Question about Epson ACULASER CX11NF All-In-One Printer
Epson aculaser cx11nf Error --E OPEN -- That door is closed I opened and closedit many times and it stil says same thing. I turned the printer on and off several times and it still has the same error. Where is the swich that controls the E doore located -maaaaaybe I can by pass that switch. Can anyone help help
SOURCE: B door open
There are two switches, so if you changed the one that was working....
Possible parts affected could be
- cover top
- cover fuser
- cover front assembly
- the switch
1) check the condition of the cover - top, front assembly and cover fuser closed?
2) on the cover top there is an "actuator", a plastic bit, which presses down on the switch assembly top - is that plastic bit broken, bent or deformed?
3) on the cover front assembly there is also an "actuator", check this
4) and of course same for the fuser cover
5) top cover, check the switch, disconnect the switch (P116-1) and press/release it - does that make a difference. If not replace switch
6) same procedure with the switch (P115-1) for front cover.
Posted on Feb 06, 2008
SOURCE: epson aculaser cx11nf MP E paper jam
open the mp tray
locate 2 white plastic egg shaped piece on the ends of the steel rod
gently push one or the other towards the back of the machine
if the paper jam error message is on then the roller will turn as soon as you give it a push
re load the paper
open and close door a or e
printing should resume
that white piece works with the paper lift to get the paper up to the in feed roller
Posted on Sep 16, 2008
hdsportyem
  • 11 Answers
SOURCE: Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Posted on Feb 18, 2009
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Posted on Apr 06, 2009
  • 11 Answers
SOURCE: EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
Posted on Sep 06, 2009
Epson c1100 e door open
Just solved the same problem. It is a very slight misalignment of the two rollers behind door E. I closed door E holding the vertical bar below the handle and just 'jiggled' it slightly from side to side, and it latched closed. Paper jam fixed, yippee!!
Mar 23, 2013 | Epson Aculaser C1100 Printer
Epson ACULASER CX11NF paper Jam error every time I print
you may wanna check if the paper that your using is a laser paper, check the mp tray, reload the paper and check the settings on your computer using thicker needs to match the setting on your driver you may also wanna check if your printer can do a stand alone copy so that we can identify if this a hardware issue or a driver issue.
hope this will help u
May 10, 2010 | Epson ACULASER CX11NF All-In-One Printer
How do I fix a paper jam cef for epson aculaser cxn11nf?
Diagram of doors should be above control panel of printer.
Lift ADF/Scanner up. Open door "C" just below it. Lift orange photoconductor lever up to release photoconductor. Lift photo conductor up towards you. Inspect for jammed paper and remove if necessary. Replace photoconductor, close lever and door "C".
Open door "E" on rear of printer and look for jammed paper and remove. Close door "E".
Last place to look is in paper tray. Take stack of paper out and look for paper jam. Removed as needed.
These are the three places i have had jams and you will only find the jam in one of them. Most likely it will be in back in Door E
Aug 12, 2009 | Epson ACULASER CX11NF All-In-One Printer
Light print on right side of page
from what you are saying, if color is fine and black is not, its most likely the black drum that is the problem. the toner is part of it. try taking the black toner out and shaking it, and putting it back in, if it still does not help, most likely it is the toner/drum.
thanks adi
May 05, 2009 | Epson AcuLaser CX11N All-In-One Printer
Thanks
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
Epson aculaser c9100 error code Eo86
After a repair person came and worked on the Epson Aculaser CX11NF, I have vertical line, full lenght across every printed page
Oct 08, 2008 | Epson AcuLaser C1900 Printer
Epson aculaser cx11nf MP E paper jam
open the mp tray
re load the paper
Sep 01, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson ACULASER CX11NF All-In-One Printer Logo
119 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
