Question about Philips 55PW9383 55" Rear Projection Television
Where can I get the cable for HD input av 5
I have this TV I want to see HD on it but I need to conet to HD box this box came with the cable as a High speed HDMI with Eternet but tv do not have this conection it have like 24 pins can you help me thank you
    Sergeant:
  • 214 Answers
It's the wrong box if it doesn't have HDMI. Take it back.
Posted on Dec 29, 2012
tvtek
  • 1284 Answers
SOURCE: HD input
On the Magnavox projections, only one of the inputs supports hight than 480p input IE: 720p, 1080i. Make sure it is the correct input.
Posted on Dec 19, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: hooking up from hd receiver to hdtv ready
This particular television puts you in a tough bind - you can use Component cables in AV-1, but you won't be able to get HD. Or you can use the Component cables in the right-most component slot (AV-4), but since your HD Receiver probably doesn't have V/H Sync connectors, you may get a rolling picture. Try the component cables in the right-most slot - if the picture doesn't roll, you're in business.
Once again, I doubt that your model # is a 60pp9202, since that model doesn't have a VGA or DVI slot. If the picture rolls after trying the above, you will need to purchase a HDMI-to-DVI-D cable and hook it up from the HDMI output of your HD receiver to the DVI slot (that looks like a VGA slot) on the back of your Philips or Magnavox.
-Tha Mp3 Doctor
-Tha Mp3 Doctor
Posted on Mar 07, 2009
  • 1779 Answers
SOURCE: connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Posted on Jun 06, 2009
Slinteriors
  • 8617 Answers
SOURCE: Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Posted on Jul 25, 2009
  • 4 Answers
SOURCE: looking for hd channel
To get an hd picture you have to use a digital input and this cannot be done by simply turning it to a channel. You need to hook up your HD receiver (box) to your tv using either an HDMI or a Component which will be a cable that looks similar to an rca but there are three of them and the colors are bed blue and green. If there is a red, blue and green on the back of the cable box and the tv hook them together with a component cable and then find the input on your tv that correlates to the compnent connections and then even after all of this you need to be tuned into a channel that is offered in high definition and if you have cable like I do the high definition channel will be a seperate channel from the regular one. Comcast in my area puts the HD's from channels 400-500. For example my espn HD is channel 403 but just regular espn non HD is on channel 27 in my area.
Posted on Sep 21, 2009
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Jul 15, 2008 | Televison & Video
How can I get high definition on the tv? I have it set to receive the signal from my cable tv company but it transmits only a regular signal.
Check these things to solve this problem:
Do you have an High Definition TV? If you bough it recently, then you probably do. If you are unsure, look on the back of the TV for the model numbe and search on Google to read find information about he model of TV you have. If you don't have an HD TV, you will need to upgrade if you want High Definition.
Is the TV connected to the cable box with an HDMI or Composite cable?
You can order a cheap HDMI cable at Monoprice.com.
If you are using old style AV cables (red, yellow, white) then you will not get an HD signal from the cable box.
Check the TV settings to make sure it is set to display in HD. Look in the manual for help here. It is probably in the Input Settings.
You will need to call your cable company and make sure you are getting HD service. If you are not the you will only get Standard Definition. You may have to pay more or upgrade your cable box.
Mar 05, 2011 | Televison & Video
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
I have recently gotten a Sharp AQUOS Quattron (LC52LE810UN). I have a rogers cable box with a RCA input, but the tv doesnt not have an direct RCA input. It has a input for an audio cable with a component...
Your TV is a High-Def TV (HDTV) therefore you need a Rogers cable box and service capable of High-Definition in order to get the HD resolution you paid for with the HDTV. HD video requires HDMI or component video cable connections. Standard RCA AV (yellow, white, red) will not show HD video.
Having said that, you may want to hookup a game or VCR to the TV and therefore you will need to get a cable known as an AV miniplug. It has RCA (3) on one end for the VCR for example and on the other end is a Mini-plug to connect to the HDTV (Sharp). This cable is like the ones used on camcorders such as Sony. Make sure you get a cable with the right ends as depicted in your manual on page 14.
You'll have to Google online for a supplier. Sparco.com had these cables but are out of stock currently.
Jan 17, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 55PW9383 55" Rear Projection Television Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
