Question about Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator
Dummy filter cartridge
Looking for a dummy filter cartridge to replace Frigidaire/Electrolux puresource2 filter on model PLHS267ZAB5
5 Suggested Answers
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Posted on Jun 19, 2009
  • 74 Answers
SOURCE: frigidaire gallery model plhs267zab5 when ever i
The dispensor door seal is not closing. Either it's blocked or not closing all the way.
Posted on Dec 02, 2009
  • 351 Answers
SOURCE: can't find user's manual but need to install
There are two places to look for the filter .. under thye door at the bottom of the fridge, there should be a button to push to release the filter cartridge, OR ,, with the door open in the upper right hand corner ..
Posted on May 09, 2010
oldTech2332
  • 2341 Answers
SOURCE: I am installing a reverse
hello.
i know such thing exist but i am having a hard time finding a part number for it. A alternative would be to in essence bypass the ref.filter this way.
The water line on the back of the refrig where the house plumbing connects to feeds directly into the filter first then out of the filter into the water valve to be dispensed to icemaker and door dispenser.you could connect the water supply from the RO system directly to the water valve instead of connecting the RO to the inline refrig filter.
Gene
Posted on Aug 06, 2011
Testimonial: "thank you"
I replace filter, each time the water dispenser is push the filter ejects
It sounds like you may not be getting the filter fully locked into position. Push it in firmly until it clicks.
Feb 28, 2015 | Frigidaire PureSource2 Water Filter WF2CB
Slow water flow
I would try the backwash as you suggest. Also, I had to run a few gallons of water through a new filter, for it to work properly..
Hope it helps.... good luck!
Jan 12, 2014 | Frigidaire Refrigerators
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Water stopped flowing on my frigidaire, replaced the filter (Frigidaire Frigidaire PureSource2 Water Filter WF2CB) and still no flow. Filter was old. About a year and a half or so. Any ideas on how to...
If you by pass the filter does the water flow? I suspect your water valve may have gone bad. Have you tested that by any chance? Also make sure the filter is in correctly and no loose lines and is locked in tightly. I would do two things: make sure the water reservoir in the refrigerator (behind the bottom drawer) is not frozen and check if 120 VAC coming to the water valve solenoid while the water dispenser calls for water.
Here is a link to a page that describes how to test the water valves.
www.appliance411.com/faq/test-water-valve.shtml
Jun 25, 2011 | Frigidaire PureSource2 Water Filter WF2CB
PureSource2 filter popped out on its own. Bought a new one because its past due, but cant get it to install all the way. Tried with & without pushing release button that is functional. HELP!! What is...
These filters, Electrolux advises, have been re-designed. Right now, as of this writing (July 5 2013) they are giving out conflicting reports of whether a special installation technique for the re-designed filter will work (doesn't for me) or if their Service Flash RF1210 will cover replacement of the filter housing (Won't for Sears Kenmore models). I'm unable to solve the problem so have written back to my distributor about this whole problem asking them to dig into it with Electrolux.
Feb 08, 2011 | Frigidaire PureSource2 Water Filter WF2CB
Inserted new toner it says CRU FUSE ERROR
If you have a CRU Fuse error, you have probably purchased an after market toner cartridge. If so, take the cartridge out of the machine and at the back of the cartridge you will see a small 'dummy' fuse. Take that 'dummy' fuse out of the cartridge and your printer will work. I know, it happened to me.
Nov 16, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Can't find user's manual but need to install
May 09, 2010 | Frigidaire 26.0 cu. ft. Side-By-Side...
Cobra Model HH35 radio dummy batteries
Normal AA batteries are 1.5 Volts each. The battery compartment on the HH35 holds 10 Batteries. If regular batteries are used they must be configured to a 12 Volt output. Thus the Dummy (Blank) is used to Make 8 X 1.5V=12 Volts.
If you use NiMH or Nicd which are rated at 1.2 Volts 10 X 1.2 =12 Volts.
Nov 21, 2007 | Radio Communications
Electrolux renaissance power hose
If the wires power a motor then it shouldn't actually matter as the motor is AC which has no polarity.
Oct 07, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator Logo
313 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
