Question about Dell E173FP 17" LCD Monitor
My DELL external monitor turned pink
It just turned pink... I can change the hue by the legend on the monitor but cannot get it back to white or original color.
  • 1153 Answers
SOURCE: dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Posted on Sep 14, 2007
GregL
  • 49 Answers
SOURCE: The laptop starts up with a pink hue
Make sure the LCD is completely attached to the system board. I've had them come partially out and cause this. If this doesn't help, your LCD and/or inverter could be going bad.
Posted on Dec 31, 2008
  • 3940 Answers
SOURCE: Dell monitor attached to Inspiron 1520 runs landscape (sideways)
try CNTL+ALT+Up arrow/Down Arrow
Posted on Apr 14, 2009
  • 10406 Answers
SOURCE: dell monitor 152fpc orange coloring replacing red
If you connect the monitor to a laptop's "video-out", do you get correct colours, or do you still get the "orange" ??
If so, then the monitor is the problem.
Posted on Apr 23, 2009
pravinbhavsa
  • 348 Answers
SOURCE: monitor color
replace signal cable your problem will be solved if persist then open the monitor and find out the dry solder and clear it
Posted on Apr 13, 2010
Pinks squares on Dell laptop screen
Try connecting to an External Monitor via the VGA Port, if Ok on a known good monitor then ONLY the Screen is faulty, if pink squares show up on the external monitor than video chip (Graphics inside the Laptop and on the Motherboard OR cable from motherboard to Screen, see how you go.
May 01, 2013 | Dell Computers & Internet
My DELL external monitor just turned PINK... I can adjust the colors from the legend within the monitor but cannot change it back to the original white display.
The nature of your problem not software. This is hardware problem.
Either you have a broken, loose, bent pin in your VGA connector or VGA convertor board in the monitor is damaged. First try changing the VGA cable. If that doesn't work, send it to a repair shop. But compare the price of repair and buying a new one. These days buying is more reasonable than repairing.
But wish you it was only the VGA cable. Good luck.
Dec 29, 2012 | Dell UltraSharp 1905FP LCD Monitor
Monitor Problems
A pink or red tint indicated that florescent back light bulbs that light up the monitor are going out. When they start to die they out out red or pink light instead of white light like they should. They bulbs are replaceable but not easy for someone not familiar with this type of repair. Parts would run about $30 plus shipping and are available online but it may not be worth the repair on the monitor due to age.
Jun 20, 2012 | Hannspree HW173A LCD Monitor
Moniter background is pink instead of white.
Hello gladyshbrown,
If the background is the only thing that is pink, then this will be as simple as changing your background color. the process is different depending on the operating system you are using, but if you right click on an empty space in your desktop chose either properties, or personalize. then choosing desktop.
If however this is not just affecting your background, meaning everything has a pink hue to it then it is most likely a hardware problem. To test this you can change to a different monitor, if the pink hue is gone then it is most definitely the monitor. However if the problem is the same on both monitors, then that would mean that your graphics card has gone bad. Many Pc's bought from dell, or hp have both video cards, and on board video. If this is the case with your Pc, you can move the monitor cable from where it is connected now, to the identical connection on the back of the computer. If you do switch to an on board video, please turn off your computer before plugging it in. This way when your computer is turned back on it will recognize that you are using a different video source. Most computers will do this automatically, however if it does not you will need to go into the "bios(cmos)" and enable onboard video. The option for bios is given as the computer first starts up. The key varies but it will be one of the following f1,f2,f10, or delete.
Aug 14, 2011 | Computers & Internet
LG E1940S Monitor displays with a pink hue. I am using with a T40 ThinkPad and XP
A pink hue is a sign the CCFL lamp is about to fail.
The CCFL lamp is a fluro like tube approx. 2mm in diameter that is located on the bottom edge of the LCD screen that supplies the back light to the screen.
Replacement CCFL lamp is available from this WEB site.
www.lcdparts.net.
Jun 04, 2011 | LG E1940S 19" LCD Monitor
When i turned on computer this morning the colors have red/pink hues where it should be white
This is a sign that the CCFL lamp is about to fail.
Replacement CCFL lamp may be available from :-
www.lcdparts.net
Sep 19, 2010 | Acer AL1702bm 17" LCD Monitor
I added the E196fp to my older dell computer with win 98 from my newer dell with win xp.The whole thing has a pinkish hue to it and is very dark
mklotz, Try looking at the vga connector end and make certain all the brass pins are not bent or broken or recessed down into the connector body housing. If connector ok, then connect, disconnect, reconnect a few times and try to see if the PINK has changed to WHITE. If still PINK, then reseat the video card in pc. If still PINK screen, Then monitor may need to be repaired. CCFL ballast circuit repaired and/or CCFL lamps have too many hours on them and they also will need replacement. Report your findings here with additional info for me. 12fixlouie
Aug 17, 2010 | Dell E196FP 19" LCD Monitor
Dec 30, 2008 | Dell E176FP 17" LCD Monitor
Top screen of DS has pink hue.
this is happening to me right now and i just say call nintendo dog
Oct 25, 2008 | Nintendo DS Console
Pink-hued display
one try a degauss
second check the cable wich connect the monitor to the pc video card.
third. keep away the magnetic things like speackers from the monitor..
bye:)
Feb 03, 2008 | Compaq CV 7500 17" CRT Monitor
Dell E173FP 17" LCD Monitor Logo
80 people viewed this question
Alun Cox
