Question about Prima CV2011 TV
Bottom of screen flickers, and eventually the screen 'freezes'
Prima flat screen, wall mounted TV.  I get horizontal waves (and I don't mean wavy lines, but rather pulses, I guess) at the bottom of the screen.  If I leave the TV on while this is going on, the entire screen will eventually freeze with vertical lines of black and color.  It first happened while I was watching something I had PVR'd, but realized that it happens on TV too (HD or otherwise).  I made sure all the connections were good and solid, checked some settings...all seems right.  Had good viewing for 2 days, and now it is back to the waves and freezing...am I hooped?
They have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
Posted on Feb 28, 2009
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Toshiba/ 42H81 / hyper board
You can either yrplace your Hyper board, or replace all the serfice mount capacitors in it. The cap replacement fixes this 90% of the time.
May 09, 2012 | Toshiba 42H81 42" Rear Projection...
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Horizontal,wavy lines on sony xbr4 52" sony lcd tv
hi,
check the ground connection of your house wiring. fist of all remove all the external input like set top box, cable connection, dvd etc from the tv. Then power on the tv and watch is the wave is there or not. if it there then ,if the tv power cord comes with three pin connector then remove the earth connection on the wall outlet socket to which you connect its power. the connect the power and switch one the tv.
if the wave will not appear then connect external devices (set top box, dvd etc) one by one and watch which device produce this wave in the tv. also check the ground connection of that device which produce this wave.
If all these will not help full then the SMPS power supply of your tv have some problem. Normally this type of complaint arises due to the faulty Main filter capacitor. you can see it in the power supply.. It will be the big capacitor according to others. Normally There will two or more. replace the same. will solve this problem. if you need any more assistance feel free to contact me through fixya
ok
Mar 05, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
Have a 50fx48b Hitachi TV, screen flickers, gets wavy and goes to horizontal line, smack top of tv and it goes back to normal.
This problem is a couple of bad caps in the vertical and horizontal sweep area, just can't remember which. It use to be a 220uf cap that needs changing.
Feb 28, 2011 | Hitachi 50FX48B 50" Rear Projection...
I have a few horizontal wavy lines at the top of the screen when I first turn on the TV. They eventually fade after a few minutes. What's going on? Is this serious?
yes it is, your hyper board has bad caps and they will just get worse and worse. you can run it on an HD signal to keep it going longer but eventually even the HD will have the wavy lines too.. basically the hyper board needs new 10uf 16v surface mount capacitors, replace all those and your golden, but its a difficult repair, even for a educated and seasoned electronics tech, estimate from repair shop will run you $250-$550
if you can solder surface mount, you can fix it yourself for like $20
let me know if I can provide further assistance
Sep 09, 2010 | Toshiba 42H82 42" Rear Projection...
Wavy horizontal lines on bottom of RCA 36in Truflat TV
The convergance or y-sus board can become faulty. The capcitors do tend to burn out. It is about a $250 + repair for this. Not all parts can be repaired, but they can be replaced. A capacitor tester and multi-meter are about the best tools for the job. If the price you get is over $250, I simply would replace it instead of repairing it..
Sep 13, 2009 | RCA TruFlat 27F520T 27" TV
Wavy screen
Sounds like power interference. Try a different wall plug or power cable
Apr 16, 2009 | Computers & Internet
Sony ke-p42m1
dunguard, How long have you had this for, zazwpx
Jun 04, 2007 | Sony KE-P42M1 42 in. Plasma Television
Wavy Screen on Startup
I gather from your post that wavy can mean two possible things as the TV comes on, you see the picture flow like ocean waves? In this case you may have 60Hz hum modulating with the picture, this is actually unlikely these days, but I have heard it happens sometimes. The other thing it could be is light horizontal tearing. This happens when the horizontal frequency is too high or too low. You are not going to like my solution because I feel that for problems like this the set must be analyzed not just subjected to "shotgun troubleshooting", so here I go, Take the TV to a repair shop.
Feb 28, 2007 | Toshiba 50H72 50" Rear Projection...
Prima CV2011 TV Logo
226 people viewed this question
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
