Question about Panasonic Lumix DMC-FZ20 Digital Camera
Problems taking TIFF photos
I just returned from two weeks in China where I took numerous TIFF photos - only to return and try to view them - and they turned up as green - almost "color photo negative" type coloration. The images also seem to be "cut" on the right - with about 20% of the impage "wrapped" to the left side. The "low res" images look great - but at a MINIMAL megapixel size. 1) Has anyone seen similar issues? 1) Is there any way to view/use the high res images that seem to be defective? 3) Are there settings that I have screwed up which caused this situation? Advice??
There is a known issue with using 2GB SD cards on the FZ20. There are scripts online to assist with getting the images corrected. Here is a link,  http://www.flickr.com/groups/fz20/discuss/72157594149365564/#comment72157594507413493
Posted on Nov 16, 2007
I have seen similar problem on one of the SD card. Tried another SD card and it works fine with TIFF. I think it is related the the SD card compatibility.
Posted on Jul 12, 2007
Good day I have a Lumix DMC- FZ20 When I put the settings on Tiff and the pic size on 2560 the camera outomatically create a jpg file as well. The Tiff file is very bic, about 14MB and looks like a...
I have this camera, and like you I have taken photos in the Hi-resolution TIFF mode. What you are experiencing is not a camera problem, but a problem with the software you are using to view the pic. Tiff is an odd format that can be configured in different ways and not all viewing software understands all the different configurations. The viewer I use is called Faststone, and can be downloaded for free from the internet- try at www.downloads.com
Faststone displays my FZ20 TIFF files perfectly. They are very big (14Mb) though, and there is little advantage over the jpg if you use the high quality compression setting.
Dec 13, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
Donwload multiple files from server to client using asp.net
Sir,
//To Get the physical Path of the file(me2.doc)
string filepath = Server.MapPath("me2.doc");
// Create New instance of FileInfo class to get the properties of the file being downloaded
FileInfo myfile = new FileInfo(filepath);
// Checking if file exists
if (myfile.Exists)
// Clear the content of the response
Response.ClearContent();
// Add the file name and attachment, which will force the open/cancel/save dialog box to show, to the header
Response.AddHeader("Content-Disposition", "attachment; filename=" + myfile.Name);
// Add the file size into the response header
Response.AddHeader("Content-Length", myfile.Length.ToString());
// Set the ContentType
Response.ContentType = ReturnExtension(myfile.Extension.ToLower());
// Write the file into the response (TransmitFile is for ASP.NET 2.0. In ASP.NET 1.1 you have to use WriteFile instead)
Response.TransmitFile(myfile.FullName);
// End the response
Response.End();
private string ReturnExtension(string fileExtension)
switch (fileExtension)
case ".htm":
case ".html":
case ".log":
return "text/HTML";
case ".txt":
return "text/plain";
case ".doc":
return "application/ms-word";
case ".tiff":
case ".tif":
return "image/tiff";
case ".asf":
return "video/x-ms-asf";
case ".avi":
return "video/avi";
case ".zip":
return "application/zip";
case ".xls":
case ".csv":
return "application/vnd.ms-excel";
case ".gif":
return "image/gif";
case ".jpg":
case "jpeg":
return "image/jpeg";
case ".bmp":
return "image/bmp";
case ".wav":
return "audio/wav";
case ".mp3":
return "audio/mpeg3";
case ".mpg":
case "mpeg":
return "video/mpeg";
case ".rtf":
return "application/rtf";
case ".asp":
return "text/asp";
case ".pdf":
return "application/pdf";
case ".fdf":
return "application/vnd.fdf";
case ".ppt":
return "application/mspowerpoint";
case ".dwg":
return "image/vnd.dwg";
case ".msg":
return "application/msoutlook";
case ".xml":
case ".sdxl":
return "application/xml";
case ".xdp":
return "application/vnd.adobe.xdp+xml";
default:
return "application/octet-stream";
Thanks
Good Luck
Aug 17, 2009 | Microsoft Designing ASP.NET Applications...
Green images on LCD and Green on PC once uploaded
White balance settings may be changed. Go to the menu select WHITE BALANCE then select AUTO in it , then OK then return, now try.
Mar 22, 2008 | Nikon D40x Digital Camera
Menu Problem
Did you try calling Canon tech support or returning to retailer if the camera is really not functioning properly this soon after purchase, I'd try returning it once all troubleshooting issues have not resolved the issue.
Hope this helps!
Feb 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Camera slow
you must have changed the option to store the images in .tiff format so while storing in tiff format it compresses the image so it takes time for u ... so i suggest u to change that setting to .jpg uncompressed mode by doing this though it takes more space and allows u to store less photos in memory but it will fast while storing ...
in .tiff format as it compresses the image it takes time but the memory usage will be low this allows u to store more photos...
Feb 11, 2008 | Nikon Coolpix S51c Digital Camera
Lines in my photos
Looks like an incompatibility with the camera and the Speedlight- Synchronization not as it should be Check out both manuals If still in trouble Nikon Technical support may point the way
Jul 28, 2007 | Nikon Coolpix 8700 Digital Camera
Problem
If this is the first batch of images then there would appear to be a fault with the Camera or the Card to check it out following the manual- Format the card. Take a test batch of images Try a read back or an upload to computer. This will establish if it is the card or the camera. returner either or both to the seller for replacement
Jul 24, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
175 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Jay Plesset
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
