Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side fridge makes loud thud sound...starting/stoping?
My friend was over last night and heard the refridgerator make this loud ba-dum sound and said her mothers did the same right before it quit working, it has been about a week that it has been making the sound, on and off. Sounds as if something is ending then ba-dum, or ba-dum and something is started?? Please Help! I just went shopping and would have to freeze everything in my garage...12 degrees outside, a foot of snow and well I hope I can fix it or get help fixing it. Thank you to all you intelligent, mechanical, knowledgable people!!!!! Teresa
    Novelist:
    Champion:
  • 220 Answers
I am not sure when yours is making the noise, but I have a GE side by side and mine would make a similar noise when the compressor shut off. Check your warranty paperwork, I think GE has a warranty on the compressor for 5 years. It sounds like your compressor is going bad. If its in warranty, remember " the squeaky wheel gets the oil" complain until they fix it.
Sometimes when the repairman is there, it takes a little pushing to get them going in the right direction and to acknowledge compressor problems. Mine has a new compressor and runs like a champ.
Posted on Jan 19, 2009
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
I have a ge sisde by side model#gss25rgma ww. the fridge/freezer is working good, but now not making ice, it has started to make a really loud humming type sound if the doors are left open to long than...
Sounds like a evaporator fan motor problem. However remove rear panel and if slight frost on top of evaporator replace motor if not post back or call professional
Oct 02, 2017 | Refrigerators
Refridgerator side is set to 34 but temp reads 52 last night freezer was at 20 when set to 0 cleaned coil of dust now reads 0 but fridge side still wont come down it is a GE side by side
your evaporator coil in the freezer behind the rear panel is iced up and cold air cant flow thru ice,defrost the evaporator coil,then check continuity of the heater element under the coil,if its good,then suspect the defrost control,usually located in the refrige side on the upper area
Jul 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
A side by side GE refrigerator with a loud hum
Hello Kchoffman73,
It sems we developed the same problem.
The hum seems to be coming from the bottom rear of the
fridge.
we have a GE side-by-side model TFX25JR.
The fridge is about 12 years old.
Whats the status of your fridge ? Did it ever stop
humming ? Did you replace or repair it ?
Does it still work ?
Thanks
Sep 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
New refridgerator delivered this morning to replace the same model that was a lemon. The fridge is making a sound on the fridge side. When I open the door to the freezer side the sound stops. When I...
sounds as if there is an issue with the evaporater fan motor, perhaps the fan blade has come dislodged and is makinf noises, normal for the fan to stop when the frig door opened as welll,
Dec 17, 2008 | Refrigerators
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Clicking Fridge
I used to have a whirlpool fridge, they are the ones who make kenmore too. It used to make a loud thud noise. It was the compressor turning off. sometimes it was loud enough to wake me up at night. It did this for years and I never had any problems with it. when I purchased a larger fridge I sold it to a friend and its still working today. If you can tolerate the noise I wouldn't worry about it unless it starts giving you trouble.
Nov 01, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
191 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
