Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
Maytag centennial washer model mvwc6esww1 will not spin out all the water
beltronic205
  • 1460 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
Daniel S
  • 4323 Answers
SOURCE: Maytag Centennial will not spin
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 22, 2010
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
richroth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
Jahn27
  • 1554 Answers
SOURCE: Maytag Centennial Washer model MVWC6ESWW1
It sounds like this is a clutch and brake assembly problem. The clutch spring must provide the necessary pressure for the lining to turn with the hub and the clutch tab to push the brake cam driver and release the brake. The clutch spring of your washer must be weak or the clutch lining is worn causing it to slide and not release the brake. This prevents the tab that holds the clutch spring to force the brake cam driver, release the brake, and allow the basket to spin particularly when the machine is under load. This is manifested in the spinning of the drum when the machine is empty. The clutch and brake assemblies are located just below the tub and the excessive heat resulted from the friction between the clutch lining and the clutch hub.
Remove the thrust washer from the agitator shaft then remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip using a screwdriver. Unsnap the clip and the clutch retaining ring the slide the clutch off the agitator shaft. Make sure to retain the washer located under the clutch.
Install the new clutch assembly on top of the gearcase then insert the clutch band and hold it in place. Using a pair of needle-nose pliers, place the end caps on the clutch spring and compress to insert into the open end of the band. Release the tension on the spring and the band will stay in place the reinsert the retaining clip on top of the clutch.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 30, 2011
I have a Maytag Centennial MVWC6ESWW1 and need to know how to lift off the top cover to get to the lid switch?
There are two hinges at the back, just remove two screws on top then push the top toward the front about 1'' or 1.5'' then lift it up.
Sep 30, 2013 | Maytag Centennial MTW5800TW Top Load...
Maytag Centennial is filling with hot water on cold setting
Probably the fill lines were reversed. The installation guidance tends to be poor.
Jun 15, 2017 | Washing Machines
My Maytag Centennial elec dryer won't dry well
could it be the thermasat are all the wires connected
Jan 01, 2012 | Maytag Dryers
Owner's Manual For CENTENNIAL Commercial Technology Washer - Model No. MVWC6ESWW1
Maytag has many of the manuals for their washers available at their site. Go to https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10562&langId=-1&storeId=10212&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView and enter the model number of the washer.
The direct link to the manual for the Maytag Centennial MVWC6ESWW1 is https://www.maytag.com/digitalassets/MLPDF/User%20Instructions%20-%20W10330943.pdf . Additional manuals are available here https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10562&langId=-1&storeId=10212 . (This includes the manuals in Spanish, installation guide and parts list.)
I hope this helps.
Aug 06, 2011 | Washing Machines
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
104 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
