Question about Nintendo Wii Console
Light Powers on butunit shuts off no power when button is pressed
When you plug in the unit you get the green light (power on)
but when you press the on button it immeditly shuts down acting like no power is coming to it. Ive tried hitting the eject button and it does the same thing. I've checked the manual nothing their to sugest anything.
I wondering if the cord has something to do with it. but I think more like the panel of the on/eject/reset is bad. Any hope? I'm really miss'n my city folk...I haved this unit for 1 year.
From the research im doin on the same problem its the same as xboxs red ring of the death. the most consistent answer is to return it to sony for 149 bucks if out of warranty. trying to find more....
Posted on Jan 18, 2009
LC-40le550u no picture... green light on
if powers on and has no video and no audio could be the main board, but first try this :
take a flashlight, turns on the tv and try to "see" the image while light up the flashlight against the screen , if you "see" something you have a bad back light inverter board.
below the posible parts number :
MAIN BOARD : Sharp 9JY0140CTJ05100
POWER SUPPLY/ BACK LIGHT : Sharp 9JY0940CTJ05000
TRY TO LOOK FOR AT :
www.bostonrecycling.net
or ebay
thanks
Oct 09, 2014 | Televison & Video
I have a Breadman TR875 breadmaker. It will not do anything when I hit start. I've tried to unplug it, but didn't help.
I believe for this perticular model to power-up, you must press the Select button first to select a mode, then press the Start button.
Here's more on the subject...
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source your accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reset the breadmaker by pressing down on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Note: It bears mentioning again at this point that some models require you press the Select button first to select a mode, then press the Start button.
Jun 20, 2011 | Breadman Kitchen Appliances - Others
Breadman Pro TR875 is stuck & will not start up to knead the dough. Timer is hi-lighted & shouldn't be. No pushing of any buttons will not clear & start over
  2. Confirm the power source you're drawing from is live using a blender, toaster, etc.
  3. Plug the breadmaker in, unplug it, then plug it in a second time.
    1. Some models have a built-in off/on toggle power switch. Turn it to the ON position.
    2. Some models confirm power by making and audible tone when plugged in.
    4. Some models require you press down on the Stop button until the unit powers up.
E. Some models require you press down on the Start button until the unit powers up.
F. Some models require you press down on the Select button until the unit powers up.
G. Some models require you press the Select button first before pressing the Start button.
In the end, were you able to confirm that your breadmaker is receiving power?
No. Sorry to hear that. Have the breadmaker serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the breadmaker's electronics by pressing down on the Stop button until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press down on the Start button instead. And yet a few others require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics.
Note: All breadmakers use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn during the kneading cycles, your timing belt is probably broken. You'll need to disassemble the breadmaker to visually confirm. The belt and pulley assemblies are located at the bottom of your breadmaker.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. r53w6t
Jun 07, 2011 | Breadman TR900S Bread Maker
West Bend Bread Maker model 41056 does not start. When machine is plugged in, LED displays a time but buttons do not work and red light does not go on. (Pan was in machine and anchored.)
Power-Up/Start-Up Issues:
    1. Some models have a built-in off/on toggle power switch. Be sure it's turned on.
    2. Most models confirm power by making an audible beep when plugged in.
    3. Most models have a colored light and/or a lighted display screen that lights up.
    4. Most models require you press down on the Stop button until the unit powers up.
G. Many models require you select a baking mode by pressing the Select button before the pressing the Start button.
Q: In the end, were you able to confirm your breadmaker is receiving power?
No. Sorry to hear that. Have it serviced by a small appliance repair shop or simply discard it.
Yes. Fantastic! Now reboot the electronics by pressing down on the Stop button for 1 to 5 seconds. Note: A few models require you press down on the Start button instead. And even fewer require you press down on the Select button instead.
Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. See reboot directions above.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. 465ygbea
Jun 07, 2011 | West Bend 41053 Bread & Dough Maker
Canon pixma ip4200 green & yellow light blinks 12 times and cannot print. what am I to do? pc connected, cable connect.
You might need to reset your printer so it can work again. please follow the steps below. It is important to familiarize yourself to the steps before doing it.
Here it is.
With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button.
Do not release the buttons. The LED light should be green to indicate that a function is selectable
While holding the Power button, release the Resume/Cancel button, do not release the Power button
While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
Press the Power button. The LED lights in green, and the reset is performed.
When the operation completes, the printer returns to the menu selection mode automatically
Press the power button to exit service mode.
Hope this helps.
Apr 24, 2011 | Canon Office Equipment & Supplies
Powers off
do you hear any sounds what so ever? Clicks or anything when you press power.
Jun 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Doesn't boot up
try it pluged in without the battery, does it turn on?
when it shuts down, does the power light stay on? or is it just no display?
Jan 04, 2008 | Dell Latitude D600 Notebook
Error message
OK guys quite a simple one....
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
Dec 05, 2007 | Epson Stylus CX6600 All-In-One InkJet...
WII shuts down when power or eject is pressed
Depending on the chip and who installed it, it is probably shorting out something in your system. Even if the system was working before, it might have shifted or come loose. If it is only shorting your power switch then it would just be a simple adjustment of the chip. However, the chip could have shorted out your main board and when the system powers on, it detects the short and shuts itself off as a fail-safe. Removing the chip *might* fix it if it didn't totally fry the system.
Aug 30, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
