1980 368 motor fuel injection,I replaced spark plugs,cap,rotor,wires,map sensor set timing at 10 degrees.i checked all vacuum hoses they are good.i have suction at vacuum hose for map it's good.i disconnected wires from injectors they are not stuck open.when I turn key with wires disconnected.i found the baro sensor next to map sensor plugged into ECM it doesn't have a vacuum hose attracted to it.it looks like it is missing vacuum hose but there is not one for it,is this suppose to be this way?.i noticed the spark plugs are turning black on drivers side only.i cleaned them and it did it again,there is spark going to every plug I checked.i also noticed the drivers side does not seem to get hot not like other side.also I noticed I don't have any suction coming from several vacuum lines.from emission type outlets,also the heater controls work when I push buttons but the blower will not come on.somebody please help 973-349-4941 Tim or email [email protected]
SOURCE: 1989 Deville 4.5 TBI No start condition
A faulty map sensor will make it run rich and so will a bad or misadjusted TPS but it should try to crank. Check mat sensor. A stopped up converter will do this to.
Testimonial: "Stopped up converter thanks"
SOURCE: Stalling Issues
Was the TPS adjusted to 1.5 volts or checked for that voltage reading beforehand?
