Question about Vizio M370NV 37 in. LCD TV
Audio input can not connect to pc
    Sergeant:
  • 214 Answers
Why would you want to hook up a PC to a tv? Do you mean laptop to a tv?
Posted on Dec 29, 2012
Which input for laptop audio?
You can connect a powered stereo speakers or amplifier to your laptop for better sound. Connect an audio cable from the headphone socket on the laptop to the powered stereo speakers or amplifier audio input.
Jul 01, 2012 | Toshiba Computers & Internet
Pc input no sound through screen. but sound when changed to hdmi input?
If you are feeding video from your pc to your TV from the pc video card, then no audio will go to the tv unless that is connected also from your pc audio output.
HDMI (Multimedia Interface) means it connect both mediums: i.e.audio and video.
May 06, 2012 | Televison & Video
Connect to PC
You can use the audio our port to be connected to the audio input - MIC input- which can be selected as the AUX input. Select audio properties and select and switch the input to AUX so that the input is reduced to match the signal.Hence the audio outputs from receiver can be connected to this input and it can also be recorded by using the default recorder or the Sound Forge which can be downloaded.
Dec 17, 2011 | Sony STR-V555ES Receiver
How do i connect my wii to my new samsung ue46d6530?
Input &
Output
HDMI 1.4 (3D Auto Setting/Return Channel):4
USB:3
Component In (Y/Pb/Pr):1
Composite In (AV):1(Common Use for Component Y)
Digital Audio Out (Optical):1
PC In (D-sub):1
CI Slot:1
SCART:1
RF In (Terrestrial / Cable input):1
RF In (Satellite input):1
Headphone:1
PC Audio In (Mini Jack):1
DVI Audio In (Mini Jack):1 (Common Use for PC Audio in)
Audio Out (Mini Jack):-
Ethernet (LAN):1
Initially I thought the problem was going to be no composite input on this television. However according to the specs there is one composite (yellow, white, red) input and that is where you connect the wii. Is the problem that you've already connected something to the one input and you're looking for another spot to connect the wii? There is a wii component cable http://www.amazon.com/Official-Wii-Component-Video-Cable-Nintendo/dp/B000JJRV90
Jun 13, 2011 | Samsung Televison & Video
How to connect the gemini to the computer
Easy.
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The Gemini's Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select Line In.
http://i.ehow.co.uk/images/a04/fa/r2/subwoofers-as-home-entertainment-set-1.1-800X800.jpg
The Gemini's Output (Record Master) would perform similarly if adapted to your PC's audio input, whatever that may turn out to be (usually Mic, maybe Line In).
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 12, 2011 | Philips Gemini CDM-500
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
How can I connect my Onkyo TX-SR507 to a PC to play MP3 files
The easiest way is to use a 1/8" stereo to dual RCA cord and connect the output of the sound card to an AUX input on the receiver. These cables are readily available and cheap. You shoul dhave 3 mini jacks on the back of the computer related to the sound card setup.
1) Audio input mic
2) Audio input line
3) Audio output line
Connect the receiver to the audio output line jack.
Dan
Jan 30, 2010 | Onkyo Tx-sr507 A/V Receiver
VGA and Audio cables connected to PC but no audio through TV
if your tv has vga input there should be a "line in" input very near it. VGA can only get its audio source through a "line in" connecting to the coaxial audio inputs will apply the music stream to a different video input on your tv. your tv has video 1, video 2, vga, and so on, but the vga cannot show video and then audio from the video/audio coaxial inputs. you will need something like a dual male tipped 3.5mm audio connector.
Good luck and pls rate this post
Mar 16, 2009 | HP Pavilion dv2000t Notebook
Hook up for dell inspiron 6000 to panasonic th-50px80u
the TV supports resolutions as follows:-
VGA (640 × 480 pixels), WVGA (852 × 480 pixels),
XGA (1,024 × 768 pixels), WXGA (1,366 × 768 pixels)
You need to set the PC desktop res to one of these resolutions and then simply connect the VGA o/p on the laptop to the PC input on the TV. You can also connect the audio out of the PC to the TV if you wish by connecting the audio into AV2 audio input on the TV
The other option would be to use the S video o/p on the PC and connect into AV3 input (audio inc) but I suspect the picture quality will be better via the VGA
Please post back if you have other questions or problems.
Jul 15, 2008 | Panasonic Computers & Internet
Open Questions:
See all Vizio M370NV 37 in. LCD TV Questions
Vizio M370NV 37 in. LCD TV Logo
29 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
