Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
CHAINSAW WON'T START. BELIEVE IT'S FLOODING OUT.
IT'S GOT SPARK, BUT FLOODS OUT. PULLED AND CHANGED THE PLUG, CLEARED CYLINDER SEVERAL TIMES, BUT STILL GETTING FUEL OUT MUFFLER AND CARB. IT RAN ABOUT TWO MONTHS AGO AND I DON'T RECALL HAVING ANY PROBLEMS WITH IT. THE FUEL IS O K .
  • justohs Jan 25, 2009
    • pull start rope stuck on homelight UT`9767 chain saw
    President:
  • 2,692 Answers
Take the carburator off and clean it out.
Posted on Jan 18, 2009
Stihl MS 170 chainsaw will not start
remove the plug, hold the throttle wide open and pull about 10 times
replace the plug and hold the throttle wide open, pull to start
the stihl floods very easy and will not start until the excess in the crankcase is removed
Jan 19, 2017 | Cars & Trucks
017 Stihl chainsaw problem
Could be the spark isn't as strong as you think it is. Could be the spark weakens when the unit is warm. Electronic module ignition needs an energetic pull at the best of times to get a strong enough spark for starting and if it is weaker it would be impossible to pull the starter cord fast enough.
Instead of testing the spark with the standard spark plug try using a spare plug with the gap opened to about 1 to 1.5 mm. The atmosphere in the cylinder during compression is much more dense than in open air and a much stronger spark is needed to jump the gap.
If the spark is satisfactory it could be the crankcase compression that is low, perhaps leaking past the crankshaft seals. If the chainsaw is little used and stands idle for longish periods this could be the problem. Seals tend to lose flexibility quicker under those conditions.
Mar 26, 2016 | Stihl Garden
Seems my Poulan Chainsaw P3314 is flooding.
Ron, the excessive gas could be the result of continued start attempts with a weak spark or a bad plug or a carboned plug. If none of the carb adjustments have not been turned or twisted prior, I'd suggest obtaining a fresh spark plug. Make sure the gap is correct. Blow out the cylinder with compressed air to vent all the residual gas/oil within. Ground the new plug against the engine and pull the cord. You should observe a fairly bright spark at the plug. If no spark you could have a faulty coil/ignition module. If a bright spark is present, install the plug and give it full choke and attempt to start. It should attempt to start within a few pulls....when it does, go immediately to HALF-choke and pull again and it should start.
Nov 11, 2015 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Why won't it start?
it is flooding . turn off the choke and remove the plug
dry the plug and pull the rope about 10 times to blow all excess fuel ot of the system
refit plug and try it again
May 02, 2015 | Garden
95 trooper flooding cylinders when cranking, runs great when starts,but setting all day or night, floods again, will run then if spark plugs removed & cleaned!!, all sensors changed!! WHAT TO DO NEXT??...
Connect a fuel pressure gauge to the fuel line and check the fuel pressure. If it exceeds manufacturers specifications; replace the fuel pressure regulator.
Spark plug cables which have aged, and now have more han 1,000 ohms resistance per inch of length, also can lead to cylinder flooding; and should be replaced.
Oct 23, 2013 | 1995 Isuzu Trooper
I have a PB251 Echo blower that won't start. I have a good spark Good compression and clean new gas is getting to cylinder because i have a wet spark plug when i removed it ,yet it won't even...
I suggest cleaning the carburetor and replacing the diaphrams. The diaphrams come with a rebuild kit that has a lot of unused parts.
Aug 31, 2011 | Echo Garden
My 98 xr400 will not start. It seams to be flooded but it doesn,t even sputter if I don't move the choke at all. If I put the choke on half open it almost starts but then I think it floods. I changed...
Check to see if you have spark. Put a plug in the cap and touch the cylinder , kick it over to see if the plug is sparking. I kick mine 2 or 3 times to prime the cylinder holding decompression lever in. If it pops on full choke but does not start I go to half choke. If it does not start after 3 or 4 kicks , then I turn off the choke and kick it over 5 or 6 times with the decompression lever pulled to clear it. Then I will kick with no choke or half choke. Honda's are notorious for being cold blooded so when it starts let it warm up and do not be afraid to drive a short distance on half choke till the motor warms up a little.
When the machine is hard to start after sitting I usually start by removing the carburetor and shooting carburetor cleaner through the jets and passageways.I have always found my 96 xr400 to be a dependable starter with fresh gas and a clean carburetor. If it is flooded use the decompression lever to clear the cylinder.
Dec 31, 2010 | 1998 Honda XR 400R
I have a 262 pro chainsaw and I used it all day and stopped for a couple hours and now wont start or even try too...I changed the plug and pulled it a couple of times with out the plug....It's got spark...
Pour a little fuel mix in the plug hole and try for start--if pops several times, you have a fuel delivery problem. Check for a plugged fuel filter, air filter, and muffler. Check the condition of the fuel lines, particularly the line ends. Make sure the carburetor fasteners are tight. Does the primer bulb fill with fuel when pumped? Hope this helps!
Sep 11, 2010 | Poulan Garden
Wont start
When you replaced the spark plug, did the plug show a snappy, blue spark when the engine was pulled through smartly? If it did, check for a plugged fuel filter, air cleaner, and muffler. Check the fuel lines for condition. Make sure the carburetor fasteners are tight. Does the primer pull fuel into it? Is the fuel mix fresh? If still nothing, try spraying some starting fluid into the cylinder through the plug hole and pull through. If pops several times, the carburetor may need to be disassembled, cleaned and adjusted. Hope this helps!
Apr 22, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have an 18'' Poulan chain saw that won't start.
Take the wire of the spark plug,and see if it shocks you when the cord is pulled.If not there may be something wrong with your coil.(loose wire for example)If it does shock you,you may want to check out your piston rings,or the little air/fuel mixture valve between your carburetor,and cylinder.
Jun 05, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
1,080 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
