Question about Magellan RoadMate 700 GPS Receiver
Cradle Is it possible to bypass the cradle on the Magellan 700 and run 12vdc directly to the internal board?
  • David Brown Jun 22, 2007
    The cradle is a poor design and I was hoping just to bypass the entire unit and design my own mounting system. The problem that I have had is sometimes vibration causes the units to trip off. I did take one of the cradles apart and looked at the circuit board. I did not take any measurements of the contacts on the cradle but was hoping that someone in cyber land had all of them labeled as to the function of each contact. I was concerned that the board inside the cradle did some voltage changes within the unit at various locations. Thanks for the help.
  • 944 Answers
I believe not,and there is sparse info about the insides of these on the net; however This is often possible for many types of electronic equipment - the thing to check first is use a multimeter and check the voltage at the cradle where it connects to the gps - if it is 12 volts(11.2 - 13.8v) there then the cradle has no power electronics except perhaps a fuse or surge protector, or a noise suppression filter. However looking at photos of the cradle, the price for a replacement, and the other features built into the cradle, I believe there is stuff in there, bypassing which will not do your unit any favours. To make absolutely sure, see if you can open the cradle up and see what it actually contains without breaking it - post us a photo if you are unsure. Especially considering the damage to the resale value of the unit, I have to ask is it not better just to get a handheld or flush-mounted unit rather than modifying your 700? If you just have got fed up with replacing damaged cradles (as some have according to reviews) then the universal cradle appears to be a more reliable replacement than the original; http://www.circuitcity.com/ssm/Magellan-Roadmate-700-Universal-Cradle-702176/sem/rpsm/oid/135062/catOid/-13128/rpem/ccd/productDetail.do although it is sold elsewhere also. If your reason is that you want to be able to move it around from the cradle position without moving the cradle, then so long as you can identify the power terminals on the cradle/unit you should be able to merely connect a cable between them, within reason and almost certainly within the dimensions of a vehicle. Hope this helps, please post again if you would like more help :)
Posted on Jun 22, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Jun 23, 2007
    From the assorted reviews I have read, I think the easiest and neatest solution would be a universal cradle - There was only one negative review i discovered about that, and only one positive one about the original cradle design.
    The spring (that holds the unit into the cradle) in the original cradle sounds like it is the most likely culprit - maybe there is a way to fix or improve that but I get the feeling from what I have read that it is a design fault.
    check this link for the AC adaptor for the 700;
    http://www.radiooutfitter.com/store/8315...
    as far as i can tell it plugs directly into the unit without the cradle - I had no luck with establishing exactly what DC output voltage it produced, but it suggests that you could plug direct DC into the same socket, hopefully 12V.
    Perhaps you have one of these adaptors as I believe it was sold with the unit - check the available voltage (probably written on it, but even blowing up the photo and trying to crisp it didn't show anything legible) else check with a meter.
    Hope this gives you some more ideas, post back with anything you think and I can try and investigate further :)
  • Nigel Ridehalgh
    ps there is however a little confusion on that link if the adaptor is for the 700 or the 500 - sorry only just noticed.
My magellan GPS will not turn on or charge. I tried
these models and many other magellan model have issues with the power port failing..if you have a friend that has the same model, borrow his/hers and try the cradle on your gps and see if that works..im sure that power connection on that model is on the cradle.
Jun 14, 2009 | Magellan RoadMate 700 GPS Receiver
Unit will not turn on
Check for voltage at the end that plugs into the cradle. If no voltage there, check glass fuse inside end that plugs into car plug. If there is voltage at the cradle end and it still doesn't turn on then it's the cradle. The cradle fails over a short time inside the cradle plug. You can hard solder the cable end to the cradle circuit board, which is a delicate procedure which I have perfected but I am an electronics person. If you want to buy a new cradle it will fix your problem for turning on the gps but I recomend a cable tie on the cradle cable end to stop the strain on the connector so the new cradle connector will last a long time.
Jan 24, 2009 | Magellan RoadMate 700 GPS Receiver
Intermitant powering up
Yes, it is most likely the cradle. My unit did the same thing. Picked up a new cradle and it works.
Apr 07, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan 700, lost signal found a causation. Need help
Bin the Magellan - nothing but problems when you need to update or resolve problems.. I am replacing my magellan with a Tomtom Go which does auto updates via a cradle linked to PC.
Dec 16, 2007 | Magellan RoadMate 700 GPS Receiver
Cradle defective
This cradle/power problem was a major problem at launch 4 years back - i had 3 units before I got one that worked OK and that replacement was itself a factiry refurbished unit. Even now, sometimes the power lead is verys ensitive and the unit shuts down.
Magellan Support is absolutely useless (apart from 'John') they just don't respond to queries. I updated to latest maps and firmware 6 (actually shows ver 5.37) on the understanding that I would get Magellan Tools and could then load cameras. BUT it has been such a huge waste of time.
I am at last binning my Roadmate and getting a Tomtom Go 720T with Traffic and cameras preloaded. It auto updates each time you sit the unit in its cradle linked to PC/internet.
Wish I'd never wasted over £800 on Magellan 4 years ago.
Dec 13, 2007 | Magellan RoadMate 700 GPS Receiver
GPS
Check the pins on the cradle. I've noticed that sometimes, my pins will become misaligned (they become bent, or unevenly spaced). Also, make sure the unit is snapping completely on the clip. Sometimes, the clip doesn't "bounce back" after the unit is released, and a subsequent attempt to attach the unit to the cradle results in a faulty connection.
Dec 09, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan GPS Roadmate 760
Are you willing to part with it, I may be able to use it for parts denisdsouza@hotmail.com
Aug 05, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 can't power up 2nd time in car
Jun 19, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan 700
if it's the same plug that works with 700/760 then the plugs good. .if your trying to use one for an 800/860T then it's not good. yes it could be the cradle or anything inbetween your unit and the source.. Or.. if your hearing the smallest rattle.. then look for one of my solutions talking about U6.. a small chip that is common to come loose from the board from rubbing up against the rear housing.
May 01, 2007 | Magellan RoadMate 700 GPS Receiver
Doesnt stay powered-up
Small IC chip on the back of your I/O board is losing connection. Look at my posts to other users with the same type problem. -Daniel
Mar 31, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
131 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
