Question about Car Audio & Video
Which wire to connect to continuous power
JVC KDs5050 which wire to connect to continuous power to keep pre-sets and clock without depleeting battery?
Thanks
  • appleart Jan 18, 2009
    Thank You very much for your help
    May God Bless...You & Yours
    Sergeant:
  • 233 Answers
Yellow wire goes to constant 12 volt power (or battery+ terminal, but you should be able to find constant power in the car...), red to switched, black to ground.
Posted on Jan 18, 2009
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
Mar 02, 2011 | JVC Audio Players & Recorders
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
I installed my JVC KD-SX650 and it works but it will not keep the radio station settings and the clock setting once I turn my truck off and back on again, what could be the problem?
you need to make sure the yellow wire is going to a constant power source.. the yellow wire controls the clock and preset setting memory.
Jul 13, 2010 | JVC KD-SX650 CD Player
I have JVC cassette car receiver fitted into my classic Triumph Spitfire. It has a direct feed +12volts to it via a fuse. When I put all my selected radio freqs into the memory they all work, also I can...
You have the Constant (Memory) Power wire connected to a switched power source.
Make sure the YELLOW wire is tapped into a power source that is always 12VDC 9when the key is in the OFF position).
Yellow wire - Constant power - to retain memory settings.
Red Wire - Switched power - to turn on and off with the key.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
Wont save pre-set stations
you need to make sure the red wire is connected to the battery via a fuse(normally inline or in the back of the unit) and the yellow is connected to ignition live(ignition needs to be on to give power). if the red wire is not permanantly live then the pre-program function will be reset every time you turn the ignition off.
Oct 06, 2009 | JVC KD-S6060 CD Player
Set clock on an JVC KDS5050
Here's the manual -->LINK<--
Page 15 for setting the clock.
Regards
Philip
Jul 20, 2008 | JVC Car Audio & Video
Connecting a JVC fr end loader to an old car.
Thanks, I got it right. The blue 'remote' wire stays unused and the red 'ascessories' and the yellow battery supply for the clock and memory are coupled together.
Feb 13, 2008 | JVC KD-S6060 CD Player
Car Audio & Video Logo
133 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
