Question about Sharp 32U-S650 32" TV
TV remains in standby
All i get on my Tv at moment is the power light - but no picture or sound. When i turn the Tv power switch off the light goes off and when it comes back on i get nothing no sound or picture. Have got tw remotes that work with the Tv but both dont resolve the problem.
    Problem Solver:
  • 6 Answers
If your'e ok with a multitester a simple resistance test is all u need to do.Try checking the wire wound resistors in the psu cct
Posted on Jan 23, 2008
  • 97 Answers
PRoblem is in the start-up circuit for the high voltage power side of the power supply. The 5 volt, stand-by circuit, is obviously fine. Need to take voltage measurements on start-up to 32kv side of transformer to diagnose. Possible flyback transformer or voltage regulator.
Posted on Jun 25, 2007
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
When turning on the TV all I get is a click sound, the red light remains red and no picture or sound.
Sounds like the tv is on standby, and needs to be switched on after via the remote control.
Oct 11, 2012 | Pioneer PRO-99 TV
37PF9731D/10 - when turned on the tv power light remains green but no picture or sound. Just a clicking sound - like it does normally when swiching on from being on standbay. It reapts the attempt to turn...
The clicking sound is from the main power supply relay being turning on and off, it is driven by hte main board and it gets the power from the standby power supply board.
You need to check the main powwer supply board and the standby power supply board voltages.
Check the resistor in the main power supply board also
Please see my pictures here:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 16, 2011 | Philips 37PF9731D 37 in. HD-Ready LCD...
My Sony KDF-50WE655 does not turn on. Only the standby LED Flashes several times and then goes steady green, but the lamp light remains off.
You just count the number of blinks of the standby light before it goes out to green. In sony sets this blinking count ic critical for us to locate the faulty stage. You just count it after switch it Off by Power switch and Switch it On by the power switch at the front of the TV, for at least three or four times, and make sure abut the number of blinks, and report it to me. Ok
Nov 14, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv keeps turning itself off and the white in the picture looks alittle off.
To get the right colors, especially a plain white, requires the right mix of red, green and blue from the picture tube. Sony TV sets have a circuit called AKB that automatically keeps the picture tube balanced by adjusting the signals to it. If that balance can't be achieved it shuts off the picture. This may due to tube aging so one of the color guns is too weak to adjust, or failure of parts in the AKB circuit itself. If the sound stays on and the power light starts blinking when the picture goes off, this is likely why.
On the other hand, if the set is turning off completely with no picture, sound or power light, the set may have power supply problems or defective parts in the picture tube high voltage circuits.
Since there are several possible causes, this set needs to be checked by a technician who can diagnose the problem and decide what needs to be done. It's not a simple thing I can point to and say "change this part". If the picture tube is the cause, it's better to replace the set. Otherwise get an estimate, then decide whether to fix or replace.
Apr 04, 2010 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Hi, I have an LG Flatron TV which I bought 6 years ago. Good picture, no problems until now. I put the set on standby via the remote. Later, when I put it on via the remote all I got was sound and no...
Since the screen keeps turning off and sound only remains have a look at the inverter board for any buldging capacitors which look like blue cans, there is most probably a short in the inverter and the powersupply is sensing this thus turning it back into standby to prevent damage to the tv.
Nov 04, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sharp 32U-S650 32" TV Logo
114 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
