Question about Gateway MT3705 Notebook
Unlock my laptop
Gateway m465-e
  • bellesa4146 Jan 30, 2009
    i forgot my password to get in to my laptop
  • Randy Hough
    Randy Hough May 11, 2010
    By the power invested in me by the computer gods,I have commanded it to be unlocked. LMAO
    Just kidding,Please send more details
    Scholar:
  • 170 Answers
You have three options.
  1. Disassemble the laptop and remove the cmos battery and put it back in.
  2. Reinstall windows, put your windows CD in the drive and restart your computer. ( all data well be lost)
  3. Take it to a shop, for $20 they reset it for you
Posted on Jan 18, 2009
4 Suggested Answers
  • 120 Answers
SOURCE: Gateway M465-e Wont Start
Is your laptop receiving charge from the power supply. If not your power supply is bad. If yes.. The power mosfet of your laptop need to replace including a fuse.
Posted on Jul 26, 2009
Geekman
  • 32281 Answers
SOURCE: Have a gateway M465-E with power issues. Low
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Posted on Nov 26, 2009
Testimonial: "Thank you...tried all the above and determined to be a power adapter problem. "
tbreeze47
  • 3083 Answers
SOURCE: will any wireless mouse work with my gateway
One way to know, try it, but keep the receipt in case it doesn't work. Most mice should work, but only someone who's tested every mouse on every make computer would know the answer to this question.
Posted on Mar 21, 2010
Gateway M465-E Notebook hangs after booting
try removing and testing each memory separately
or try fix start up
Dec 16, 2013 | Gateway M465-E Notebook
M465-e has flashing blue light wont startup
Try removing the battery and disconnecting the power for a minute or so. Then re-install the battery and power cord and try booting it up again. If that doesn't work I'm afraid it's probably an issue with the motherboard.
If in the unfortunate event the motherboard needs to be replaced, here are the instructions:
http://www.ehow.com/how_7498700_remove-motherboard-gateway-m465e-laptop.html
Looks like boards range between $100 - $200
If it's not something you want to tackle yourself, expect labor to be about $100. Consider the age of the laptop and the cost of about $200-$300...some newer laptops can be had for that amount. (Especially with Black Friday sales going on.) Check microcenter.com
Nov 24, 2012 | Gateway M465-E Notebook
Gateway m465-e touchpad is not working; cursor is slowly moving
To fix your touchpad, read the information from this link.
Feb 03, 2011 | Gateway M465-E Notebook
I have a gateway M465-E it power up but it has no battery indicator when charging or just on also i have no screen light up i have a spare known good back half of the same model when i connect it to the...
Hi Good day!!! Did you try checking the RAM of your laptop? try to remove it clean it same as the memory slot and then re insert it see if your display will light up.. if still not reply to me
Nov 09, 2010 | Gateway M465-E Notebook
Gateway M465-e laptop won't detect hard drive for XP install
The Gateway M465-e is only compatible the SATA hard disk drives. If the drive you are using is not a SATA drive, then it will not be able to work with your hard drive.
Dec 18, 2009 | Gateway Computers & Internet
Nov 26, 2009 | Gateway M465-E Notebook
No Audio Device on Gateway notebook M465-E- Need Sound Card?
Go to device manager, sound / video. and your sound card will be in there. Oh and right click on my computer and select properties, Hardware. if you didnt know.
Aug 03, 2009 | Gateway Computers & Internet
Jul 26, 2009 | Gateway Computers & Internet
M465-E will not turn on
Simply your RAM or mother board is faulty. Replacing RAM is cheap but repairing Mother board modules is an expensive affair.
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | Gateway M465-E Notebook
Gateway M465-e
replace the cmos battery
Mar 18, 2009 | Gateway M465-E Notebook
Gateway MT3705 Notebook Logo
174 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
