Question about Samsung SGH-D820 Cellular Phone
SLIDER PROBLEM Hi Folks, Problem is the slider is too tight. It hard to slide due to which the display is getting affected. I have been using SGH-D820 for more then a year now, the moment I thot of getting slider problem repaired I lost my bill.
  • 44 Answers
Well m8 seems like the only way to fix your problem would be to eather get a new casing and fitt it or to take your fone apart and see what is causing it to be so tight eather way i would recomend you send it to these guys as its not worth taking your fone apart cuz you might end up damaging something else. http://www.mobilephoneservicecentre.co.uk/
Posted on Jun 26, 2007
SOURCE:
Why are my cleaned and lubricated caliper bolts hard to move?
The pins don't slide, the caliper slides on the pins.
Mar 26, 2016 | 2006 Chevrolet Impala
Tip
Samsung phones
Hello there Samsung slider phones LCD or screen problem. Always you have seen that samsung phone get problem like some phone doesnt have light in LCD and some times they does not turn on. Samsung slider phones like G 600 , U 600 . J 700, E250 ,D800 and D900.Slider phones always has Ribben ( slidr belt ). And this ribben always connect phone upper part ( screen ) to the mother board.when the ribben (slider belt) got damage then it gives you that problem.it happens when you use your phone roughly or when you dropped your phone on concrete or any different floor.Mostly Samsung phone model U600 , G600 AND J700 has this problem.whenever your phone gets this problem firstly check. And Do not try any flashing or any kind of software tools. it easy to change ribben (slider belt ). Just get ribben belt or some tiny screw driver and some slider opener. this tools are easy to get from any tools shop. then mostly phone has screw. firstly open the battery cover and take it out and see two hole under the battery and when you slide up your phone then you can see two screw just under your phone top keypad just hold the slider for while and open those screw and slide up then see two rubber things are both side on camera. Use any flicker type things and take out that rubber top then you can see two screw just under the screw open those screw then use the slider opener if the opener is tight if slider is loose the do not use opener just take it out so softly and remove the one side of the ribben which you can see connected of mother board just take out ribben and put new one ribben the put all things back as a normal then tight the screws and put battery then turn it on your phone will turn on.some phone like U600 ,j600,has touch panel. this type of model slider belt or ribben always comes with touch panel and its quite difficult and quite expensive to change.Samsung U600 has this problem mostly because they are very thin and then slider belt is as well thin and they get this problem so quickly.
thanks
on Jan 08, 2010 | Cell Phones
Denon dn-x300
Greetings
can you explain more?
or just the sliding fader is not working?
if the sliding fader is not working u need to change the sliding part
REF: SLIDE VR(RA45D2-211-15D1-R0B50K)
its 50K Ohm slider.
sometimes the material inside the slider ends fast due to activity.
hope this helps
Kind Regards from Audio-adviser.com
Feb 15, 2014 | Denon Dnx300 3-Channel DJ Mixer System
My Samsung camera displays "Card
Take out the Micro SD storage card and if you look closely along the edge you will see a small slider with a padlock symbol ar both ends. Slide the slider to the symbol that looks like an unlocked padlock. This locking feature is to stop users accidentally erasing or formatting the memory card. Sometimes the slider can be moved if the SD card is a tight fit in to the slot.
Jul 08, 2011 | Cameras
How to adjust time, date and alarm
hi please specify ur brand name and model number of ur vacuum cleaner for a normal vacuum cleaner u can see a slider on the top slide the slider to the time and select the minute button and hours button to set the time and for setting the date slide the slider to the date and set the date using minutes button and for setting the alarm slide the slider to the alarm section and set the alarm on to off the alarm there are two options u can either press the snooze button which will stop the alarm for 5 minutes and after that it will ring ring again to permanently switch off ur alarm slide the slider to alarm off tab and press ok was this useful to u pls vote for me if u liked it
with warm regards - bonefirediv
Mar 25, 2011 | Vacuums
Hi, My Fuji FinePix S1000fd keeps displaying "Protected Card" how do i get rid of it ?
Hi. There is a tiny tab on a slider on the memory card which can easily be locked by mistake. You should be able to see a very small indicator to show which way is 'unlocked', so you can gently slide the tab back to that end.
Dec 28, 2010 | Fuji FinePix S1000FD Digital Camera
My phone's slider is very tight. What is the problem tell me .Please tell me the new slider price.
hi, you can fix that yourself. if you can see the slider assembly, get a qtip, and some vaseline (petroleum jelly) and just clean it. and just keep sliding up and down to grease it.
nick
Sep 10, 2010 | Cell Phones
Acer aspire does not open
Do you mean that the lid doesn't open or that your operating system doesn't open? If it's the lid, then the latches attached to the slider are jammed up. You can force them back with a small flat-head screw driver or a butter knife, or some other thin object that you can slide in there. Be careful not to scratch your LCD with whatever it is that you choose to use to open the lid. Once you get it open, move the slider back and forth to see if the latch hooks are moving with it. If they are then there is something going on with your lid that is preventing them from moving back after it's be closed. Sometimes this is due to the lid being slightly bent so that it causes the latches to lock in tightly and then not move back to unlatch when moving the slider. If you were meaning that your operating system won't open then you may need your system reinstalled. MADHATTER COMPUTERS
Mar 22, 2010 | Computers & Internet
Volume auto turns down
hi i downloaded windows 7 and now my touch volume control does not work what should i do
May 28, 2009 | Computers & Internet
Samsung SGH-E800 nodisplay
Can u Help me.
How to remove slider.
In my mobile the display ribbon connector was cut so i do not know how to remove slide to change the ribbon connector.
Can you sent picture regarding servicing (to remove circute board and slider.
Thanks
Jan 27, 2008 | Samsung SGH-E800 Cellular Phone
Samsung SGH-D820 Cellular Phone Logo
199 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
