 | Dell Inspiron 6400 Notebook
    Pink flashing band down the middle of the screen
    Hi:
    You most likely have a bad LCD panel on your laptop, and to verify that is the problem, connect up a desktop monitor to the external VGA connector, and toggle to the external display. If it has a good display on the external monitor, you have a bad LCD panel. If the color band is still showing up on another monitor, you have big problems!
    Mar 24, 2010 | Dell Inspiron 1501 Notebook
    Display problem with colors
    Check the display on the external monitor. if the display if fine, you lcd needs to be replaced. if the display is the same, your computer mother board has gone bad.
    here is what you can also try before calling Dell.
    Turn off your computer.
    now, press and hold the Fn button at the bottom left hand corner. and then turn on the computer. kepp holding the Fn key down untill you see Pre boot self assesment. it will check all the hardware problems in the computer. After 2 minutes it will show you a rainbow. if the colors are fine press Y else press N. it will give you an error code. call dell and give the error code and get the LCD repalced.
    Sep 24, 2009 | Dell Inspiron 6400 Notebook
    LCM-22w3 monitor suddenly changed colors. All
    Try adjusting the monitor cable that goes from your monitor to the back of your computer.
    Jul 10, 2009 | Westinghouse Electric LCM-22W2 Monitor
    Cant figure out color issue with computer.
    Well...it's a Dell and even when it's well...it's still a Dell.
    Have you tried the monitor on different system to eliminate the tower being the problem? Some have updated and/or rolled back drivers to help cure this problem, which seems to be a common issue with this LCD. Personally i think the contrast ratio is inadequate.
    Good luck with your Delllll...
    May 14, 2009 | Dell E176FP 17" LCD Monitor
    My averatec 3200h stopped
    maybe your external monitor is faulty.
    old monitors usually have color problem.
    try with a good working monitor.
    then you will know if it is the monitor or you external port problem.
    good luck
    Mar 13, 2008 | Computers & Internet
    Dell UltraSharp 1905FP LCD Monitor Logo
    110 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
