Question about LG 42PC3RA 42 in. HD-Ready Plasma TV
Panasonic LG plasma no audio on hdmi 1
There is no audio on hdmi 1. There is audio on hdmi 2.
  • 2 more comments
  • Carole Carole Dec 29, 2012
    We figured it out!
  • Brandon Murphy Dec 29, 2012
    What was the problem?
    We found the answer! The HDMI port has to be set to digital. Somehow when we unplugged and moved it from the living room, and plugged it in the movie room, something internal changed the port. This has been a HUGE frustration for 3 weeks!! Thanks for your time! Happy New Year!
    Ah yup that will do it. TV probably reset when the power cord was removed from the wall. Your welcome and Happy New Year.
    Sergeant:
  • 214 Answers
HDMI cord may be faulty. Try the cord that works on the port that doesn't If it works then the HDMI cord is bad. If it doesn't work then the HDMI port may be bad on the TV.
Posted on Dec 29, 2012
3 Suggested Answers
dduncan774
  • 760 Answers
SOURCE: My TV is not showing
Go into your user menu and make sure the inputs are turned on. If they are, check your source and make sure it is working. You can do this buy hooking something else to your set. If you find that it is your set that is the problem, then your main board wil need to be replaced
Posted on Apr 04, 2011
  • 103 Answers
SOURCE: lg plasma 50 trying to
You will only be able to use the HDMI if you tv has an output for it(for other things beside built in DVD player of home theatre). It can not be an input. If you want everything that plays through your tv to then play through your home theatre the easiest way is to use white and red composite audio cables(some call them rca cables) More than likely you tv will have this output.They will go from the output of the tv to the input of home theater. If your home theater has a Blu-ray or DVD player you need to use the HDMI from home theatre out to in on the tv. If you tv happens to have and OUTPUT for fiber optic audio or digital coaxle audio on your tv and your home theatre has same but as inputs that will work as well with a better quality sound. However this is very rare.
Posted on Dec 13, 2010
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Oct 19, 2014 | LG 55LK530 55 inch 1080p LCD HDTV, with...
HDMI Video droputs.
Have you tried a different HDMI cable?
Dec 08, 2013 | Yamaha RX-V663 Receiver
No Audio on Multiple Plasma tv's connected via 1*2 hdmi splitter
Too many connections here---likely a hookup issue if both sets work alone and frankly the wrong way to do this.
Apr 30, 2012 | Televison & Video
Whats the best way to install a panasonic viera tc-p50x3 to a yamaha home theater receiver rx-v371 to a panasonic blueray dmpbd75 using dishnet work hddvr set top box
connect your blue ray and your dish net with hdmi cables to the amplifier than monitor out hdmi to tv .in your dvd configuration you must make sure that hdmi audio is activated .ps not to be mean but this is a very low quality dvd because it does not have fiber optique audio output but it can still work, for your dis net it all depends on what type of digital audio output
is available , ill be honest with you this is a good job .
Dec 07, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
I have a lg plasma tv tryin to get the panasonic scpt480 connected i have sound threw dvd player but not tv wat cables should i use
There are a couple of different ways you could go with this. Your Panasonic SCP-T480 has an HDMI and a digital optical port HDMI carries audio and video signal so, it would be your easiest/best bet. Digital Optical provdes sound only but, provides as good sound quality as HDMI but, no video To use the digital optical for sound you would also have a composite(RCA) cable to gain your video.
Mar 23, 2011 | Panasonic SCPT480 Theater System
Can i connect my panasonic viera th-42px8ou plasma tv,to my vista desk top? my tv has hdmi on it,my vista tower also says it has 1 hdmi connector on the back of it
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
Dec 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Lg plasma 50 trying to configure hdmi to play tv sound through panasonic home theater.
Dec 13, 2010 | LG 42PB4D 42 in. Plasma HDTV
Audio on HDMI(2) output with external audiocord?
The audio from the hdmi out on your computer is turned off. Try connecting another device such as a dvd player to the hdmi input on your tv . If audio works on tv then you know no audio is not available from the hdmi output on you computer.
Nov 21, 2009 | LG 42PC1R 42 in. Plasma HDTV
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
TV ranking
Hi. You could look up reviews. I personally usually never offer advice on choices, because what I like, may not be what you like..its a matter of personal preference. But in this particular case, I'd go for Panasonic. Why? Better features, better service, easier availability of parts, and better resolution.Plus some nice features. If this answers your question, PLEASE don't forget to rate as fixed. I'd really appreciate it. Enjoy your new tube!!!
Jeff
May 12, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
LG 42PC3RA 42 in. HD-Ready Plasma TV Logo
187 people viewed this question
Computer Repairing
Computer Repairing
