Question about LG WM2450HRA 3.7 CF Steam Front Control Washer
No power on machine outlet is fine - LG WM2450HRA 3.7 CF Steam Front Control Washer
Was having similar issue. Unplugged for about 15 minutes and plugged back in and worked for a couple days. Then it was dead again, unplugged again and working again. Hope this keeps working.
Posted on Jan 21, 2013
GE Profile Harmony washer won't power up and trips gfi
Did you replace the inverter board?? It is inside the tan plastic box in the bottom of the control panel I think on the right side. That controls the power supply to a good part of the machine and drive system. Has to be a direct short somewhere to trip the breaker.
Mar 31, 2015 | GE Washing Machines
No power when I turn the unit on
  1. Verify whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.
    1. If your Brother machine's LCD is blank, continue toStep 2.
    2. If your Brother machine's LCD displays a message other than the date and time, please refer to the FAQ about the message being displayed for further information.
  2. Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
  3. If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding theOn/OfforPower Savekey. This key is located in the upper-right corner of the control panel.
  4. If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
    -OR-
    Confirm the power outlet is working by plugging another known working device (a lamp, radio, etc.) directly into the same outlet. If the other device does not work, the problem is related to that power outlet. If a wall switch controls the outlet, verify that the switch is ON.
  5. If your Brother machine still will not power on, please contact Brother Customer Service.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Nov 14, 2013 | Brother MFC-J220 All-in-One Color Inkjet...
No Power
loose wires connection or pc board
Aug 25, 2017 | LG WM-2277HW Front Load Washer
Machine will not turn on. Worked fine 12 hours ago
Have you checked for power at the outlet?or maybe try and unplug for few minutes and plug back in to outlet or another outlet...also outlet maybe gfci protected,look for reset button on outlet or in main breaker panel.
Jul 26, 2011 | Keurig Elite B40 Coffee Maker
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
Thanks
May 21, 2010 | Washing Machines
The microwave does not react what so ever. Checked the fuse and its fine, what could be the problem? please help
Is there power at the outlet? You say you checked the fuse ... is that the one inside the machine? Is the outlet protected by a GFI (reset for a GFI is on the GFI)? A GFI looks like a ordinary outlet but is very sensitive to electrical irregularities. Your circuit breaker may be on or your power panel fuse may be fine and the fuse inside your oven may be fine. If the GFI is popped, you have no power.
Try some other electrical device in the outlet. Does it work? Try an extension cord from a known hot outlet?
Beyond these tips, you may need professional help with this.
Thanks for your interest in FixYa.com
Jan 22, 2010 | LG LMV1630ST Microwave Oven
The unit does not power up. The outlet is fine
check on the power up button.swich itself, and measure with ohm meter, you will know than do you need to change that with new or you have some other problem in cord.
Mar 31, 2009 | Breville ESP8XL Espresso Machine
Kenmore het3 washer just quit, no power.
If power to the unit then most likely the machine control went bad and would need to be replaced. There are no fuses or reset buttons. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Washing Machines
LG WM2450HRA 3.7 CF Steam Front Control Washer Logo
87 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
