Question about Hitachi 46F510 46" Projection HDTV
Digital signal hookup and compatability
My 46F510 should be HDTV compatible for the new signal however, I am not getting an HD signal at this time. Do I need to purchase a digital converter box or should my tv work when the signal is changed on Feb. 19th.
  • superwolf22 Jan 18, 2009
    So I need to get a converter with the coupons I got from the government or just a special hookup for this tv. I have been told that my tv should work without the converter box.
    How do I know if it has the freeview or not?
  • 135 Answers
The tv will be hd through the dvi port you can purchase a converter at most shops the you plug the hd freview sat and it will work if the tv has freview built in then it will still work when the switch over happens
Posted on Jan 17, 2009
  • paul hughes Jan 18, 2009
    if it has freciew you will be fine for digital switchover if you want to connect a hd freview then you need dvi to hd converter
    hi it does not have freeview so you will need a freeview box
How do I change my service from analog to H D?
Most LCD tv's built in the last 4 years are HD compatible. Most cheaper brands tv's are 720 HD and some are full HD 1080 a little more money. Since their is no more analog broadcast as June 2009 all tv's manufactured around 2006 started incorperating the digital tuner (DTV) along with the analog so that the tv would still receive analog broadcast while the digital transistion was ongoing. All tv's with a Cathode Ray Tube (glass picture tube) are not HD compatible. First you will have 1 or 2 ports on the tv ethier on the side panel or rear panel of the set. They a marked HDMI 1 HDMI 2 or HDMI A HDMI B. If you have these ports your set is Hd Compatible. You may also need to upgrade your cable or satelllite equipment and subscribe to a HD package to be able to get HD service. You will need a HDMI cable to connect your cable or satellite receiver to the HDMI port on you tv. Call your local cable or satellite provider for options to upgrade to HD. Most over the air broadcast stations depending on your area transmit some stations in HD free of charge. A good quality outdoor antenna works best to give you stable signal. You may need to change the settings of the tv as some sets default to the 480i this is the standard digital signal.
Sep 10, 2014 | Televison & Video
The provided HDMI female receptacle is being used by the DirecTV hookup. Is there an adapter, from coaxial cable to HDMI (male receptacle)?
HDMI cable has several diferential digital (LVDS) signals that also carry digital audio on them, not compatible with coax!
Jan 19, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Cant get hd to work
What is HDCP?
HDCP stands for High-Bandwidth Digital Content Protection, a copy protection scheme to eliminate the possibility of intercepting digital data midstream between the source to the display. The format designed by Intel and licensed by Digital Content Protection, LLC using an authentication and key exchange procedure before video and audio is presented. Products compatible with the HDCP scheme such as DVD players, satellite and cable HDTV set-top-boxes, as well as few entertainment PCs requires a secure connection to a compliant display, the process often described as the handshake. Due to the increase in manufacturers employing HDCP in their equipment, it is highly recommended that any HDTV you purchase is compatible. Although most video devices support high-definition video over component output, analog connections are scheduled to phase out in the future or possibly forced to limited resolutions output.
Why is it important to me?
Although manufacturers are still making most products with at least component HD output, new generation of products like HD-DVD and Blu-Ray devices will limit the analog output resolution (Analog defined as Component or RGBHV). The highest resolutions these devices can output (720p/1080i/1080p) will be available on via the digital (DVI or HDMI) connections that employ HDCP encryption. Any new HDTV purchase should have a digital HDCP compatible input.
It is important to note that HDCP is currently not a standard used in PC monitors, and almost none of these displays have Component inputs. Although PC monitors are HDTV capable, HDCP encryption limits this type of use. If you use an HTPC and want to ensure dual use of your new flat panel display, look for HDCP compatibility.
How does it work?
A simple answer is that an HDCP session will result in the exchange of keys between the source and display device. The source device will query the display to make sure that the equipment is HDCP compliant before video is shown. Non-HDCP devices such as PC's and older model DVI products will work with any DVI compliant display, but the HDCP compliant boxes will show an image only on HDCP compliant display.
Other products affected by HDCP are scalers, switchers, and splitters (distribution amps). While these devices do no authentication for key exchange, they must be able to transmit the presence of HDCP if the video is handled (processed) in any way. Due to the two different formats of digital connections, occasional inability for proper communications may result in loss of interoperability. The newer format, HDMI was designed to be backwards compatible with DVI and in most instances, the two signal types are easily adaptable, but older devices may not always work well with in-line devices like scalers or switchers. These problems can sometimes be fixed in "firmware' although that is not always the case. Incompatibility is often displays on-screen as a snowy image or an error message.
Hope this explains it for you.
Jan 08, 2011 | Televison & Video
How do I remove the Hd compatibility message from top of screen?
Go in ur tv menu go to Option go down the menu check the Program Title Dsiplay pick no.That should take away the HD signal sign.But some tv must have that HD sign,to tell u it in HD programings.
Apr 03, 2010 | ViewSonic VPW425 42 in. Plasma HDTV
So you are telling me I need a digital converter for this TV to g
Who was not watching the months of public service announcements? You need a Digital-to-Analog (ATSC-to-NTSC) converter box to receive over-the-air (OTA) signals in most parts of the country. You do not need one for most cable and satellite box outputs--they are NTSC or HDMI. Some low-power, typically religious, stations are still analog. Note OTA may be high definition (HD) or standard resolution (SD) but will be digital.
To get HD on your HD set you must have OTA (HD TV tuner, not converter), cable (QAM TV receiver), satellite (HDMI or 5-wire RCA),or Blu-Ray with HDMI or RCA.
Aug 18, 2009 | Hitachi 46F510 46" Projection HDTV
Screen goes black and resets during HD shows
Are you on Cable service or Direct TV. Have you tried the analog signal? HDTV ready monitor can use a standard analog signal. Most HDTV ready tv's have analog tuners built into them, meaning you can use standard cable/over the air signals on them. They will not be high definition. You can use the analog hookup by hooking it to the coaxial antenna hookup, or, if you have a cable box, it may have a set of audio/video outs (the red-white-yellow rca plugs on the back) that you can use to hook up for a slightly sharper picture.
Aug 31, 2008 | Sony KP-53HS10 TV
HI i have a 42" Hitachi HDTV 1080p (LCD)
Most newer Digital TV's don't display Analog signal very well. Often worse then an Analog TV. This is normal to a degree. If your Wii has component  cables, try using that. As for cable, you might get a better signal with Digital Cable.
Apr 23, 2008 | Hitachi 46F510 46" Projection HDTV
DVD Upconverters???
Greetings jhays82,
Some DVD players can upconvert DVD signals to resolutions that match those of HDTVs, and send them to a compatible TV via a digital video connection. HDMI (High-Definition Media Interface) and DVI (Digital Visual Interface) both offer high-quality digital transmission of standard- and high-definition video signals. HDMI can also carry multichannel audio, and is backwards compatible with DVI (video only). So in other words, to receive the full benefit from an upconvert, you would want to hook it up with HDMI or DVI.
Thank You,
Agent Dort,
Go Ahead. Use Us.
Apr 14, 2008 | Televison & Video
Nintendo 64 HDTV
I am not an HDTV expert but I believe they are all backwards compatible so the fact it is HD should not be a problem. Have you tried a vcr or dvd player on the same hook ups? It is possible you are trying to use a video input that is already in use? I know on my TV I have the DVD hooked up with an S-video cable to "Video 2". Right next to the S-video hookup are the red, yellow, white RCA jacks. On my TV these can't be used when the S-video is in use so I have to have the games hooked up to the front panel "Video 3". I would disconnect everything and try hooking the N64 up in each input to see if you can find one that works.
Mar 02, 2008 | Nintendo 64 Console
Hitachi 46F510 46" Projection HDTV Logo
122 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
